25 registered members (Alan_nc),
208
guests, and 405
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,537
Posts644,984
Members10,169
Most Online3,995 Feb 13th, 2017
Re: '55 Triton Cafe Racer
[Re: Bry]
#688867
03/21/17 4:04 pm
03/21/17 4:04 pm
Posts: 3 Fremantle, West Aus
Adrian1983
Fremantle, West Aus
Hey Bry,
First off, absolutely amazing work!
I have a question I was wondering/hoping if you could help me with; I tried sending you a PM, but for some reason it's not working for me.
I'm currently in the process of restoring a '51 Wideline Triton and I'm going to be putting some Ceriani GP35 forks on her and the guy making them needs the dimensions for the stem - but I'll be stuffed if I can find that info anywhere.. Would you mind terribly helping me with this?
Cheers, Adrian.
Two bike's, both in pieces;
- '51 Wideline Triton w/ '61 pre-unit 650 - '50 Triumph 6T
[Re: Bry]
#697394
06/04/17 7:45 pm
06/04/17 7:45 pm
Posts: 7,290 scotland
triton thrasher
Where can I buy good files from these days?
[Re: Bry]
#697511
06/05/17 6:05 pm
06/05/17 6:05 pm
triton thrasher
Thanks.
What holds those drilled plates onto the silencers?
[Re: Bry]
#697871
06/08/17 10:22 pm
06/08/17 10:22 pm
triton thrasher
Ok- unless your Triton vibrates a lot less than mine, look out for those slotted attachments cracking and falling apart.
You may be able to avert that by mounting them with rubber in there somewhere.
[Re: Bry]
#698074
06/10/17 8:14 pm
06/10/17 8:14 pm
triton thrasher
I have two rubber bobbins on each silencer, so the exhaust doesn't drop off when the rubber inevitably eventually fails.
[Re: Bry]
#698142
06/11/17 3:23 pm
06/11/17 3:23 pm
Posts: 9,224 Scotland
kommando
The ones in the photo are Commando rear oil tank fittings and they are prone to failure as the tank is not supported very well, I have replaced them with old Mini exhaust rubber mounts which I also use to support the silencers on my Commando but not with a 6mm thread on one end, 5/16 on both ends. There are waisted ![[Linked Image]](https://www.clampcouk.co.uk/media/catalog/product/cache/1/image/300x/9df78eab33525d08d6e5fb8d27136e95/e/s/esm1_1.jpg) and unwaisted versions ![[Linked Image]](https://www.clampcouk.co.uk/media/catalog/product/cache/1/image/300x/9df78eab33525d08d6e5fb8d27136e95/e/s/esm15.jpg) there are chinese knockoffs with 8mm threads. All these bobbins suffer from being weak in shear and one of the ends eventually loses the fight to grip the rubber, so the waisted version is not more failure prone.
[Re: triton thrasher]
#698164
06/11/17 6:42 pm
06/11/17 6:42 pm
Posts: 293 Scotland
Bry
Thanks, as I need to be able to screw these into the captivated nuts in the slotted channel on the silencer, I have ordered a set of these ( http://www.avindustrialproducts.co.uk/documents/Page%209.%20Hex-Bemag%20Bobbins.pdf) with hex end plates to get a spanner on. The manufacturer does give a shear rating for these, but we'll see how long a service life they have. How often do you need to replace the ones on your Norton? Thanks a lot for posting the pictures triton thrasher, that helps a lot. I should be able to have a similar arrangement with 2 bobbins per silencer. Are these the only exhaust supports that you have, other than the connection at the head?
1946 Velocette MSS 1955 Triton (project) 1959 Velocette Venom 1966 Triumph T120
[Re: Bry]
#698175
06/11/17 8:29 pm
06/11/17 8:29 pm
triton thrasher
Yes they're only held there and at the head. I don't clamp the pipes onto the head stubs very tightly, since cracks have occurred at that end too.
There are car engine mounting rubber bobbins in existence, that are much stronger. Some day, some day I'll fix it right..... or maybe I'll just run out of days.
[Re: Bry]
#698201
06/12/17 2:31 am
06/12/17 2:31 am
Posts: 21 Southern Ontario, Canada
johnod
You have through bolts on the oil tank?
1969 Royal Enfield Interceptor 1982 Suzuki Katana 1100 1996 Buell S2T Thunderbolt 1997 Harley Ultra Classic 2002 BMW K1200RS Triton project, mainly boxes of stuff.
