BSA-KC
BSA-KC
Dallas, TX
32 registered members (AngloBike), 252 guests, and 460 spiders.
philliplye, Will K, jachenbach, EarniesT100R, Chad bowles
10214 Registered Users
Lannis 107
Stuart 106
reverb 70
578,704 mail-order LSR
Topics66,819
Posts648,007
Members10,214
trouble removing rear wheel from 56 hs frame #697952
06/09/17 4:35 pm
06/09/17 4:35 pm
superior, wi
actriumph Offline OP
superior, wi
hello feeling dumb , but had trouble removing ariel hs rear wheel. appears to have quick detach rear hub, bolt unthreads from right, like a bsa. But, sprocket carrier does not separate from hub . right axle removed, brake plate to thick due to room in swinging arm to pull out. What am I missing ? book has no exploded views thanks in advance
Al
alan r Cirilli
Re: trouble removing rear wheel from 56 hs frame [Re: actriumph] #697988
06/09/17 10:18 pm
06/09/17 10:18 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Are there 4 "dome" type nuts on the sprocket?
these need to be removed to split the wheel
Re: trouble removing rear wheel from 56 hs frame [Re: actriumph] #697989
06/09/17 10:22 pm
06/09/17 10:22 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Re: trouble removing rear wheel from 56 hs frame [Re: chaterlea25] #698339
06/13/17 3:59 pm
06/13/17 3:59 pm
superior, wi
superior, wi
thanks john, this popped into my head the other night in bed, it is similar to a bsa qd thank for your again Al
alan r Cirilli
