37 registered members (Alan_nc),
201
guests, and 215
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,569
Posts645,348
Members10,173
Most Online3,995 Feb 13th, 2017
Re: 1968 500 jammed kickstart
[Re: SEATTLE GS]
#702001
07/17/17 11:38 am
07/17/17 11:38 am
Posts: 267 Stamford
paulberry
Stamford
It should be fairly obvious what's jamming by inspecting the gears, selectors etc. Your'e going to have to go in there to fix it anyway.
Cheers Paul
1969 T100S 1955 Tiger Cub
[Re: SEATTLE GS]
#702146
07/18/17 9:39 pm
07/18/17 9:39 pm
Posts: 11,167 North Georgia, USA
RF Whatley
North Georgia, USA
There is no separate kick start quadrant on a T100, like there is an a 650/750. It's made onto the kickstart shaft. So I'm thinking you'll need the k/s shaft, the needle roller that goes inside the shaft (if not included), the k/s pawl, the 1/8" dia split cotter x 1" long (or longer), and maybe the k/s return stop plate. You'll need the 2 cover gaskets and some gear oil. I have never seen the first gear damaged from a sick k/s pawl. Since you have to go all the way inside the g/b, I'd also replace all the coil springs in the shifter mechanism and cam plate plunger if you don't know them to be less than 20 years old. Replacing the o-ring and seals on the gear shift and k/s shafts wouldn't be a bad idea either. If it's not the pawl causing the issue, then it's usually damage caused by allowing the k/s lever to fly back up. The T100 return stop boss is very small and often mushrooms or peens over in strange ways when owners watch too much West Coast Chopper.
Don't hide 'em, Ride 'em !!
RF Whatley Cornelia, GA
