Go2fer
Go2fer
37 registered members (Alan_nc), 200 guests, and 217 spiders.
10173 Registered Users
Lannis 93
reverb 82
Stuart 77
NickL 67
koan58 61
551,048 mail-order LSR
Topics66,569
Posts645,348
Members10,173
Weird Shifting Issue #701123
07/08/17 4:55 pm
07/08/17 4:55 pm
Canada
LarryLebel Offline OP
Canada
My B44R has developed a weird shifting issue. Every once and awhile when going from 2 to 3 it finds a neutral but if I wait for a moment it clicks into gear. The shift feels completely normal. I know little to nothing about how the gear change mechanism works so its difficult to imagine what's happening.
Re: Weird Shifting Issue [Re: LarryLebel] #701124
07/08/17 5:13 pm
07/08/17 5:13 pm
triton thrasher Offline
It's normal for the dogs to occasionally meet square on, baulking the engagement of the next gear.
Keep steady pressure on the pedal until you have released the clutch lever.
Re: Weird Shifting Issue [Re: LarryLebel] #701125
07/08/17 5:14 pm
07/08/17 5:14 pm
Shingle Springs, California
Roadwarrior Offline
Roadwarrior  Offline
I think all of my bikes have that false neutral once in awile.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: Weird Shifting Issue [Re: LarryLebel] #701143
07/08/17 8:27 pm
07/08/17 8:27 pm
kommando Offline
kommando  Offline
I would be looking at the leaf spring in the back of the box, it could be at the point of breaking, the camplate can contact it and rub away half way up and then the spring breaks.
Re: Weird Shifting Issue [Re: kommando] #701257
07/09/17 8:43 pm
07/09/17 8:43 pm
Canada
Canada
I have boned up on the shift mechanism with the help of a parts catalog and 441rider (aka Steve Dale of Brit Gaskets) videos. I have been in 441rider's dingy shed come workshop so I understand why his videos look the way they do. I don't see anything in the shift mechanism or transmission that would cause the delay going into gear.
Re: Weird Shifting Issue [Re: LarryLebel] #701268
07/09/17 10:17 pm
07/09/17 10:17 pm
kommando Offline
kommando  Offline
If your quadrant is not moving enough to move the camplate fully to the next notch/gear a good leaf spring will compensate and force the camplate to move so it can engage in the next notch on the camplate completing the movement. As the leaf spring loses its springyness it can no longer move the camplate and you will get a neutral.
Re: Weird Shifting Issue [Re: kommando] #701306
07/10/17 4:44 am
07/10/17 4:44 am
Canada
Canada
I guess that's plausible but I would think the friction of the spring on the cam plate would stop the cam plate from moving at all unless helped along by the quadrant plunger. Its an intermittent problem that did not happen at all today on my 6.3 mile daily drive to Starbucks.
Re: Weird Shifting Issue [Re: LarryLebel] #701329
07/10/17 12:49 pm
07/10/17 12:49 pm
kommando Offline
kommando  Offline
I grind down the high spots on the camplate where the spring runs and then polish the surface to a shine, this stops the leaf spring contacting the camplate about 1/2 way up the spring and improves the feel of the gearchange, before I do this the angle of the camplate is quite steep into the notch and if you are within 1/4 the leaf spring could complete the change, surface on new camplates is rough from the pressing die but used ones can be very smooth. Just be a bit more forceful for now with the lever and add it to the list on next strip down.
Re: Weird Shifting Issue [Re: LarryLebel] #701391
07/10/17 11:23 pm
07/10/17 11:23 pm
Anchorage Alaska USA
Mitch Offline
Mitch  Offline
do you have the new style camplate marked 69 or the old style marked T? the new style also uses a different shifter fork. I believed that change was made to help eliminate the false neutral
Re: Weird Shifting Issue [Re: Mitch] #701403
07/11/17 2:07 am
07/11/17 2:07 am
Canada
Canada
I have no idea what's in it but other areas seem to be stock. Its a 67. I'll keep your comment in mind when and if I take it apart. When I bought the bike in 08 I had ideas of doing a restoration but I'm used to the patina now and unless something breaks I'll leave it alone.
Re: Weird Shifting Issue [Re: LarryLebel] #701404
07/11/17 2:11 am
07/11/17 2:11 am
Mark Z Offline
Mark Z  Offline
For what it's worth: I was having some shifting problems with my A65 the other day. It went directly from second to fourth, skipping third, then back down to second from fourth, again skipping third. I took it down to first and then back up through the gears. It found all four this time, but the next time I tried to downshift into third, it found neutral between fourth and third.
The problem, as indirect as it may seem, was that both my primary chain and final drive chain were loose. There was also no oil in the primary chain case, or at least none came out when I removed the drain screw. I had been checking the primary chain with my finger (engine not running of course!) - NG; you have to push it up and down with a screwdriver or the like. Brought it up to the 1/8"-1/4" free play, and added 140cc of ATF. I also lubricated and tightened the final chain.
Bottom line, after the adjustments, shifting is back to normal, snick-snick, smooth as silk.
Page Time: 0.060s Queries: 15 (0.005s) Memory: 1.0632 MB (Peak: 1.2617 MB) Zlib disabled. Server Time: 2018-04-23 01:53:05 UTC
