meatwagon
meatwagon
San Diego CA
25 registered members (Alan_nc), 205 guests, and 461 spiders.
10291 Registered Users
Stuart 92
Lannis 66
Mori55 64
637,405 mail-order LSR
Topics67,385
Posts654,246
Members10,291
Ever see this happen to a carb? #703164
07/28/17 8:27 pm
07/28/17 8:27 pm
Cleveland, OH
TheInvisibleCity Offline OP
Cleveland, OH
This is a new-ish (maybe 6 or 7 years old) AMAL carb. Put in the Berrymans dip that I've always used - including on this exact carb before - and this is how it came out after about 15 minutes. Float bowl too. What the heck has happened? This carb was bright and new looking (minus the stale gas inside) prior to the dip. I've not seen this reaction before.
'69 A65T
'66 A65T
Late 60's Lightning Bitsa
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703173
07/28/17 10:20 pm
07/28/17 10:20 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
City, funny you should bring this up, as I had the same thing happen just a few days ago. I also was using Berryman dip on a AMAL Monobloc carb. The carb body and slide came out with a slimy grey coating, almost like the dip had started eating away the metal. It was only the magnesium alloy parts that were affected. All the brass or steel parts weren't affected at all. I have used this dip many times before on AMAL carbs and never had this happen. The grey slimy stuff wiped off easily and coated my hands; they as if I had been handling raw aluminum. I did leave the carb in the solution over the weekend; maybe that was the problem? Too long?
I cleaned up the carb, and got all of the grey residue removed, but I haven't tried the carb yet. I fear it may be ruined. Now too much clearance between the slide and the carb bore?
Fullminator
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703175
07/28/17 10:27 pm
07/28/17 10:27 pm
Irish Swede Offline
Irish Swede  Offline
Does "Berrymans Dip" contain phosphoric acid? Long contact with certain carb cleaners can have strange effects on some metal alloys.
A friend left a kickstand spring in "Metal Prep" phosphoric solution too long and it ate away most of the spring!
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703178
07/28/17 10:44 pm
07/28/17 10:44 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Similar thing, I have often used "Mr Muscle" oven cleaner to clean engines, Villiers engines come out nice and pristine aluminium looking. It even removes baked on "R" oil.
I used it on my B31 cases, they turned a charcoal grey colour. It must be a reaction between an active ingredient and one of the metals alloyed with the aluminium. In the case of the carb above it's mainly zinc
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Ever see this happen to a carb? [Re: Andy Higham] #703221
07/29/17 8:35 am
07/29/17 8:35 am
I used mr muscle on the underside of a bantam head (test section) and rubbed it with a scotchbrite pad. It got it clean but it also ate at the aluminium too.
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703222
07/29/17 8:47 am
07/29/17 8:47 am
Using the float bowel as the test piece try using citric acid to see if it clears the deposit, then try sulphuric acid from an old battery. AMAL did not seem to have a tight control on the alloy mix and it varies a lot giving these odd reactions.
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703355
07/30/17 5:45 pm
07/30/17 5:45 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Happened to me using Simple Green in an ultrasonic cleaner - it stripped the plating off
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703430
07/31/17 10:03 am
07/31/17 10:03 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
if i may hazard a guess it looks like what caustic soda does. but that said, many years ago i was fooling around with a caswell anodizing kit and got the same reaction. i called caswell and he politely told me that the easiest way to tell the difference between ALUMINUM and ZINC ALLOY (AMAL carbs) was that sulphuric acid turns zinc black and whitens aluminum. does berrymans react with baking soda?
Re: Ever see this happen to a carb? [Re: jaycee] #703625
08/01/17 10:19 pm
08/01/17 10:19 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
I looked at the Berryman dip can, it is mostly water at 40-55%, but it also contains heterocyclic amine derivatives at 15-20%, butoxyethoxy ethanol at 8-15%, butoxyethanol at 8-10%, and ethoxylated alkyl amines at 1-5%, whatever all that means. It has always cleaned carbs very well in the past. This is the first time it left me thinking I had seriously damaged something. My carb now looks like a zebra; stripes of grey and white, and a very flat, course surface appearance.
Fullminator.
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703685
08/02/17 3:56 pm
08/02/17 3:56 pm
Cleveland, OH
Cleveland, OH
I guess the next obvious question would be - is this just cosmetic damage or has material actually been removed from my carb making it useless? Also strange that it didn't have this reaction in the past.
'69 A65T
'66 A65T
Re: Ever see this happen to a carb? [Re: TheInvisibleCity] #703686
08/02/17 4:29 pm
08/02/17 4:29 pm
Using exactly the same method I have cleaned about 10 AMAL Concentric carbs recently, ultrasonic with a mild detergent, it worked well on all but one which went very dark and nearly as bad as yours. As the others cleaned up well with a couple looking like they were shop fresh I can only guess at the metals alloy not being consistent or an operation at the end such as a flash plate in zinc has been missed. Size wise the one bad one I have is not affected so will look ugly but perform properly.
