jim schmidt
jim schmidt
Sanger, CA
31 registered members (Alan_nc), 228 guests, and 447 spiders.
10257 Registered Users
Stuart 75
Lannis 55
TBolt72 47
610,901 mail-order LSR
Topics67,152
Posts651,660
Members10,257
A65 Oil Tank Mounting Hardware Help Needed #694325
05/07/17 11:52 pm
05/07/17 11:52 pm
Jon W. Whitley Online content OP
Jon W. Whitley  Online Content OP
I need to know how the spacer ( 68-8317 ) and the Rubber ( 68-8334 ) for the upper oil tank mount are correctly assembled ? I would have thought that the spacer fit into the rubber but the hole in the rubber is not large enough. Also, in which direction does the rubber face and is it between the frame and the mounting tab ? So, before I potentially destroy it, I thought I would ask bigt
The parts are numbers 2 and 3 in the parts diagram. And, this is for my 1970 A65F.
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694449
05/08/17 7:13 pm
05/08/17 7:13 pm
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
Its a simple rubber grommet and spacer. You may be able to find the grommet in the Help section of an auto parts store and make the spacer out of some aluminum tube stock
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Richard Phillips] #694459
05/08/17 8:59 pm
05/08/17 8:59 pm
Thanks, but I have the new parts on hand already. I need to know the correct way to mount them, like does the spacer fit through the rubber grommet and is the grommet sandwiched between the frame tube and the oil tank mounting bracket ? Pictures would be great too.
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694508
05/09/17 3:14 am
05/09/17 3:14 am
Mark Z Offline
Mark Z  Offline
I know this isn't much of an answer, but I could never figure out how the stock setup was supposed to isolate the oil tank from both the frame and the bolt, so I re-engineered the mount. I think it went something like this: Bolt head, metal washer and rubber washer big enough to span the hole in the oil tank, generic rubber bushing in the hole (no spacer), rubber washer between oil tank and frame, metal washer and nut on the other side of the frame. Nylok nut to maintain adequate tension without destroying the rubber washers. Put on many miles with this setup with no ill effects.
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694511
05/09/17 4:16 am
05/09/17 4:16 am
Shingle Springs, California
Roadwarrior Offline
Roadwarrior  Offline
That's the way I did mine. Just guessed
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694537
05/09/17 12:52 pm
05/09/17 12:52 pm
West Virginia, United States
Beach Offline
Beach  Offline
I remember having questions about the correct placement of these parts on my bike too and found an undisturbed original bike...I will take some pics of it after bit...
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694544
05/09/17 1:53 pm
05/09/17 1:53 pm
Beach Offline
Beach  Offline
Here you go Jon....
The rubber goes between oil tank tab and frame...Bushing goes inside the rubber...bolt through tab, bushing and rubber, then through frame...
Any other questions or need for more pics just ask...battery box mounts on mine were kind of a puzzle...
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694549
05/09/17 2:29 pm
05/09/17 2:29 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
The second image that Beach posted shows the best way to connect the tank to the frame. The rubber bushing is T-shaped so needs the washer between it and the bolt head.
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Jon W. Whitley] #694599
05/09/17 11:07 pm
05/09/17 11:07 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Re: A65 Oil Tank Mounting Hardware Help Needed [Re: Roadwarrior] #694611
05/10/17 12:05 am
05/10/17 12:05 am
Originally Posted by Beach
Here you go Jon....
Beach, thank you so much ! It's just as I suspected it was but I was thrown off by the too small diameter of the hole in the rubber bushing.
Thanks Gary. I will add a flat washer to act as a buffer between the bolt head and the rubber bushing.
Originally Posted by C.B.S
Thanks C.B.S. although it looks like the order of the parts is incorrect and you might want to turn the rubber bushing around and maybe put the spacer after the bolt head. Nevertheless, I really appreciate your help
Thanks Mark, sounds like a good plan and would have been my plan B.
Thanks Roadwarrior !
