Paul G80
Paul G80
Cambridgeshire UK
208 registered members (57nortonmodel77), 2,344 guests, and 690 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,260 mail-order LSR
Topics66,021
Posts638,979
Members10,073
1967 BSA A65 Timing Plug #701586
07/12/17 10:25 pm
07/12/17 10:25 pm
AZ - USA
qbeanie Offline OP
qbeanie  Offline OP
AZ - USA
Which way is the plug supposed to be inserted? The manual I was referencing says to use the 50 end not the 65 end. However, I just realized the workshop manual is for a 1966 model. Thanks.
Re: 1967 BSA A65 Timing Plug [Re: qbeanie] #701603
07/13/17 2:48 am
07/13/17 2:48 am
Mark Z Online content
Mark Z  Online Content
Sorry, not a direct answer; I've always used an Allen key and positioned it right in the center of the hole. But if one end or the other of the tool causes the timing mark on the rotor to line up with the needle in the primary case, and the other end does not, that would be a strong clue, provided the alternator rotor is OE and not damaged. I think you'll find that the difference will be very slight; there are only a couple of degrees of crank rotation between the top and the bottom of the timing slot inspection hole.
Re: 1967 BSA A65 Timing Plug [Re: qbeanie] #701608
07/13/17 4:37 am
07/13/17 4:37 am
BC Canada
Daryl D Offline
Daryl D  Offline
BC Canada
I have a 68 manual and it says to use A50 only on both sizes of engine . Daryl
Re: 1967 BSA A65 Timing Plug [Re: qbeanie] #701773
07/14/17 10:50 pm
07/14/17 10:50 pm
El Dorado, California
Roadwarrior Online content
Private Sponsor
Roadwarrior  Online Content
Private Sponsor
Interesting my manual has the A50 plug end at 34 degrees, and the A65 side at 37 degrees. It says " Insert the peg with the appropriate model number uppermost." 66 manual. I have not seen a 67 manual yet.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: 1967 BSA A65 Timing Plug [Re: qbeanie] #701783
07/15/17 12:53 am
07/15/17 12:53 am
When setting the static timing for a 45 year old motorcycle, it almost doesn't matter which side of the plug you use.
You are only getting the static timing in the ballpark so that the bike will start and you can then REset the timing two different ways:
1) With a strobe light.
2) By actually riding and testing the bike on the road.
The 1966 specifications really don't mean much in 2017. The gasoline you use is completely different. The combustion chamber is likely to have bits of carbon and coke or sharp spots that can cause preignition. You really need to take the bike out on the road and see how much advance it can stand in its current condition and with the kind of gasoline you burn.
People get all knotted up trying to set the timing EXACTLY PRECISELY ON THE DOT to the old spec, and then end up having to retard the timing 3 degrees or whatever so the thing won't "ping" going up a hill. Might as well go ahead and test it anyhow ..... !
Re: 1967 BSA A65 Timing Plug [Re: qbeanie] #701800
07/15/17 3:02 am
07/15/17 3:02 am
Private Sponsor
Private Sponsor
Mine is E.T. It has to be coordinated with the rotor pin. The pin is at 37.
70 Bonnie
56 Chevy
Page Time: 0.213s Queries: 15 (0.006s) Memory: 1.0250 MB (Peak: 1.1861 MB) Zlib disabled. Server Time: 2018-02-21 11:13:01 UTC
