The Bonneville Shop
Shadrach
Shadrach
Maryland
39 registered members (Adam M.), 244 guests, and 440 spiders.
10528 Registered Users
franko 90
NickL 66
785,221 mail-order LSR
Topics69,221
Posts674,282
Members10,528
Open contact breaker points #702114
07/18/17 2:17 pm
07/18/17 2:17 pm
Louisiana, USA
IkeIke Offline OP
IkeIke  Offline OP
Louisiana, USA
I'm working on a CB34 GS935 and have a question on whether the points should show a closed circuit when they are open. I'm using a static timing light and it's showing a closed current when the points are open. Is this normal? It has been my experience that the circuit should be broke when the points are open or a piece of insulated material is place between the contacts. I suspect the points are shorted out. The spark plug will fire intermittently when I turn the engine over but will not start. Just a very loud backfire every now and then. The attached photo shows a piece of plastic shrink wrap between the points and the light showing a closed circuit. Any advice? Not sure if the photo will be accessible as I'm not familiar with how to add a picture to this post.
BSA Gold Star Points.JPG[img]http://i61.photobucket.com/albums/h...ar%20Points_zpsqppi0s23.jpg?t=1500300733[/img]
Re: Open contact breaker points [Re: IkeIke] #702119
07/18/17 3:56 pm
07/18/17 3:56 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Your experience is probably with a more common coil and points system. I doubt there is nothing wrong with your points. On a magneto, a continuity light across the points will remain on whether the points are open or closed. On my Velo and my Norton (K1F and K2F magnetos), the light will work if you remove the central screw. This is only accurate if there is a sufficiently tight fit on the taper that the position of the points plate won't be disturbed by removing the screw. You must remember to reinstall the screw when you are done-the bike won't fire without it.
Ed from NJ
Re: Open contact breaker points [Re: IkeIke] #702123
07/18/17 4:43 pm
07/18/17 4:43 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
All else being equal ,
You are simply tring to replace the .oo2 gap (cigarette paper) with a multimeter continuity test ?
I have read , probably somewhere on britbike , that removing the center fixing nut will allow a such a test .
Edit .... Opps , what Ed said ... first .
Re: Open contact breaker points [Re: quinten] #702657
07/24/17 7:08 pm
07/24/17 7:08 pm
Louisiana, USA
IkeIke Offline OP
IkeIke  Offline OP
Louisiana, USA
Thanks for the advice. I will try removing the center fixing nut. I that doesn't work, then I'll do the cigarette paper method. I'll keep you posted.
Re: Open contact breaker points [Re: IkeIke] #702658
07/24/17 7:12 pm
07/24/17 7:12 pm
Louisiana, USA
IkeIke Offline OP
IkeIke  Offline OP
Louisiana, USA
I assume the center fixing screw is the one at the opposite end from the individual contact points?
Re: Open contact breaker points [Re: IkeIke] #702664
07/24/17 7:58 pm
07/24/17 7:58 pm
Zero measured resistance across open magneto points is normal. The ohm-meter current is passing through the low tension windings, whoch have very low resistance. If you clip a low voltage battery and buzzer across the points, you might hear the tone change when the points open.
Re: Open contact breaker points [Re: IkeIke] #702666
07/24/17 8:10 pm
07/24/17 8:10 pm
What are you on about?
It's the hex head screw in the middle of this lot.
Re: Open contact breaker points [Re: IkeIke] #702926
07/26/17 11:49 pm
07/26/17 11:49 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi All,
TT
The MO1 mag has a face cam and the centre screw head is underneath the outer point contact
that has to be removed before accessing the centre screw
Ikelke,
An electronic magneto timer can be bought that detects the exact contact opening point,
several here
https://www.eBay.com/sch/i.html?_fr...S0&_nkw=magneto+timing+&_sacat=0
Re: Open contact breaker points [Re: chaterlea25] #703429
07/31/17 9:43 am
07/31/17 9:43 am
Blue Mountains, Sydney Austral...
geordie Offline
geordie  Offline
Anyone know what lurks inside the electronic mag timer? it might be possible to make one
58 goldstar
74 commando
70 Thunderbolt
81 Darmah
Re: Open contact breaker points [Re: geordie] #703448
07/31/17 2:07 pm
07/31/17 2:07 pm
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
BING oh! laughing
http://www.gasenginemagazine.com/Gas-Engines/Building-and-Using-a-Magneto-Timer
http://buzzzboxes.com/
CZ
