nisse
nisse
sweden
21 registered members (blackrag), 164 guests, and 451 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,838 mail-order LSR
Topics67,150
Posts651,648
Members10,257
Cracked frame #701785
07/15/17 12:59 am
07/15/17 12:59 am
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
I was working on my '70 BSA this evening in the basement when I looked down and noticed a little bit of rust on the back side of the right down tube, just above the forward engine mount. There's a crack in the frame! Is this something that any competent welder can take care of? How screwed am I?
Josh
Re: Cracked frame [Re: JD] #701788
07/15/17 1:19 am
07/15/17 1:19 am
Rich B Offline
Rich B  Offline
Is the frame cracked or are you getting some rust bleed from the faint? BSA frames are pretty tough....
Re: Cracked frame [Re: JD] #701792
07/15/17 1:53 am
07/15/17 1:53 am
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
Hard to see in the photo, but definitely looks like a crack just above the weld bead.
Josh
Re: Cracked frame [Re: JD] #701840
07/15/17 3:58 pm
07/15/17 3:58 pm
California, US
Peter_Joe Offline
Peter_Joe  Offline
California, US
You need to make sure that the frame is indeed cracked. If it is you have a problem.The reason is that the engine mount lug is brazed to the frame and you can't weld anything that was previously brazed. So the fix would be to replace a section of frame tubing and then braze the engine mount lug back on.
One thing that I noticed is that the frame tube is waisted above the engine mount lug. Possibly crash bars or highway pegs were mounted to the frame tubes which could have stressed the frame causing the frame tube to crack.
Peter Joe
