Buckshot1
Buckshot1
Diamond Springs, Kalifornia
38 registered members (Al Eckstadt), 334 guests, and 364 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
Jap dampers in brit forks #606389
06/28/15 9:32 am
06/28/15 9:32 am
bon Offline OP
bon  Offline OP
I have heard of people putting fork dampers from japanese sports bikes in to british forks like the roadholders and others to improve the damping compared to the originals. Anyone here ever done this ?
Re: Jap dampers in brit forks [Re: bon] #606392
06/28/15 11:10 am
06/28/15 11:10 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Any modern Japanese sport bike damper will not fit in these old 34/35mm forks. You might be able to fit period (70's) Japanese dampers such as the XS650 or RD250 which have similar size fork tubes.
Are you talking early damper rod connected to the fork cap or damper stanchion used on OIF forks? The OIF damper is fairly ineffective owing to the slots along the damper tube which basically allows the oil to bypass the damper head.
As the seal in the bottom of the fork tube slides down the damper tube, oil is first pushed up to the top of the damper head but after the slots are positioned above the damper seal the oil goes directly to the chamber underneath the damper head, bypassing it completely.
A new damper tube with the holes and slots removed and the transfer holes put at the bottom so the damper head is always in the circuit.
Re: Jap dampers in brit forks [Re: bon] #606411
06/28/15 1:21 pm
06/28/15 1:21 pm
kommando Offline
kommando  Offline
Modern cartridge inserts can be fitted to roadholders, they need to be the thinner type and even then there will be some turning required.
The Cosentino insets fit directly as they are premodified, but hurt the pocket, there are cheaper but more intensive DIY options.
http://www.accessnorton.com/commando-fork-cartridge-conversion-t21431.html
Re: Jap dampers in brit forks [Re: bon] #606422
06/28/15 3:15 pm
06/28/15 3:15 pm
bon Offline OP
bon  Offline OP
Yes i believe honda cbr 600 dampers can be turned down and fitted, just wondering if anyone had done it and what was involved.
Re: Jap dampers in brit forks [Re: bon] #607910
07/09/15 6:00 pm
07/09/15 6:00 pm
gavin eisler Online content
gavin eisler  Online Content
Thats a great link thanks Kommando
Re: Jap dampers in brit forks [Re: bon] #609288
07/19/15 4:02 pm
07/19/15 4:02 pm
england
GS DAVE Offline
GS DAVE  Offline
england
The early CBR 600 forks have anti dive valving on one leg this is why I am going to use Honda cb 500 stanchions and damping internals.
Re: Jap dampers in brit forks [Re: bon] #617888
09/17/15 11:46 am
09/17/15 11:46 am
Overland Missouri
old mule Offline
old mule  Offline
Overland Missouri
In some past "Fishtail", the magazine of the Velocette Owners Club, it was told that a certain 70s honda fork leg was only .003 larger than the Velo one, and the article showed installation of those fork tubes on a standard Velo.
Re: Jap dampers in brit forks [Re: old mule] #617892
09/17/15 12:05 pm
09/17/15 12:05 pm
Stuart Offline
Stuart  Offline
Velo 1-3/8" o.d., Honda 35 mm. o.d.? Same as Triumph and Japanese stanchions.
Re: Jap dampers in brit forks [Re: Stuart] #617905
09/17/15 2:17 pm
09/17/15 2:17 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
? OIF stanchion that I measured is 1.3602" (34.549 mm)
Re: Jap dampers in brit forks [Re: DMadigan] #617981
09/18/15 5:37 am
09/18/15 5:37 am
Stuart Offline
Stuart  Offline
Hi Dave,
As that'd be 15 thou. undersize from 1.375" nominal, I'm guessing a working tolerance?
Re: Jap dampers in brit forks [Re: Stuart] #618022
09/18/15 1:58 pm
09/18/15 1:58 pm
england
GS DAVE Offline
GS DAVE  Offline
england
Hell of a working tolerance on a ground stanchion I would of thought.
Suzuki GS 550 stanchions are 35 mm, they fit Goldie bottom yokes which are 1 3/8" ( 0.003" ) smaller than 35mm but you have to machine the top diameter down and put the tapers and threads on.
Re: Jap dampers in brit forks [Re: bon] #618064
09/18/15 6:59 pm
09/18/15 6:59 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
This was back when England was still on the foot and finger system so presumably they started with a nominal side tube (1-3/8") and ground it down to a convenient dimension that would clean up any dings or slight bends in the material.
A close running clearance (RC4) would have a shaft -0.001 to -0.0016, a medium running shaft fit (RC5) would be -0.002 to -0.003.
-0.015" is off the chart even for a loose fit.
Leak Proof Seals labels the stanchions as 34.60mm.
Re: Jap dampers in brit forks [Re: DMadigan] #619328
09/26/15 8:48 pm
09/26/15 8:48 pm
south ester pa
DanDaughenbaugh Offline
south ester pa
Ive used the cartridge emulators from Mikes XS turned down 1mm to fit many brit bikes, nice price too!
https://www.mikesxs.net/product/27-1086.html
Re: Jap dampers in brit forks [Re: bon] #643342
03/08/16 1:41 am
03/08/16 1:41 am
Alaska
linker48x Offline
linker48x  Offline
Alaska
Gil Vaillancourt at Works Performance put CBR600 F3 cartridges in his Premier Manx, the really good blue one, before he passed away. It had the best fork action I ever experienced on a vintage bike, so I put them into the 38mm FZR 600 forks on one of my racers, a Yamaha two stroke F500 bike. My Triumph 750 Sportsman racer has 38mm Marzocchis with a set of custom cartridges Pierre Vaillancourt at Works Performance made for it, and they are really, really excellent too. The F3 forks don't have internal topout springs inside the cartridges, so you have to add them, if your forks don't have topout springs in them already (I cannot remember if Roadholders do or do not). And you need to machine down and rethread the caps, and make the package fit into the internal length you have available, and find springs that will work in the short space these will allow you (or use external springs on the Roadholders). Don't do this if you don't know what you are doing. It is best to send them to Pierre at Works, if he'll do it, he will make them work well.
Re: Jap dampers in brit forks [Re: linker48x] #643691
03/10/16 6:14 pm
03/10/16 6:14 pm
Western NY
Pete Suchawreck Online content
Pete Suchawreck  Online Content
Western NY
See Kommandos post in members bikes about Gavin's project.
Re: Jap dampers in brit forks [Re: bon] #667430
09/12/16 10:56 pm
09/12/16 10:56 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
+1 for Mikes XS cartridge emulators, cheap, effective adjustable damping.
Re: Jap dampers in brit forks [Re: bon] #691482
04/12/17 9:45 pm
04/12/17 9:45 pm
sydney.
tank slapper Offline
sydney.
I am going to opt for Japanese forks for my pre unit triumph. The prices you have to pay for pre unit forks now is insane.
Re: Jap dampers in brit forks [Re: bon] #693136
04/26/17 11:41 pm
04/26/17 11:41 pm
sydney.
sydney.
Actually, on the subject of forks, could some one tell me the total length of a set of 1957 tiger 110 front forks?
Re: Jap dampers in brit forks [Re: bon] #693195
04/27/17 12:56 pm
04/27/17 12:56 pm
New Zealand
johnm Offline
johnm  Offline
New Zealand
The guy who made the Landsdowne dampers for Roadholders sadly died a year or so back.
I understand they can now be purchased here.
http://www.tritonmotorcycleparts.com/297620484
These are a midrange price and not as much as Maxton or Cosentino. I have modern Honda 600 ones in my race Dommie but they took a lot of tuning to get right.
I think getting rid of stiction and preventing twisting under braking is at least as important as the improvement which is possible by going to modern dampers.
Re: Jap dampers in brit forks [Re: bon] #693201
04/27/17 1:49 pm
04/27/17 1:49 pm
kommando Offline
kommando  Offline
The Landsdowne inserts are singe rate dampers, ie its a single hole with an adjuster, one leg for rebound and one leg for compression, they have no facility for digressive damping which has 2 circuits and the circuit used depends on the type of bump you encounter eg you set the Landsdowne for one rate which is a compromise between low speed and high speed damping albeit adjustable between rides. So it cannot be compared to Maxton or Cosentino, they are using the same technology as the Showa's fitted to the CBR600RR with twin circuits hence the difference in price.
