BSA-KC
BSA-KC
Dallas, TX
32 registered members (AngloBike), 243 guests, and 460 spiders.
philliplye, Will K, jachenbach, EarniesT100R, Chad bowles
10214 Registered Users
Lannis 107
Stuart 106
reverb 70
578,704 mail-order LSR
Topics66,819
Posts648,007
Members10,214
No spark ET B44 Victor #698251
06/12/17 7:08 pm
06/12/17 7:08 pm
NYC & Upstate NY
AML Offline OP
AML  Offline OP
NYC & Upstate NY
I just replaced the springs on the AAU, and when retiming the points got unusual inductance readings on the LCR meter. It showed 0.002 to 1 when the points opened instead of 0 to about 6+. And no spark showing on my in-line tester.
The bike ran last weekend and the only thing I removed was the advance unit and points plate, and I unplugged the points wire to check for continuity between the ends of the wire.
The few wires in the harness are all snug and correct.
Any ideas as to what I should be checking?
Adam
Re: No spark ET B44 Victor [Re: AML] #698253
06/12/17 7:14 pm
06/12/17 7:14 pm
Magnetoman Offline
Magnetoman  Offline
Start here and follow the steps forward from that point.
Re: No spark ET B44 Victor [Re: AML] #698255
06/12/17 7:18 pm
06/12/17 7:18 pm
John Healy Offline
John Healy  Offline
You didn't have to catch the part number on the points you used? Is it 54419827 by chance. If so on which side of the small plastic insulator that fits in the small loop at the end of the spring did you put the connector for the points wire/ If you out it between the nut and washer and the plastic insulator you grounded the points wire. The terminal goes between the insulator and the point's spring.
Re: No spark ET B44 Victor [Re: John Healy] #698257
06/12/17 7:34 pm
06/12/17 7:34 pm
NYC & Upstate NY
AML Offline OP
AML  Offline OP
NYC & Upstate NY
Thank MM and John. The bikes back in the shed and I don't even have to look. But Duh, and Yes I installed the points wire above the plastic insulator, not below.
Thanks to both of you again for such a quick reply.
Adam
Re: No spark ET B44 Victor [Re: AML] #699294
06/21/17 9:11 pm
06/21/17 9:11 pm
Shingle Springs, California
Roadwarrior Offline
Roadwarrior  Offline
Don't feel too duh, we have all done that.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
