porge
porge
Tasmania, Australia
38 registered members (998John), 292 guests, and 457 spiders.
10294 Registered Users
Stuart 99
Lannis 68
Mori55 67
640,539 mail-order LSR
Topics67,424
Posts654,681
Members10,294
Thunderbolt Electric...? #704740
08/12/17 2:24 pm
08/12/17 2:24 pm
Kent Garden of England
Kent Shaun Online content OP
Kent Shaun  Online Content OP
Suppose I SHOULD ask on the BSA board bit, but I rarely venture away from the Pub... wink
As you might've read, my A65 has been a bugger to start lately, and YES it was dirty points, well at least I think so. I got it to fire up and it runs sweetly, so that'll do me for now. But then I got me to thinking, which is always a bad thing... frown
Should I, or should I not, fit a Pazon Electronic ignition system, had me one of them buggers in my first BSA, me B40. And MAN, what a difference, also got me an electronic system in the Guzzi. Nice and easy to start, and runs sweetly... bigt
Just can't see me mucking about too much with points, so if I can make it easy that's what I'll do, BUT, and that's a big but you'll notice. Am I wasting time and beer vouchers... whistle
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704746
08/12/17 2:43 pm
08/12/17 2:43 pm
wadeschields Offline
I have both and honestly the points bikes run just as good and any of them. Only once did I have to fuss with the points on the triumph when they got loose and twice with the points on the 51 when the mag got wet hauling the bike on a trailer in a storm. Fired right up after I used an emory board on the contact surface.
That said I never do anything to the boyers.... Just have to worry about having a solid 12 volts and hope nothing breaks on the road as I couldnt fix a Boyer with a hammer or a file smirk
12 volt issue probably void now with the new technology units though
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704776
08/12/17 5:22 pm
08/12/17 5:22 pm
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
I'd shove in a pazon on any bike that I had points issues with
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704787
08/12/17 6:14 pm
08/12/17 6:14 pm
A10 and M21 are magneto bikes, they have points, and they'll keep points. One set of points in a magneto is a good solid ignition system.
The Firebird, Norton, and Guzzi SP all have EIs - Boyers in the Firebird and SP, Pazon in the Norton. All of them work good, all the bikes seem to run a little smoother with them because both cylinders can be right on time with no compromises for gap and dwell to get the timing right.
If points started annoying me, I'd go ahead and upgrade.
Re: Thunderbolt Electric...? [Re: wadeschields] #704788
08/12/17 6:16 pm
08/12/17 6:16 pm
Yep, the Pazon's good down to about 8v. By the time you're there, you're almost walking anyhow, no matter what your ignition ... !
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704801
08/12/17 6:53 pm
08/12/17 6:53 pm
Royal Berkshire.
Kev. Online sick
Kev.  Online Sick
Royal Berkshire.
I would fit a Dyna DBR-1, I have one fitted to the Guzzi, easy to fit, and you get to keep all the original ignition in place, and if the worst should happen out on the road, you just swap one wire over, and you are back on points again, so you have every chance of getting home, even on a BSA.
That's my thoughts on the subject, but then no one ever listens to what I have to say.
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
1981 Harley FLH
2006 BMW R1200GS
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704814
08/12/17 8:17 pm
08/12/17 8:17 pm
Sunny Sussex, UK
tbird649 Offline
tbird649  Offline
Sunny Sussex, UK
Ive got a Pazon on one Triumph, Boyer on the other. Boyer one is my off road bike, has no battery, uses Boyer powerbox. On the Thunderbird, I have a sealed Hayter lawnmower battery, also a modern version of Lucas blue capacitor, I have had main power wire to Ammeter break, bike still runs without battery, although lights must be switched off to start, and doesnt like to tickover slow with 55/60 H4 headlight, although runs fine above tickover to get you home. Fitting EI is the best improvement I have made to both bikes, also to Mrs Tbirds 400/4
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704874
08/13/17 3:30 pm
08/13/17 3:30 pm
Sacramento California
Rusty Goose Offline
Rusty Goose  Offline
A tale of two A65's... I put a Sparx e.i. on my '66 A65 and once it was timed and dialed in (15 min) I did not do a thing to change it until I sold years later. During that time I found my '67 A65, and it was in really decent original condition. I decided to leave the points and the rest all original. I spent an inordinate amount of time setting up a degree wheel and pointer so I could strobe each cylinder and get the optimum spark at a perfect 180 degree. One Saturday down... That bike then started soooo much easier and ran much smoother, less vibration than the '66. The offset is I give up a Sat. every spring fiddling with it, making it perfect, changing oil/filter, adjusting primary and all the rest of the spring dance.
In the end, the e.i. got sold, kept the points. The e.i. went south on the new owner later on, and now sits on display in a shop.
I feel you can "dial in" points better. When they are in good nick, all sorted properly, I feel they are better. BUT, you have to do all that work periodically to get the slightest (maybe imaginary) edge over the e.i. Or just spend the cash, drop in the new fangled computer and forget about it. More time to think about the route to the next pub.
1967 A65 Lightning
1967 Triumph T20 Mountain Cub
1967 Moto Guzzi V7
1969 B44 Victor Special
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704889
08/13/17 4:58 pm
08/13/17 4:58 pm
Ontario Canada
Don Leaming Offline
Don Leaming  Offline
Ontario Canada
Ran a Boyer for 20 years in the 1970 Interceptor. Never touched the timing again! Never needed anything ever.
I am going to put one in the Triumph.
The 65 Interceptor has a freshly rebuilt mag so I am stuck with points in that bike.
1969 Triumph Tiger 650
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704896
08/13/17 5:47 pm
08/13/17 5:47 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
My 70 Thunderbolt has an old analog Boyer - yes the one which needs 12V to work.
I suspect its around 30 years old, I had to cut and redo all the old wires 10 years ago, they were stiff and broken.
For next 10 years I didn't have a problem with it other than connecting wires near the pick up plate lost contact once.
I disconnected them, reconnected and this was it.
Agree with Lannis here, only place for point ignition is one cylinder magneto bikes.
Re: Thunderbolt Electric...? [Re: Kent Shaun] #704915
08/13/17 9:20 pm
08/13/17 9:20 pm
Stafford, UK
Andy Lorenz Offline
Andy Lorenz  Offline
Stafford, UK
Boyer, the older analogue ones need 12V or they retard the ignition, I keep it as a spare.
I have the mew Mk5 version - no problems.
Thrash, Bang, Re-Build...
