wolvertone
wolvertone
Denham Springs, Louisiana
35 registered members (998John), 284 guests, and 393 spiders.
BSADon, VH5150, okieboss02, philliplye, Will K
10217 Registered Users
Stuart 108
Lannis 106
reverb 67
L.A.B. 57
579,756 mail-order LSR
Topics66,834
Posts648,164
Members10,217
A65 ignition wiring help please #698784
06/17/17 10:59 am
06/17/17 10:59 am
WALES
H
hopski Offline OP
hopski  Offline OP
H
WALES
Hi guys, I'm rebuilding a 1969 A65T from basically a box of parts. I've got the engine in the rolling chassis at last and about to start the wiring. I thought I had everything I needed until I looked at the A65 parts book (1969) and saw there is a small capacitor unit in the ignition circuit, basically looks like two capacitors attached to a base and enclosed by a rubber cover and sits on the frame under the seat.
I don't have this and can't find one anywhere. Is there a modern work around? and what does it do?
thanks in advance guys.
ps my mates 1967 A65L doesn't have one although he has Boyer electronic ignition.
BSAOC South West Wales Member
Re: A65 ignition wiring help please [Re: hopski] #698785
06/17/17 11:18 am
06/17/17 11:18 am
BSA_WM20 Offline
BSA_WM20  Offline
They are the ignition caps used for the points.
Took BSA a while to understand that a hot shakey oily place is not a good spot to locate a cap.
If you have fitted an elactronic ignition they are no longer required.
If you are still running points they are required.
Ask and I am sure there will be some one close to you with one sitting in a box since they fited their Boyer/ pazon/ etc.
Re: A65 ignition wiring help please [Re: hopski] #698786
06/17/17 11:23 am
06/17/17 11:23 am
Whitstable England
TT John Offline
TT John  Offline
Whitstable England
The two capacitors are mounted in a rubber cover and are connected to the + side of each coil and one also goes to +, so you have four wires from the + side of the coil, one each to the caps the other two down to earth.
Hope this helps TTJohn
Re: A65 ignition wiring help please [Re: hopski] #698787
06/17/17 11:23 am
06/17/17 11:23 am
kommando Offline
kommando  Offline
It will be similar to the one used on the Commando
https://andover-norton.co.uk/en/shop-drawing/13/basic-electrical-components
Inside are the 2 condensers for the points, so you only need them if you are staying with points, fit IE and they are redundant.
As you can see only the condensers seem to be available, the mounting plate 40 and the rubber cover 39 will only be NOS or used.
http://www.eBay.co.uk/itm/Lucas-CONDENSORS-TWIN-PACK-/201956062288?hash=item2f0584f450:g:9pIAAOxy4fVS~48Y
Re: A65 ignition wiring help please [Re: hopski] #698800
06/17/17 1:30 pm
06/17/17 1:30 pm
Mark Z Offline
Mark Z  Offline
On '68-'70 A65, the condenser two-pack is mounted to a flat frame piece that runs diagonally across over the oil tank, under the seat.
There are only two wires to the condenser pack, one from each coil (+). They are grounded to the frame through the mounting bracket.
I think these condenser two-packs are available SOMEwhere, at least on this side of the pond. Right, you don't need them if you have electronic ignition. You may want to consider that, espectially if your auto advance unit and/or breaker assembly is not in good shape. Replacing those parts can be more expensive than installing an EI.
Re: A65 ignition wiring help please [Re: Mark Z] #698809
06/17/17 3:04 pm
06/17/17 3:04 pm
WALES
H
hopski Offline OP
hopski  Offline OP
H
WALES
Wow, great information guys. Now I know they are condensers I can do another search. Also thanks for the info on correct way to connect to the coils. As you can tell I'm an A10 guy and not used to fancy electrics, give me a magneto any day.
