The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
B44 strobe timing #697184
06/02/17 7:22 pm
06/02/17 7:22 pm
NYC & Upstate NY
AML Online content OP
AML  Online Content OP
NYC & Upstate NY
Since I started messing around with my carb, I thought I should recheck valve clearances and timing before I went any further.
Valve clearances and static timing were aok, but when I put the strobe on the rotor it did not advance with revs at all against the pointer.
The aau is loose on itself so I'm not sure what's up.
It idles well and otherwise seems ok, what do I know. It's has ET if that makes any difference.
Could it be that the springs are so loose that it's going full advanced at idle? How can I tell if the springs are ok?
Adam
Re: B44 strobe timing [Re: AML] #697185
06/02/17 7:28 pm
06/02/17 7:28 pm
The ET only gives 5 degrees of advance at the cam and 10 at the crank, coil ignition B44's have 12 at the cam and 24 at the crank, suspect you are right in thinking its going fully advanced at idle. I never check the springs but fit stronger ones but there is a lot of slack potential in a worn AAU and even strong springs may struggle to stop it advancing on an ET AAU.
Re: B44 strobe timing [Re: kommando] #697204
06/03/17 12:34 am
06/03/17 12:34 am
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
I went through a few ignition iterations on my B44R to get it to run properly. I recommend you get rid of the points and AAU. Install an EI.
Re: B44 strobe timing [Re: AML] #697233
06/03/17 11:17 am
06/03/17 11:17 am
Nor Cal near Sutters mill.
Roadwarrior Offline
Roadwarrior  Offline
No. This is an ETS bike.
The shrieking of nothing is killing
Re: B44 strobe timing [Re: AML] #697353
06/04/17 1:53 pm
06/04/17 1:53 pm
NYC & Upstate NY
NYC & Upstate NY
The springs seem a little stretched and loose so NOS Lucas "strong" springs have been ordered and will be on the way.
There's no slop at all between the AAU center and the post on the plate, so I hope the springs will do it.
