Go2fer
Go2fer
39 registered members (Alan_nc), 197 guests, and 218 spiders.
10173 Registered Users
Lannis 93
reverb 82
Stuart 77
NickL 67
koan58 61
551,048 mail-order LSR
Topics66,569
Posts645,348
Members10,173
Super Rocket Main Jet- what are you running?? #701028
07/07/17 1:03 pm
07/07/17 1:03 pm
Burlington VT
mikelucas Offline OP
Burlington VT
Currently my Super Rocket has a Concentric carb on it that runs and pulls very well. That carb has been on it since my dad bought it in 1977. But I'm feeling like getting a Monobloc and putting it back on the bike as it's the correct carb for the bike and it just looks nice to boot.
I've scoured the internet and only found a few suggestions, most of which go back to the early Roy Bacon, Eddie Dow, BSA bulletins etc. But like most people say it's going to be different with modern fuels. So I AM FULLY AWARE :-) that I will likely have to fine tune the main jet etc. But what I'm looking for is what are people "currently running" on their super rocket with modern fuels????
My goal is to order the carb with a main jet that is close to what most people are currently running with modern fuels and then order a few jets up and down so I can fine tune it from there.
Literature is showing anything from a 290-420 main jet and I know some of this has to do with the changes made to the engine and for some reason where the motor was shipped etc.
Yes every engine is a little different, no two engines are exactly alike. Here's what I have for a set-up currently
1958 Super Rocket
Later style alloy head with larger intake valves
357 Cam
Boyer ignition- (properly set-up and strobe timed)
I have access to high test non-ethanol fuel (not looking to start an ethanol thread here :-)
Standard factory style exhaust
air filter- with this new carb I was going to go with either the fully exposed cone or round style in chromed ring?
I plan on ordering the Monobloc 389 (1 5/32")
If there's something I missed here that's relevant let me know.
Can't wait to hear where people are having success, I'm sure there has to be a general range/average of what works well in this set-up with modern fuels.
So let's hear it, what's your jet size?? And/or anyone have any relevant trial and error stories?
Thanks in advance-Mike
Re: Super Rocket Main Jet- what are you running?? [Re: mikelucas] #701060
07/07/17 9:34 pm
07/07/17 9:34 pm
Upstate NY
Red Lapierre Offline
Upstate NY
Mike if I remember correctly
389/3732 (from Walridge)
Main 330
N Jet 106
Pilot 25
started with a 3 Throttle valve but changed to a 2.5
Needle position in middle.
Plugs have been a touch of black with some brown. Run great, starts easy. I went with manual advance not auto.
62 SR
40 over pistons
my BSA service sheet
Carb up to 59
Bore (in) 1 1/16
Main Jet 250
Throttle Valve 376/3.5
Needle Position 3
Needle Jet (in) .1065
Hope this helps
Red
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Super Rocket Main Jet- what are you running?? [Re: mikelucas] #701064
07/07/17 10:05 pm
07/07/17 10:05 pm
Burlington VT
Burlington VT
Thanks Red,
Exactly what I'm looking for, hoping for a few others to chime in so we can maybe get a thread that becomes a useful resource.
I'll be reporting back once the carb gets swapped out as well.
Re: Super Rocket Main Jet- what are you running?? [Re: mikelucas] #701455
07/11/17 2:23 pm
07/11/17 2:23 pm
I set my fathers SR to run with a 930, it ran best with a 290 main jet. I beleive the main jet would have been about 350 for the monoblock. However in the AMAL manual they had various specs, some as high as 390 and 410. Some closer to 330.
Fuel shouldn't make too much difference to the jetting. I've found on a stock bike that going leaner is a big difference and going richer gives no benefit. Fuel and how it combusts will effect timing, if you still have the manual advance you can figure this out when on the road for where its happiest.
Page Time: 0.058s Queries: 15 (0.004s) Memory: 1.0058 MB (Peak: 1.1408 MB) Zlib disabled. Server Time: 2018-04-23 01:54:08 UTC
