SidSnot
SidSnot
Auckland, New Zealand
197 registered members (Adam M.), 1,984 guests, and 542 spiders.
10070 Registered Users
koan58 85
Lannis 79
NickL 75
501,616 mail-order LSR
Topics65,998
Posts638,719
Members10,070
55 Mac , Oil leak. #706255
08/26/17 8:02 am
08/26/17 8:02 am
Lansdowne ,Mid north coast , ...
Jon C Offline OP
Jon C  Offline OP
The feed pipe union at the crankcase feeding the pump leaks, I would imagine a common problem , thread in case is worn to affixe through bolt ,Is there a cure without striping and machining case face and retapping banjo bolt thread. Cheers , Jon
Re: 55 Mac , Oil leak. [Re: Jon C] #706258
08/26/17 8:44 am
08/26/17 8:44 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Normal solution would be to use PTFE tape wound onto the banjo thread, and Dowty seals on the banjo union, and try not to overtighten.
But DO be careful not to block oil feed with the tape! ... Bear in mind that this oil feed is the lifeblood of your engine.
Page Time: 1.288s Queries: 15 (0.016s) Memory: 0.9895 MB (Peak: 1.1069 MB) Zlib disabled. Server Time: 2018-02-18 19:45:39 UTC
