porge
porge
Tasmania, Australia
40 registered members (998John), 304 guests, and 457 spiders.
10294 Registered Users
Stuart 99
Lannis 68
Mori55 67
640,539 mail-order LSR
Topics67,424
Posts654,681
Members10,294
info or piston for 1948 g80 #703839
08/03/17 6:47 pm
08/03/17 6:47 pm
superior, wi
actriumph Offline OP
superior, wi
Bike came with wirewound piston, but these are few and far between What years and where can one be bought that will work for the old ironhead thanks Al
alan r Cirilli
Re: info or piston for 1948 g80 [Re: actriumph] #703870
08/03/17 10:41 pm
08/03/17 10:41 pm
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
JP Pistons in Oztralia is one possible source for pistons.
They are quite widely used here, to good reports. I've not needed to have tried them, yet.
Although some reports have them as being a bit heavy, and they need good clearance.
http://www.jp.com.au/MCM.html
Measure and weigh your existing piston, and make sure they supply something suitable.
JP 1032 looks like what you want, make sure you check with them it will be the same.
And make sure its rebored with plenty of clearance, too tight is not good.
Typical watercooled clearances will cause trouble....
hth.
Re: info or piston for 1948 g80 [Re: Rohan] #704470
08/09/17 9:59 pm
08/09/17 9:59 pm
Alan,
Y'don't say what over size you are at, or want to find?
You might try to find who bought out Domi Racer, MAYBE they may still have a wire wound piston the size you want.....
I bought a .020" over wire wound piston from Domi, just before they closed for ever..... I will need to find rings, circlips, and a wrist pin when I get to the point I need it.
Brett
P.S. .... I don't know if anyone keeps their "worn out" pistons, but maybe, if you ask, someone might have a "worn out" piston of the size you need to go to, ask your machinist if they can set up to bore to a worn piston, wire wound or otherwise, to the clearance it needs, once you have the worn piston in hand, so the cylinder and piston can be handed to the machinist.
Like, I have ONE .030" over BSA A65 piston, I'd SURE like to find another usable one to match. No cracks or smears... Or other damage...
Moderated by  Matchman62
