tombeau
tombeau
Finland
35 registered members (998John), 323 guests, and 389 spiders.
10291 Registered Users
Stuart 95
Lannis 66
Mori55 65
638,130 mail-order LSR
Topics67,397
Posts654,377
Members10,291
Transmission High Gear Bushing #704003
08/05/17 12:35 am
08/05/17 12:35 am
SoCal
Phil R Offline OP
Phil R  Offline OP
SoCal
While inspecting the high gear assembly on a 1970 TBolt I noticed that the bushing appeared cracked on the outer portion.
I pulled out another from a parts box & found it to be cracked as well.
After researching the problem I discovered that this bushing is of the split variety and that replacements are actually available, if needed.
But a new question arose when I discovered that the two bushings differed greatly in the distance that they extended from the end of the assembly (see photo).
Is there a prescribed amount for this distance or is it set up for each individual transmission? Any insights appreciated.
Phil
Re: Transmission High Gear Bushing [Re: Phil R] #704004
08/05/17 12:39 am
08/05/17 12:39 am
SoCal
Phil R Offline OP
Phil R  Offline OP
SoCal
Sorry, looks like there are still some things I don't understand about "Attachment Manager" !
Re: Transmission High Gear Bushing [Re: Phil R] #704023
08/05/17 8:13 am
08/05/17 8:13 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
if it helps any the one on the right looks correct. its possible the one on the left could have broken off as a groove gets worn there from the seal thats in the plate behind the clutch basket. i replaced a set of bushes in a '65 tears ago but ill be damned if i can remember what the spacing was. I WANT TO SAY (but not sure) that those bushes, and there two, press in til they but up to each other and the result is the correct protrusion. i DO remember they required a light reaming afterwords.
Re: Transmission High Gear Bushing [Re: Phil R] #704030
08/05/17 10:21 am
08/05/17 10:21 am
gavin eisler Online content
gavin eisler  Online Content
The bush needs to extend enough so that the oil seal in the primary case has something to run on, not critical , just long enough and a wee bit more.
When I replaced these bushes I had to ream them to get a running fit, used an expanding reamer.
Re: Transmission High Gear Bushing [Re: gavin eisler] #704090
08/06/17 3:14 am
08/06/17 3:14 am
SoCal
Phil R Offline OP
Phil R  Offline OP
SoCal
Jaycee, Gavin, Thanks for the input, that's just the information I was hoping to find.
Much appreciated!
Phil
Re: Transmission High Gear Bushing [Re: Phil R] #704096
08/06/17 7:34 am
08/06/17 7:34 am
Interesting, out of the 3 boxes I have the high gear bushes do not touch in the centre. Unless it's seriously worn I wouldn't bother.
Re: Transmission High Gear Bushing [Re: Allan Gill] #704134
08/06/17 4:10 pm
08/06/17 4:10 pm
SoCal
Phil R Offline OP
Phil R  Offline OP
SoCal
[quote= Unless it's seriously worn I wouldn't bother. [/quote]
I think we're both on the same page Allan.
Phil
Re: Transmission High Gear Bushing [Re: Phil R] #704162
08/06/17 10:14 pm
08/06/17 10:14 pm
bigt if the gap is big enough to leak a highly viscous gearbox oil then it is goosed
Re: Transmission High Gear Bushing [Re: Phil R] #704229
08/07/17 4:16 pm
08/07/17 4:16 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The high gear bush sticks out about 0.350" from the gear and no, the two do not meet in the centre.
Re: Transmission High Gear Bushing [Re: DMadigan] #704396
08/09/17 5:59 am
08/09/17 5:59 am
SoCal
Phil R Offline OP
Phil R  Offline OP
SoCal
Roger that info Dave, thanks much.
Neither of the two I have meet up in the center. If need be, I plan to adjust the gap just slightly so that the seal will run on an un-worn surface of the bush.
Phil
