48 dingalinger
48 dingalinger
Victorville
39 registered members (998John), 325 guests, and 388 spiders.
10291 Registered Users
Stuart 95
Lannis 66
Mori55 65
638,130 mail-order LSR
Topics67,397
Posts654,377
Members10,291
A65 Kickstart quadrant #704517
08/10/17 12:49 pm
08/10/17 12:49 pm
Southampton UK
Peter Gascoigne Offline OP
Southampton UK
Is the kickstart quadrant one piece, or is the quadrant a seperate piece to the shaft, and if so, how is it attached?
1971 BSA A65 Lightning "Bitsa"
1966 BSA A65 "Beezuki" with GT550 two-stroke engine
1974 Triumph T150 830cc
1975 Suzuki GT550
1975 Laverda 1000 3C
1986 Yamaha SRX 600
Re: A65 Kickstart quadrant [Re: Peter Gascoigne] #704594
08/11/17 5:17 am
08/11/17 5:17 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
It is one piece, unlike the Triumph which is on splines.
Re: A65 Kickstart quadrant [Re: DMadigan] #704635
08/11/17 3:21 pm
08/11/17 3:21 pm
Southampton UK
Southampton UK
Thanks Dave.
1975 Suzuki GT550
1986 Yamaha SRX 600
Re: A65 Kickstart quadrant [Re: Peter Gascoigne] #704778
08/12/17 5:41 pm
08/12/17 5:41 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
If you are replacing the quadrant, make sure you get the proper one for your year. Later types are not the same as the earlier types...
Re: A65 Kickstart quadrant [Re: C.B.S] #704813
08/12/17 8:12 pm
08/12/17 8:12 pm
Southampton UK
Southampton UK
CBS,
Thanks for that. There is nothing wrong with the quadrant, I just wanted to move the quadrant round the shaft a bit, but as it's one piece I can't do that.
1975 Suzuki GT550
1986 Yamaha SRX 600
Re: A65 Kickstart quadrant [Re: Peter Gascoigne] #704948
08/14/17 7:56 am
08/14/17 7:56 am
can always bend the lever.
Re: A65 Kickstart quadrant [Re: Peter Gascoigne] #704951
08/14/17 9:35 am
08/14/17 9:35 am
Kristiansund. Norway
Arnstein Offline
Arnstein  Offline
If you want to get your kick lever to another angle I think the best way is to weld and grind the cotter pin keyway on the shaft to your preferred angle.https://www.dropbox.com/s/fuwh2pxj6tgcqb5/IMG_0810.jpg?dl=0
Arnstein
BSA Spitfire MK3.800cc
Honda CB450T -71
Laverda RGS 1130cc -85
Ducati 1098 -08
Re: A65 Kickstart quadrant [Re: Arnstein] #704992
08/14/17 5:07 pm
08/14/17 5:07 pm
Mullaloo Western Straya
Bodie Offline
Bodie  Offline
Depending on which way round you fit the cotter pin will also make a difference to how the kickstarter sits at rest .
Slipped in from the right with the nut facing towards the rear wheel the kickstart lever will sit hanging backwards
at an angle and likely the foot rubber will touch the oil tank .
Slipped in from the left & nut facing towards the front wheel the lever will sit in a more upright position
