Paul G80
Paul G80
Cambridgeshire UK
208 registered members (57nortonmodel77), 2,344 guests, and 690 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,260 mail-order LSR
Topics66,021
Posts638,979
Members10,073
BSA A65 main bearing question (DS) #701126
07/08/17 5:32 pm
07/08/17 5:32 pm
Oregon
Dana_twin Offline OP
Oregon
My 1966 motor has the ball bearing on the crank drive side (67-1240) but I see the later engines (1967-68?) used the roller bearing 68-0625 so I can go ahead and just use 68-0625 instead? Anything else to note if making this change?
Re: BSA A65 main bearing question (DS) [Re: Dana_twin] #701153
07/08/17 10:51 pm
07/08/17 10:51 pm
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
You need to provide for the end float. The later engines had shims between the roller and crank with a bronze thrust bush on the timing side. I presume your cases do not have the feature for holding the thrust bearing?
A work around is to use an outside race captured roller with the single lip on the inside race then add a roller guide ring between the inner race and the engine sprocket. An NUP or NH bearing type
Re: BSA A65 main bearing question (DS) [Re: NickL] #701456
07/11/17 2:59 pm
07/11/17 2:59 pm
Originally Posted by NickL
The crank is different dimensionaly so fitting a roller race will involve making up spacers/shims to centre the crank in the cases and have a thrust surface on the timing side.
Problem with the NUP style bearings is they are only available as metric sizes so mean either machining the cases or the bearing.
For a street bike just fit another ball race, they are good for at least 30k miles. Save yourself all the work.
Completely agree, I reverted from the roller to the ball quite happily on my 68', and will do this again too.
Page Time: 0.703s Queries: 15 (0.018s) Memory: 0.9993 MB (Peak: 1.1272 MB) Zlib disabled. Server Time: 2018-02-21 11:12:38 UTC
