48 dingalinger
48 dingalinger
Victorville
35 registered members (998John), 325 guests, and 383 spiders.
10291 Registered Users
Stuart 95
Lannis 66
Mori55 65
638,130 mail-order LSR
Topics67,397
Posts654,377
Members10,291
B31 400 cc conversion #693319
04/28/17 12:37 pm
04/28/17 12:37 pm
Humbeek Belgium
timbo917 Offline OP
timbo917  Offline OP
Humbeek Belgium
Hello,
I am planning to do a T140 conversion to my b31 engine.
I think I found al the info I need on the forum but I want to be shore I got
everything right.
I need a Triumph T140 piston complete with rings and pin?
I would like to increase the diameter of the inlet valve. Is this the 500cc goldstar inlet valve that can be used?
Someone told me to enlarge the intake as wel. 30 to 32 mm,is this the correct size?
I also have been reading about rebalancing the crankshaft. I never done this before and I Always tought you
did the balancing with the new piston attached to the crank. On the website that I have been reading they speak
of 50 to 53 procent of the piston weight. Is this correct?
regards
Tim
Re: B31 400 cc conversion [Re: timbo917] #693345
04/28/17 7:53 pm
04/28/17 7:53 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The 500 Goldie valve will not fit. 350 Goldie valves will fit but the stems need to be shortened, you will need good measuring equipment and a lathe.
My 400 B31 has 350 Goldie valves, springs and retainers. Inlet port enlarged to 32mm with a Mikuni flat slide carb, Vernier DBD34 clubman cams, Goldie cam followers and delivering the goods via a Pearson crank with Carillo rod
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: B31 400 cc conversion [Re: Andy Higham] #693413
04/29/17 6:10 pm
04/29/17 6:10 pm
Humbeek Belgium
timbo917 Offline OP
timbo917  Offline OP
Humbeek Belgium
Thanks fore the info.
I am not planning to make it a racing engine but want some more power.
Is there a bigger inlet valve that wil fit without shortening? I have a lathe,no problem
there but are the valves not to hard to turn them? I have a small workshop and did engine
revisions before but this is my first atempt to modify one. The crank and rod wil stay BSA.
No budget to change them.
Re: B31 400 cc conversion [Re: timbo917] #693826
05/03/17 8:33 am
05/03/17 8:33 am
Northern Ireland
B31 Ally Offline
B31 Ally  Offline
Northern Ireland
Tim,
the most basic 400cc conversion I ever done was to a standard YB 31 small fin engine that I got the cylinder bored to suit a Triumph T140 piston. I had to make a 2mm thick shim to sit under the cylinder to raise it up so I had a tiny bit of valve clearance as the T140 piston has a domed head, the inlet port was enlarged slightly at the carb end as it is smaller there compared to further on in, more or less to get it the same diameter of the carburettor hole which is the standard AMAL 276, you do have to change jets and stuff but that comes when you start testing the engine. I put in two gold star fast road cams as well simply because I had them.
Standard crank, rod and valves all used and it works absolutely fine, it gives your B31 a bit more get up and go. Almost 800 miles on it so far with no ill effects and all working good.
Re: B31 400 cc conversion [Re: timbo917] #696915
05/31/17 12:34 am
05/31/17 12:34 am
Falkirk, Scotland
MikeF Offline
MikeF  Offline
Falkirk, Scotland
Hi Timbo,
I did the same conversion over last winter to a 1956 swing-arm BB31 motor that I was building for scrambling. IMHO you need to spend your budget on what will best deliver your requirements. Head work is only really going to deliver top-end so if you are not going racing you want to concentrate on getting flexibility through the Rev range with good torque/acceleration characteristics. So you re-bore to suit T140 piston because it's a straight fit (you might want to look out for Goetze piston rings as they are top quality and approx €30 a set). Make a 1.5 to 2mm decompression plate to fit under the barrel otherwise you risk stressing the bottom end and/or getting valve/piston interference (bad thing). If you can, invest in 2448/50 touring cams (€100 ish) - again they are a straight fit.
You don't say what model you are converting but if it has the breather on the timing case you might want to consider fitting a reed valve as the bakelite disc fitted as standard just can't keep up over about 3000rpm. I got a Yamaha one off eBay for a few € and it cuts down on oil leaks due to crankcase over pressure - not a mod for the purists of course.
Good luck with your project.
Mike F
Current crop:1946 BSA B31, 1955 BSA B31, 1997 Yamaha TRX 850, 2006 Yamaha MT03
Last year's project - Yamaha XS400 Street Tracker
Re: B31 400 cc conversion [Re: MikeF] #697724
06/07/17 1:08 pm
06/07/17 1:08 pm
Germany
Pete C Offline
Pete C  Offline
Germany
I've been running a 400cc conversion on my plunger B31 for a few years now. I used a slightly modified low compression T140 piston with a decompression plate and kept the standard cams. It has noticably more go than before and the deco plate is thick enough to make it easy starting with my deteriorating knees.
I have a set of touring GS cams 2448/50 and, when I tried them out in the engine, either the springs went coil bound or the collar was hitting the valve guide. In any case the engine would not turn by hand so I took them out again. I have a few spare heads so I'm intending to modify one with shortened guides and maybe GS springs if necessary, as well as fitting a B33 inlet valve and opening up the inlet tract for a slightly bigger carb. Another winter project.
I seem to remember reading somewhere that the GS springs would require preloading in this application. Does anyone know about this, or if it is necesary in a B engine?
Pete
Pete
Re: B31 400 cc conversion [Re: Pete C] #697772
06/07/17 9:09 pm
06/07/17 9:09 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
HI Pete,
The GS valve springs are a smaller diamater and length than the B31 so will need spacers underneath
You will need the top caps and collets to suit, which maybe problematic as the GS collets fit a semicircular groove in the valve stem,
I think they are a different taper angle than the B31 as well? a possibility might be C15/B40 caps and collets??
The B33 inlet valve has a larger diamater than the B31
Recently I fitted a T120 valve to a B31 head that had a recessed seat, the slightly larger valve head brought the valve back to a good position in the recut seat
Overall valve length can be corrected by taking a little off the valve tip or in this case leaving out the hardened cap
Re: B31 400 cc conversion [Re: Pete C] #698121
06/11/17 8:50 am
06/11/17 8:50 am
Originally Posted by Pete C
..... and opening up the inlet tract for a slightly bigger carb. Another winter project.
I wouldn't touch the inlet tract, just fit the bigger carb, if anything taper the first 10 mm on the head to match up with the carb.
Re: B31 400 cc conversion [Re: MikeF] #703719
08/02/17 9:05 pm
08/02/17 9:05 pm
United Kingdom
PaulM Offline
PaulM  Offline
United Kingdom
Hi
very intrested in your breather mods could you post details please
Paul
A7, A10, B33, B31, A65, C15, T100
Bantam
