Go2fer
Go2fer
39 registered members (Alan_nc), 197 guests, and 218 spiders.
10173 Registered Users
Lannis 93
reverb 82
Stuart 77
NickL 67
koan58 61
551,048 mail-order LSR
Topics66,569
Posts645,348
Members10,173
BSA b31 engine sprocket #701232
07/09/17 6:03 pm
07/09/17 6:03 pm
east yorkshire uk
stevenick Offline OP
east yorkshire uk
Hi, I have a b31 motor fitted into an m20 frame gearbox. , The other year I bored the engine out to 400 cc and fitted touring goldstar cams with an 19 engine sprocket.
I have just got the primary cover off and while I am in the I was wondering if a 21 engine sprocket would be a good idea . I have one .
The bike runs fine but it's high in the rev,s when on the open road . 55/60 mph
Re: BSA b31 engine sprocket [Re: stevenick] #701350
07/10/17 4:16 pm
07/10/17 4:16 pm
Germany
Josef2 Offline
Josef2  Offline
Germany
hi,
first you have to calculate the overall ratio.
Internal gear ratio for the top gear is always 1, as its a direct gear.
Engine/Clutch and Gear/Rear differs widely.
M20 had 19/43 and 18/42
or 18/43 and 19/42, depending on the year.
The overall ratio is the same = 43/19 * 42/18= 5,281
B31 had some 5,591, B33 had 5,003 and there are some hundred other ratios for B32/B34, sidecars, Gold Stars ..
So you have to calculate your current setting.
The you need the tyre diameter , an Avon 3,50-19 has 682 mm or 26,85 inch.
And the speed, for example 60 mph
The formula to calculate with mph is now
rpm= speed * ratio * 334,4 / diameter.
With ratio 5,281 its 60 * 5,281 * 334,4 / 26,85 = 3946 rpm - So your B31 runs with 3946 rpm at 60 mph in the top gear.
With ratio 5,0 its 60 * 5,0 * 334,4 / 26,85 = 3736 rpm
Josef
Re: BSA b31 engine sprocket [Re: Josef2] #701764
07/14/17 9:34 pm
07/14/17 9:34 pm
east yorkshire uk
east yorkshire uk
Thanks Josef, going to give it a try and see how it goes
Re: BSA b31 engine sprocket [Re: stevenick] #701838
07/15/17 3:22 pm
07/15/17 3:22 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
It's easy to get trapped into thinking higher gearing=more relaxed and better MPG.
Very often what it really means is at touring speeds you are constantly shifting between top and third, worse MPG because a wider throttle opening is required for a given speed and a slower top speed because the engine will not pull the gearing
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Page Time: 0.063s Queries: 15 (0.005s) Memory: 1.0027 MB (Peak: 1.1454 MB) Zlib disabled. Server Time: 2018-04-23 02:00:39 UTC
