porge
porge
Tasmania, Australia
36 registered members (Andy Higham), 310 guests, and 456 spiders.
10294 Registered Users
Stuart 98
Lannis 68
Mori55 67
640,474 mail-order LSR
Topics67,422
Posts654,673
Members10,294
B50 chain length? #704356
08/08/17 8:30 pm
08/08/17 8:30 pm
Naarfuk, UK
Tigernuts Offline OP
Naarfuk, UK
I'm at the stage with my B50 rebuild where I;m almost ready to put a rear chain on. The one it came with is far too knackered to re-use. It is also long enough to go around the massive 70T rear sprocket the bike came with!
Doe anyone know how many links needed for 17T gearbox and 52T rear sprockets? I've asked this on the B50.org forum but people on there seem to find it an odd question, as if there is no right answer! There obviously is a right answer though, and if anyone on here can let me know what it is, I'd much appreciate it.
Re: B50 chain length? [Re: Tigernuts] #704376
08/09/17 12:11 am
08/09/17 12:11 am
Jon W. Whitley Offline
17 T front and 52 T rear would require a 106 link chain.
Re: B50 chain length? [Re: Jon W. Whitley] #704408
08/09/17 10:19 am
08/09/17 10:19 am
Naarfuk, UK
Naarfuk, UK
That's good of you Jon, thanks. I knew there must be an answer!
Re: B50 chain length? [Re: Tigernuts] #704428
08/09/17 2:26 pm
08/09/17 2:26 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
A likely reason that folks on B50.org didn't have an easy answer for you is that any chain you buy you need to shorten. In the 520 size 120 link chains are the norm as far as what is for sale. One just pulls the chain onto the assembled wheel and motor (wheel in forward position) and mark the chain where to cut. Pull it off cut it and re-assemble. That way no mistakes are made in the length/link calculation. In the time it would take me, or have others, research what length chain I would need based on my sprocket combination I'd have already done the above and already had a mounted chain.
Peter
Re: B50 chain length? [Re: Tigernuts] #704432
08/09/17 3:06 pm
08/09/17 3:06 pm
You are welcome.
Re: B50 chain length? [Re: Tigernuts] #704446
08/09/17 5:39 pm
08/09/17 5:39 pm
And the comments at B50.org on the adjuster are valid too.
Re: B50 chain length? [Re: kommando] #704461
08/09/17 8:26 pm
08/09/17 8:26 pm
Naarfuk, UK
Naarfuk, UK
I think my comments on there about Triumph chain lengths being much more precise are also valid. I loved my B50 that I had in my youth. Now that I've been rebuilding another one, having done several unit 750 Triumphs, I have to say that I find the engineering almost embarrassingly crude, in comparison. So many vague areas, design problems looking for home made solutions or at least, improvements. They make T140s seem very advanced, and that isn;t something I thought I;d find myself saying!
Re: B50 chain length? [Re: Tigernuts] #704465
08/09/17 8:49 pm
08/09/17 8:49 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
B50s are in reality an over bored beefed up tiger cub engine. Mr Turner took the easy way when designing replacements for the C12, B31, B33 etc. In most respects the earlier engines were far superior
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: B50 chain length? [Re: Andy Higham] #704507
08/10/17 10:53 am
08/10/17 10:53 am
Naarfuk, UK
Naarfuk, UK
Very true. Its amazing that B50s work as well as they do (and when they're good,they really are very good). The T140 is basically a 1937 design so even older in it origins than the BSA unit singles, and they work far better than they should too. I think the reason why the 750 triples are so much faster and more reliable (as racers) is that they were actually designed from scratch in the modern age (1967?). Stretching engines designed to produce a handful of horsepower ever further, until just below the very limits of their capabilities, was something BSA, Triumph and Norton specialised in, with surprising success.
Re: B50 chain length? [Re: Tigernuts] #704514
08/10/17 12:17 pm
08/10/17 12:17 pm
Bolton Lancs UK
Bolton Lancs UK
Triples were not designed from scratch. The engine is essentially one and a half daytona T100 engines with a T120 gearbox behind and an Austin mini clutch
1962/67 Greeves 350
Re: B50 chain length? [Re: Andy Higham] #704567
08/10/17 10:00 pm
08/10/17 10:00 pm
Naarfuk, UK
Naarfuk, UK
Have you ever owned one and rebuilt one from scratch? I can assure you there is a lot more to a BSA/Triumph triple engine than that! But I'm not here to argue, so I'll say no more on the subject unless there's some point.
Re: B50 chain length? [Re: Tigernuts] #704606
08/11/17 10:22 am
08/11/17 10:22 am
BSA_WM20 Offline
BSA_WM20  Offline
Well according to the bigraphies of the designers of the time Andy is correct.
In fact they claim the prototypes were actually made by cutting up engines & joining them together .
The diagrams in the parts books were definately cut & paste Triumph parts books and if you need proof, have a very close look a the cam shaft or where the oil pump sits.
And yes production models had to be re-engineered a bit in order to make them almost reliable and to facility manufacture.
Without checking & I am sure those who love the 2 redundant cylinders will correct me if I am wrong, but Triumph was ready to put it ito production back in 63 but the board would not have a bar of it till Turner did his tour of Japan and realized the H4 was going to kill the USA big bike market.
HE may have been a garbage engineer but he was a good stylist and highly in tune with motorcycling trends.
In the days of desk top dynos we easily forget just how difficult it iwas to design an engine back in the slide rule days
If you look at the bore & stroke ratios you can see that BSA lucked it in with some good ones early on then kept reguritating them year in year out.
The A65 was the closest thing to a new engine that came out of Small Heath which actually worked.
Brand new designs all failed miserably
The scooter range
The Dandy
The Pixie
The Bandit /Fury
Re: B50 chain length? [Re: Tigernuts] #704607
08/11/17 10:28 am
08/11/17 10:28 am
Bolton Lancs UK
Bolton Lancs UK
The Bandit/Fury wasn't really a failure, it was stillborn. BSA/Triumph ran out of money before it could get off the ground
1962/67 Greeves 350
Re: B50 chain length? [Re: Tigernuts] #704662
08/11/17 8:40 pm
08/11/17 8:40 pm
Naarfuk, UK
Naarfuk, UK
OK, have it your way (from experience on this and other forums, I know how pointless it is to bother arguing - not sure why I;m wasting virtual ink typing this actually!). But if either of you have actually seen the insides of a T150/T160/A75 engine, well you wouldn't have written what you have. So obviously you haven't!
106 links is all I need to take away from this discussion, so thanks again to Jon.
Re: B50 chain length? [Re: Andy Higham] #704700
08/12/17 8:28 am
08/12/17 8:28 am
BSA_WM20 Offline
BSA_WM20  Offline
I have had a very long chat to the owner of a working one down here.
There was not much in the engine that actually worked properly he remade an aweful lot of bits to get the bike to run.
Had they gone into full production BSA would have been bankrupted by the warrany claims.
As mentioned earlier Turner was a brilliant stylist but a garbage engineer.
From memory the published reason was a delay in the sub standard Spanish electrics causing it to miss the USA selling season, but if that was true it would have been relaunched or sent down here where if they all blew up no one would ever know.
But BSA did not do that, they scrapped an entire model after building a production line for it assembling qute a few machines , tooling up to make parts and ordering in thousands of parts.
If you think tha BSA board would throw away all that money when they had captive markets like India, Hong Hong, New Zealand & Australia where they could dump disasters, you have the board very wrong.
All the engineers involved in the project had no faith in the machine, and they say so in their memoirs , money was getting tight and the board took a conservative approach and a massive up front loss.
As for seeing the insides of an A75, why do you think I specifically mentioned the oil pump and the difficulties in preventing it internally hemoraging ?
Don't own one because it is a Triumph in drag but have been inside one or two in my time.
