BSA-KC
BSA-KC
Dallas, TX
32 registered members (AngloBike), 252 guests, and 460 spiders.
philliplye, Will K, jachenbach, EarniesT100R, Chad bowles
10214 Registered Users
Lannis 107
Stuart 106
reverb 70
578,704 mail-order LSR
Topics66,819
Posts648,007
Members10,214
Widest tires on a Trailblazer #698280
06/12/17 11:41 pm
06/12/17 11:41 pm
Trenton, New Jersey
royaloilfield Offline OP
Trenton, New Jersey
What is the widest tire that can fit on a trailblazer short swingarm? I just bought the suggested 4.00 dunlop, but it looks too small with the big valanced fenders. I have a 120 shinko on the rear, but it fouls the chainguard!!! Any suggestions??? thanks BRian
Brian
Re: Widest tires on a Trailblazer [Re: royaloilfield] #698458
06/14/17 3:10 pm
06/14/17 3:10 pm
Stuart Offline
Stuart  Offline
Hi Brian,
Originally Posted by royaloilfield
4.00 dunlop,
120 shinko
'Fraid these are about as useful as a chocolate fireguard. frown Which "4.00 dunlop"? K70? Which "120 shinko" - 120/90x18?
Re: Widest tires on a Trailblazer [Re: royaloilfield] #698488
06/14/17 8:37 pm
06/14/17 8:37 pm
Trenton, New Jersey
Trenton, New Jersey
Yes..a k70..4.00 is what the Indian manual calls for. The shinko is 120/90x18 and just fits with chaingaurd off. Brian...just wondering what everyone else is using. Thanks brian
Brian
Re: Widest tires on a Trailblazer [Re: royaloilfield] #698670
06/16/17 9:26 am
06/16/17 9:26 am
Stuart Offline
Stuart  Offline
Hi Brian,
Risking telling you something you know already, the "4.00" and "120" are 'section widths', not overall widths. And, perhaps curiously,the same 'section width' from a different tyre maker can be wider or narrower overall (but not by much).
The 4.00x18 K70 is 4.17" wide overall. Otoh, 4.00x18 tyres in modern designs like the Avon Roadrider, Bridgestone Battleax, etc. are around 1/2" wider (e.g. the Roadrider is 4.6" wide overall). However assuming the Shinko 120/90x18 is the 230 Tourmaster(?), Shinko reckons that's 4.8" wide overall, so not a lot of difference.
Btw, one thing to bear in mind with 120-width tyres is makers don't usually recommend 'em on the old British rim widths. Trailblazer's rear rim is WM3? If so, that's equivalent to modern "2.15"; 120's are normally recommended on a 2.75-width (WM4.5 equivalent) rim and not narrower than 2.50 (WM4 equivalent).
Obviously, a 120-width tyre can be fitted physically on a WM3/2.15 rim but how the carcase bends varies between tyres from different makers - e.g. I know a 120/90x18 Roadrider enlarges the overall diameter! confused
Otoh, while a 2.50-width (WM4 equivalent) rim is normally recommended for a 4.00x18 tyre, minimum is 2.15 (WM3 equivalent). bigt
Re: Widest tires on a Trailblazer [Re: royaloilfield] #698824
06/17/17 5:24 pm
06/17/17 5:24 pm
Trenton, New Jersey
Trenton, New Jersey
Stuart,
Thanks for the info! I decided just to put the K70 on and be done with it. TIme to get it on the road and put some miles down! Brian
Brian
