porge
porge
Tasmania, Australia
36 registered members (Andy Higham), 310 guests, and 456 spiders.
10294 Registered Users
Stuart 98
Lannis 68
Mori55 67
640,474 mail-order LSR
Topics67,422
Posts654,673
Members10,294
crank end float #703541
08/01/17 8:19 am
08/01/17 8:19 am
england
peter paul Offline OP
england
hi , I have a a10 1959 , the end float is 15 thou, can I still ride it or is it too far gone, will it do a lot of damage , it is a strip down of the engine I would like to avoid this as I am only a sunday morning rider your thoughts on this will be very welcome , thanks P P
Re: crank end float [Re: peter paul] #703542
08/01/17 9:01 am
08/01/17 9:01 am
15 thou end-float is fine, continue to enjoy Sunday mornings.
Re: crank end float [Re: kommando] #703544
08/01/17 9:06 am
08/01/17 9:06 am
england
england
many thanks commando . P P
Re: crank end float [Re: peter paul] #703587
08/01/17 5:58 pm
08/01/17 5:58 pm
Upstate NY
Red Lapierre Offline
Upstate NY
BSA Service Sheet 208 states that it should be on A10 Maximum float should be .005 in. Any error should be corrected with additional packing shims. Commando has more knowledge than I do, I'm just going by the book.
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: crank end float [Re: peter paul] #703629
08/01/17 10:49 pm
08/01/17 10:49 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi
Check the sump plate filter for any shim debris, if there is any then the engine needs attention immediately
There are dozens of similar topics on the A10 forum
Excess endfloat is usually caused by the cush drive nut not being properly torqued up allowing movement between
the crank and main bearing inner race, this chews up the shims wears the crank mainshaft and the drive splines
On one occasion I saw a rod failure due to excess endfloat, but this was a severe case
John,
