Timecycles
Timecycles
Alberta, Canada
49 registered members (Adam M.), 285 guests, and 394 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 99
Stuart 83
reverb 82
NickL 73
koan58 56
549,701 mail-order LSR
Topics66,547
Posts645,114
Members10,170
Lapping the mounting face of a A65 oil pump? #692552
04/20/17 9:38 pm
04/20/17 9:38 pm
NJ
jhays79 Offline OP
jhays79  Offline OP
NJ
Ok, I made the mistake of opening up my oil pump only to have it bind when re-assembled. I spent quite a few hours lapping each gear by hand until I got it to spin freely by hand with no more binding. I noticed though, that the backside of the pump body that mounts against the crankcase isn't flush. Is it safe to lap it flat on a pane of glass and some fine grit sand paper so it will sit flush?
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692554
04/20/17 9:46 pm
04/20/17 9:46 pm
kommando Offline
kommando  Offline
Yes, if you don't you risk distorting it as you do the retaining bolts up.
Re: Lapping the mounting face of a A65 oil pump? [Re: kommando] #692570
04/21/17 12:35 am
04/21/17 12:35 am
NJ
jhays79 Offline OP
jhays79  Offline OP
NJ
That's what I was thinking as well. Just double checking before I move on. Thanks!
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692583
04/21/17 6:54 am
04/21/17 6:54 am
You could always place the pump on a sheet of glass then tighten up the screws, it should keep the pump flat when you tighten it up. Otherwise you will have to stop it again to clean out any filings that you have shaved off.
7ft lb tightening torque and blue locktite on the threads (more important if your using bolts Rather than the original studs.
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692588
04/21/17 7:14 am
04/21/17 7:14 am
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
Be careful when lapping the end faces on the oil pump or you may end up taking more material from one side or the other. Ideally you need a very steady hand and ensure the pump body is completley flat, keep checking every couple of minutes that the youre not over doing it.
+1 on the use of loctite on the bolts as they are often loose and this will lead to loss of oil pressure.
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692594
04/21/17 8:49 am
04/21/17 8:49 am
gavin eisler Offline
Also check where the pump mounts on the cases, the ally tends to pull up around the fastener threads, i used blue and a scraper to flatten.
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692596
04/21/17 9:24 am
04/21/17 9:24 am
NJ
jhays79 Offline OP
jhays79  Offline OP
NJ
Thanks for the advice fellas. These pumps sure are a PITA! grin
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692614
04/21/17 12:13 pm
04/21/17 12:13 pm
Before the final build, lap the seat for the NRV in the pump body feed side, use an old ball the correct size, glue to the end of a 1/2 " dowell, , bit of fine grinding paste, check progress with a magnifying glass a continuous matt ring says you are done., this helps stop wet sumping, rinse thoroughly to get rid of any abrasive..
Use a new ball.
A useful trick, if the pump is a little tight, assemble with brasso and spin with a drill for a a few seconds, strip clean reassemble, Some drag is acceptable/ good.
One finger pressure on a short spanner to turn is about right.
Re: Lapping the mounting face of a A65 oil pump? [Re: jhays79] #692639
04/21/17 8:42 pm
04/21/17 8:42 pm
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
Not sure which pump you are working on. As been discussed before the early pumps can be trouble some. I have never been a fan of lapping anything on these pumps early or late. I have had good success noting exactly where the gears are positioned in the pump prior to removing them. Putting them back as they came out seems to work pretty good. A big problem can arise if the casting has warped it self out of flat. If it is the gear set will get tight.
If I take the gears out, I slam the assembled body sans gears on a surface plate. Then check for flatness.
I do like cleaning the feed hole with a ball and lapping compound.
Yes always run the pump with a drill motor in oil, and I like the Brass O idea, I think when it turns real good clean it with solvent but do not take it apart again.
Hope some of this is helpful
Richard
Re: Lapping the mounting face of a A65 oil pump? [Re: gavin eisler] #692657
04/22/17 12:51 am
04/22/17 12:51 am
NJ
jhays79 Offline OP
jhays79  Offline OP
NJ
Use a new ball.
Some good info here! Will do! Thanks!
Page Time: 0.064s Queries: 15 (0.005s) Memory: 1.0565 MB (Peak: 1.2520 MB) Zlib disabled. Server Time: 2018-04-20 20:23:42 UTC
