Paul G80
Paul G80
Cambridgeshire UK
208 registered members (57nortonmodel77), 2,342 guests, and 690 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,260 mail-order LSR
Topics66,021
Posts638,979
Members10,073
3 spring clutch for A65 vs 4 spring #701212
07/09/17 3:15 pm
07/09/17 3:15 pm
Oregon
Dana_twin Offline OP
Oregon
Sorry is this has been covered before, but the 4 spring clutch on my 66 Hornet is knackered beyond all hope.
Assuming I could find a *complete* later type 3 spring, could I use that for a direct replacement of the earlier 4 spring type?
Re: 3 spring clutch for A65 vs 4 spring [Re: Dana_twin] #701252
07/09/17 8:24 pm
07/09/17 8:24 pm
Hailey,Id.
bsawood Online content
bsawood  Online Content
Hailey,Id.
I had the same thing going on with my 65 Rocket. Ed at EV Engineering put together a complete 3 spring clutch for me for a reasonable price and I added a new SRM alloy pressure plate. A world of difference, much lighter lever and I only get a false neutral if I'm being sloppy.
JW
Re: 3 spring clutch for A65 vs 4 spring [Re: Dana_twin] #701301
07/10/17 3:34 am
07/10/17 3:34 am
Mark Z Online content
Mark Z  Online Content
It works but you must replace the chainwheel along with the rest of the clutch. I'm assuming that's what JW means by "complete clutch".
Re: 3 spring clutch for A65 vs 4 spring [Re: Dana_twin] #701418
07/11/17 7:47 am
07/11/17 7:47 am
Mark Parker Online content
Mark Parker  Online Content
If the 4 spring centre is still good you can modify it to work with a 3 spring chain wheel, map make a nice 4 spring alloy pressure plate as well as the three. I use this set up with extra plates and 4 heavy springs to cope with the power of my 883 motor. So the 4 spring versions can be used to good effect when you need the extra clamping force.
Re: 3 spring clutch for A65 vs 4 spring [Re: Mark Z] #701471
07/11/17 6:28 pm
07/11/17 6:28 pm
Hailey,Id.
Hailey,Id.
I replaced everything. I ran around in circles with it for sometime,replacing the most worn out bits, but being 50 yrs. old it all had too much wear to really work as it should. A worn part has a tendency to bitch up a new part it comes in contact with. My hub center had too much wear also or I probably would have done something like Mark did.
Page Time: 0.439s Queries: 15 (0.010s) Memory: 1.0158 MB (Peak: 1.1676 MB) Zlib disabled. Server Time: 2018-02-21 11:10:49 UTC
