BSA-KC
BSA-KC
Dallas, TX
32 registered members (AngloBike), 243 guests, and 460 spiders.
philliplye, Will K, jachenbach, EarniesT100R, Chad bowles
10214 Registered Users
Lannis 107
Stuart 106
reverb 70
578,704 mail-order LSR
Topics66,819
Posts648,007
Members10,214
1960 A10 Super Rocket Seat #698159
06/11/17 6:15 pm
06/11/17 6:15 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
Can anyone send me a picture of the bottom of an original 1960 / 62 A10 seat? I have a new reproduction seat that will not mount in the rear using the original rear brackets. If I make longer brackets, the seat will sit up to high. I also have a problem with the description Bacon gives in his restoration guide saying "the two-level aspect became more accentuated". Isn't this incorrect? I thought the '60-'62 seat was flatter. Can anyone advise me on this. This repro seat is fairly flat in the rear - shouldn't if be indented to follow the top curve of the fender?
Sam
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #698177
06/11/17 8:37 pm
06/11/17 8:37 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi Sam,
What brand is the seat?
Most are wrong shape and poorly made / fitting
The best seats I have seen are made by RK Leighton in UK
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #698180
06/11/17 8:59 pm
06/11/17 8:59 pm
The early seats were thicker under the riders bum, or rather the base followed the frame and the mudguard shape. The rear bracket was a one piece that bolted to the top of the mudguard.
The later type was flatter, and the mounting was 2x L shaped tabs which bolted to the side of the mudguard.
I can't see why you can't use an earlier seat on a later frame or vise Versa as long as you match the brackets to the correct seat...
One thing to note however is I have seen these mudguards fitted without the rubbers between the guard and the bracket, or the wrong thickness used. But therear guard is often cocked up too high, this would also stop the seat mounting correctly.
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #698342
06/13/17 4:53 pm
06/13/17 4:53 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
The seat I purchased is a P&P. It definitely doesn't fit. I just ordered a Leighton seat after seeing a picture of the base. I hope I don't bleed to bad on it.
Thanks for the replys.
Sam
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #698359
06/13/17 7:32 pm
06/13/17 7:32 pm
Royal Berkshire.
Kev. Offline
Kev.  Offline
Royal Berkshire.
Here is a genuine seat on my Super Rocket...
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #698386
06/13/17 10:06 pm
06/13/17 10:06 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Do not forget to fit the rubber supports that go under the mid seat area
They fit into the vertically threaded frame holes
Re: 1960 A10 Super Rocket Seat [Re: chaterlea25] #699499
06/24/17 2:30 pm
06/24/17 2:30 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
Kev - thanks for the pictures. I bent way over and bought a Leighton seat - it fits perfectly. I do have a few questions though - what are the two extra holes for behind the rear mounts?
Also ls the handrail an accessory or was it stock on all bikes? The parts book list the handrail on the same accessories page with the crash bars and carrier. Yours is the 2nd bike I've seen with this rear bar on it.
Another problem has popped up concerning the pipes and mufflers. The right muffler has to be 1/2" closer to the rear rim than the left to clear the kick starter (by about 3/16th "). It looks bad to me - is this standard British B/S?
John - I'm on it about the two seat rubbers above the vertically threaded holes in the frame. What about the hole towards the rear of the seat pan - is there a rubber that fits in this rear center hold in the seat base to help support the passenger portion of the seat?
Many thanks for your reply's
Sam
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #699518
06/24/17 6:54 pm
06/24/17 6:54 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi Sam,
The second set of mounting holes are I believe to suit different mudguards that were in use on the different models that used the same seat
I have not seen a rubber at the rear of the seat but it may help ?? Depends on the size of the pillion rider ??
I have used rubber doorstops for the seat supports when I could not find the proper ones !!
5/16 x 26 set bolts and penny washer locked up to the bolt head with a nut, and a second nut locking the bolt at the frame end
Drill or carve a hole in the rubber for the bolt head and glue on
The exhausts seem to vary a lot, also kickstarts have different cranks in them
You do what you have to to get by!!!
Re: 1960 A10 Super Rocket Seat [Re: Samsmc1] #699531
06/24/17 10:02 pm
06/24/17 10:02 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
The second set of mounting holes are for the RGS.
The grab rail seems to have been pretty well standard on U.S. models along with the short rear guard.
Re: 1960 A10 Super Rocket Seat [Re: Kev.] #700414
07/02/17 1:47 am
07/02/17 1:47 am
Hey Kev,
Might I request a better pic of the grab rail? I might have one...
And no, I've had a number of A-10's, but I only had one that came with one... And most of the fenders did not have the holes to mount a grab rail.
Re: 1960 A10 Super Rocket Seat [Re: Rickman] #700939
07/06/17 6:18 pm
07/06/17 6:18 pm
Royal Berkshire.
Kev. Offline
Kev.  Offline
Royal Berkshire.
Originally Posted by Rickman
Hey Kev,
Bike is in Georgia, so I can only show you what I have on my PC....
Of course if someone fancies buying the bike I could be persuaded
1952 Norton Special
Re: 1960 A10 Super Rocket Seat [Re: Kev.] #700989
07/06/17 11:25 pm
07/06/17 11:25 pm
Thanks Kev.
Yep, I think that is the one I have...
And not a single fender to bolt it to... Without drilling more holes...
Brett
