bonnie john
bonnie john
sunshine coast, queensland, australia
208 registered members (57nortonmodel77), 2,349 guests, and 690 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,260 mail-order LSR
Topics66,021
Posts638,979
Members10,073
LED question #701134
07/08/17 6:41 pm
07/08/17 6:41 pm
Omaha, NE, USA
Paul Sammut Offline OP
Omaha, NE, USA
Hi all,
I fully admit complete ignorance about LEDs, apart from the great ability to emit light for less energy draw. Since I installed an Alton generator on my C Rapide, I felt it was time to switch to a 12 volt system. I ordered an LED circuit made specifically to fit inside the Miller "STOP" light receptacle and was about to install it when I noticed on the package a box checked "6 volts". Unfortunately, the company I bought it from appears to have folded - or at least the website (bulbsthatlast4ever.com) has disappeared. My question, therefore, is: will this light work in a 12 volt system? Will I rapidly destroy it? Does fitting a resistor in series make it suitable? Any other way I could make it work?
Thanks in advance,
Paul.
Paul
'74 Commando
'75 T160 Trident
'15 R1200 GS Adv
'51 Vincent Rapide
Re: LED question [Re: Paul Sammut] #701203
07/09/17 2:00 pm
07/09/17 2:00 pm
Omaha, NE, USA
Omaha, NE, USA
Thank you so much, Nick. I shall do that. Now to find a Radio Shack that still exists......
Paul
Paul
'74 Commando
'75 T160 Trident
'15 R1200 GS Adv
'51 Vincent Rapide
Re: LED question [Re: Paul Sammut] #701235
07/09/17 6:11 pm
07/09/17 6:11 pm
Pacific northwest
quinten Online confused
quinten  Online Confused
Pacific northwest
Originally Posted by NickL
The simple answer is yes, but,,,,,, it's best to measure the current the panel draws on 6 volts first.
Then you can calculate the value and power rating of the resistor.
Another way is to put a small zener in series with the existing setup 6.2 volt 5 watt will be fine in 99% of instances.
Cathode (bar marking across the plastic of the zener) must face positive supply. It can be in either line.
you would be able to get one at a Radio Shack etc. cost about $1.00
Nick
Running a resistor or zener , to drop 6 volts , does not appear to be very efficient
And Kind of defeats the point of using LEDs as a power saving strategy .
How about using 2 cheap buck converter boards , 99cents each , shipped from HK , instead ?
Before doing anything , Check the light- board , with your best glasses ,
for any specs or documentation that may be printed on it .
Re: LED question [Re: Paul Sammut] #702000
07/17/17 11:14 am
07/17/17 11:14 am
Gothenburg, Sweden
Morgan aka Admin Online happy
Ride safe today!
Morgan aka Admin  Online Happy
Ride safe today!
Gothenburg, Sweden
yes it would fit both 6v and 12 if i recall correct you alter this by switching a Connection.
I have one for L564 and one for a later A65 mod.
go back and check the instrucuction leaflet
BSAing you
Morgan Johansson
BritBike.com.
____________________
Morgan on Facebook | BritBike on Facebook | Twitter | Skype: "britbike.com" |
Join our BritBike MotorCycle Forum on Facebook
Page Time: 0.461s Queries: 15 (0.005s) Memory: 1.0086 MB (Peak: 1.1501 MB) Zlib disabled. Server Time: 2018-02-21 10:58:04 UTC
