BSA-KC
BSA-KC
Dallas, TX
32 registered members (AngloBike), 243 guests, and 460 spiders.
philliplye, Will K, jachenbach, EarniesT100R, Chad bowles
10214 Registered Users
Lannis 107
Stuart 106
reverb 70
578,704 mail-order LSR
Topics66,819
Posts648,007
Members10,214
Locating transmission drain plug on B25 #698925
06/18/17 4:31 pm
06/18/17 4:31 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Just having a little trouble identifying the plug on my 1970 B25. Is it the big screw under the top fill plug, that's rather flat looking? And if so, what's the easiest way to remove it? It looks tight under there!
Thanks!!
Alex
Last edited by Alexp; 06/18/17 4:57 pm. Reason: Unable to walk and spell at the same time!
Re: Locating transmission drain plug on B25 [Re: Alexp] #698928
06/18/17 4:55 pm
06/18/17 4:55 pm
Its the hole at the top rear above the long single stud for the oil feed block in this pic, use a good fitting socket (whitworth most likely even in 70) on the drain plug head
Re: Locating transmission drain plug on B25 [Re: Alexp] #698941
06/18/17 6:14 pm
06/18/17 6:14 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Amazing! I thought that was it! Just absolutely wanted to be sure!! Thanks Kommando!!
