48 dingalinger
48 dingalinger
Victorville
35 registered members (998John), 325 guests, and 383 spiders.
10291 Registered Users
Stuart 95
Lannis 66
Mori55 65
638,130 mail-order LSR
Topics67,397
Posts654,377
Members10,291
Exhaust Temp? #703466
07/31/17 5:01 pm
07/31/17 5:01 pm
The land of pleasant living
Z
Zimm Offline OP
Zimm  Offline OP
Z
My 54 A10 has just past 1,000 on a rebuilt engine from a reputable builder. Runs great.
One oddity I noticed was that one exhaust pipe was more discolored than the other from heat. Applying my magic ray gun laser thermometer, I found that the left pipe was about 210 F and the right about 170F with the engine warmed up for about 5 minutes or so.
Anyone think of a reason for this? Is it something to be concerned about? Timing is right and plug color is actually darker than I would like, making me think its running a bit rich, not lean.
Zimm
Re: Exhaust Temp? [Re: Zimm] #703470
07/31/17 5:36 pm
07/31/17 5:36 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Those look like pretty meaningless numbers, 170F is only 76C and 210F is only 99C,
The exhaust gas temperature is usually in the range 600C - 800C (1100f - 1450F)
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Exhaust Temp? [Re: Zimm] #703488
07/31/17 8:39 pm
07/31/17 8:39 pm
Whitstable England
TT John Offline
TT John  Offline
Whitstable England
It's most likely the bias on the carb, I know at one time you could get a bias washer to fit between manifold & carb, if your carb has a 'O' ring try loosening one side & tightening up the other just to slew it round slightly..
Re: Exhaust Temp? [Re: TT John] #703494
07/31/17 9:05 pm
07/31/17 9:05 pm
Southampton UK
Peter Gascoigne Offline
Southampton UK
Adjust the height of the carb slides so that the temperature is about the same, and the engine is idling correctly.
1971 BSA A65 Lightning "Bitsa"
1966 BSA A65 "Beezuki" with GT550 two-stroke engine
1974 Triumph T150 830cc
1975 Suzuki GT550
1975 Laverda 1000 3C
1986 Yamaha SRX 600
Re: Exhaust Temp? [Re: Zimm] #703500
07/31/17 9:53 pm
07/31/17 9:53 pm
gavin eisler Online content
gavin eisler  Online Content
As you have found out, magic eye thermometers dont work on shiny surfaces, aim for the head casting beside the port for a more meaningful reading.
Might be subtle differences in ignition timing causing temp differences, or carb bias. A 54 A10 is a single carb, so adjusting slides plural isnt an option.
Re: Exhaust Temp? [Re: gavin eisler] #703706
08/02/17 6:57 pm
08/02/17 6:57 pm
Southampton UK
Southampton UK
You are right Gavin. I'm so used to two or three carbs, (even my SRX single lunger has two carbs), I'd forgotten there were bikes with only one carb!
1975 Suzuki GT550
1986 Yamaha SRX 600
