The Bonneville Shop
CaptainPugwash
CaptainPugwash
Conisbrough,Yorkshire, UK
22 registered members (Alan_nc), 200 guests, and 430 spiders.
10528 Registered Users
franko 90
NickL 66
785,121 mail-order LSR
Topics69,220
Posts674,261
Members10,528
Help with Lucas Magneto #699562
06/25/17 3:03 pm
06/25/17 3:03 pm
Germany
Gui d'Orey Offline OP
Germany
Hi chaps,
I've just spent a very frustrating weekend fighting with a magneto on my BSA 1930's Sloper. It's a MDB1 and it was actually working fine, but I decided to give it a clean and set timing which was a bit off.
After setting everything and testing it on the bench, turning it with a drill, I was happy to see a fat, healthy spark, and reassembled it on the bike. Only now there wasn't any spark anymore! After checking everything and not having found anything suspect, I took the magneto off the bike and tested it on the bench again. Again a fit big spark was there. I set it back on the machine, and before assembling the sprocket or tightening anything down, did the test again with the drill and still hat a good spark. But afer reassembling everything and setting the timing, I get no spark when I use the kickstarter, not even a weak one!
Anyone has any ideas what could be wrong or what to check? I'm at my witts end...
Any help would be greatly appreciated!
Gui
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699575
06/25/17 5:03 pm
06/25/17 5:03 pm
Germany
Germany
Well, I suppose I was attacked by gremlins today. The problem is solved, although I have no idea what was the cause and what actually solved it....
I pulled out the mag sprocket again and tried it with my drill once more. A nice big fat spark was there again! After scratching my head some more, there was nothing left to do , but to assemble the sprocket and try the kick starter. The spark was still there.... after closing the timing case, kicked her a few times and the old sloper was running again! Unfortunately due to the excitement I set the timing too early. When I advance the ignition, she starts spitting and at full advance the motor dies. So I'll have to reopen the case and set it properly....
Anyway I would still love to know what was wrong and why I wasn't getting a spark, so any ideas are still welcome. Hate these types of mysteries.
Gui
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699585
06/25/17 7:42 pm
06/25/17 7:42 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
This post could do with some photos.
Just saying.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699663
06/26/17 2:42 pm
06/26/17 2:42 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
I am sure that the drill is spinning your mag over a lot faster than your kick starter. The mag should spark just spinning it with your fingers. My guess is that your mag is operating somewhat marginally, and that the reason it is sparking now is because you are kicking it harder because you are frustrated, and thus spinning the motor faster.
Ed from NJ
Re: Help with Lucas Magneto [Re: edunham] #699673
06/26/17 4:36 pm
06/26/17 4:36 pm
Germany
Germany
Hi Ed,
Yes, that also occurred to me, but she now sparks with a slow easy kick. The mag is due for an overhaul, surely, but I was hoping to leave it for next winter, nad enjoy the rest of the riding season. Let's see how the old girl holds through.
I also set the points gap to 0,003" according to the BSA owner's manual, which is smaller than what was previously set to, and now she runs rougher. Probably another sign that something's not quite right...
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699681
06/26/17 5:19 pm
06/26/17 5:19 pm
Pacific northwest
quinten Online confused
quinten  Online Confused
Pacific northwest
knowing little about magnetos ... I would look into ... whether the final tightening down of the mag
is somehow pulling something out of alignment ?
gear lash or end float pushing on the points cam or brushes ... just far enough to cause mechanical binding or a short ?
... is the points cover causing a short ?
... or with the cover off , is the points-arm opening and closing normally ?
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699683
06/26/17 5:32 pm
06/26/17 5:32 pm
New Hampshier USA
MikeG Offline
MikeG  Offline
New Hampshier USA
Originally Posted by Gui d'Orey
Hi Ed,
They quote .003 thou for a point gap? hardly seems like enough, I have the K2f on my A10 at .012 I think
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
Re: Help with Lucas Magneto [Re: MikeG] #699710
06/26/17 8:55 pm
06/26/17 8:55 pm
Germany
Germany
Hi Ed,
Yup, it is indeed specified as 0.003" on two different versions of the BSA Mortor Cycle Instruction Book for 1930 Models smile
After further analysis, I moved my suspicions to the spark plug itself. If I take the cap off the HT Lead I always get a nice spark, but with the plug attached it is really sporadic. Unfortunately, it's an old 18mm plug which is not readily available, so I'll have to order one online and will take a few days until I can confirm if the plug is the culprit.
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699724
06/26/17 10:20 pm
06/26/17 10:20 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
0.003 in is definitely not correct
0.012in = 0.30mm is the correct gap at max opening
Maybe 0,003 is the max gap when the piston is at the firing point (cigarette paper thickness) ????
Re: Help with Lucas Magneto [Re: chaterlea25] #699795
06/27/17 12:50 pm
06/27/17 12:50 pm
New Hampshier USA
MikeG Offline
MikeG  Offline
New Hampshier USA
this makes more sense to me
1960 BSA A10
2007 Suzuki Bandit
1957 A10
71 Norton Commando
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699805
06/27/17 3:07 pm
06/27/17 3:07 pm
Magnetoman Online content
Magnetoman  Online Content
What's not right is you have the gap set much too low. Yes, I know you say that value is given in two different manuals, but even if it is given as 0.003", it's wrong.
The rough running you experience at this incorrectly-low gap is a direct consequence of a 19th Century discovery known as Paschen's Law. AC currents are much easier to interrupt than DC because the arc is quenched during half the cycle of the voltage oscillation during which time the contacts have moved far enough apart that the voltage is insufficient to restart the arc. Although it takes kV to initiate an an arc across the 0.020" gap of a plug, it takes less across a 0.003" gap.
According to Paschen's measurements it takes ~400 V to initiate an arc across a gap of 0.001", and this much voltage is present in the primary of the magneto. But, you say, your gap is 3x larger so there shouldn't be a problem. Even if there were no radial run out in the bearing (and with up to 0.005" end float allowed, there will be a similar amount of radial run out), setting the gap at 0.003" means it only opens at the "top" of the cam where the slope is minimal. Whereas with a proper gap of 0.012" the slope is ~0.002" per degree of rotation, at the "top" of the cam it is much less than this. This means that it takes many degrees of rotation of your armature before the points open to that 0.003" value. In the mean time the separation is much less than this and Paschen creates the rough running you experience by allowing arcing across the points which both alters the timing and dissipates much of the energy that no longer is available for the spark plug.
Again, even if you've read those manuals correctly, 0.003" is wrong. Set the points at 0.012"
Re: Help with Lucas Magneto [Re: chaterlea25] #699858
06/27/17 9:39 pm
06/27/17 9:39 pm
Germany
Germany
That does seem more correct. It's strange that BSA mentions it specifically, but then doesn't go on to specify the maximum gap. The "instruction book" is very basic and just gives a veeery general overview of the bike, not like a more modern manual. I suppose any rider in the 30's was expected to be mechanically fit. One of the best quotes in the book is something like this " ... the gearbox has three gears. They are there to be used, so do use them as the speed and load requires it."
Re: Help with Lucas Magneto [Re: Gui d'Orey] #699880
06/28/17 1:43 am
06/28/17 1:43 am
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
Musing along, the bicycle was one of the prime methods of wheeled transport back then, so the person supplying the power was well acquainted with the type and speed of the power required to keep going under various conditions. So it is probable that an astute someone who obtained a powered machine would apply a bit of what might be termed a mechanical version of anthropomorphism to the engine, and pick a gear that allowed it to operate in its "sweet spot'.
Just a thought. smile
CZ
Re: Help with Lucas Magneto [Re: Gui d'Orey] #702895
07/26/17 7:45 pm
07/26/17 7:45 pm
Germany
Germany
Hi everyone,
just an update on the issue. The problem is solved!
It was indeed a bad spark plug. After a few weeks hollidays, I got a new plug, and big,fat, happy sparks! The bike startet after a few kicks, and runs nicely again. It happens every time, doesn't it? we look at everything else, suspect big, complicated problems, and forget to check the simplest and obvious things?
Regarding the points gap, you were all right of course. The BSA manual do specify .003" just as the points open - the proverbial fag paper. Strangely enough, BSA never mentions what the gap should be when fully open. I dug out some old books on Lucas electrics for classic bikes, and took a look of some manuals I had for later BSAs and Ariels and the gap should be 0.012-0.015". It's been a while, nearly 20 yrs, since my last restoration, and my skills are rusty smile I should have spoted it right away.
Anyway, I'm very happy she is running again, and that there was nothing serious to ruin the rest of the riding season.
Thanks for all the inputs!
Gui
Re: Help with Lucas Magneto [Re: Gui d'Orey] #702908
07/26/17 9:30 pm
07/26/17 9:30 pm
Iowa
konon Offline
konon  Offline
Iowa
The .003 gap might be for setting the timing , as the points break open .
1968 BSA Firebird
1200 HD
XS 1100
1972 Rickman 125
