Back2Brits
Back2Brits
Philadelphia, PA USA
39 registered members (AML), 201 guests, and 455 spiders.
Tcycles, Metalguru, hanscarlsson, BSADon, VH5150
10220 Registered Users
Lannis 109
Stuart 109
NickL 68
reverb 61
581,550 mail-order LSR
Topics66,854
Posts648,474
Members10,220
The inverted cranksahft seal.... #692610
04/21/17 12:04 pm
04/21/17 12:04 pm
Running from demons in WNY
Hillbilly bike Online content OP
Hillbilly bike  Online Content OP
I hear stories of it from guys here who know what they are talking about. How do you know it inverted other than loss of pressure. Was the seal still inverted when you pulled the side cover? Anyone have a photo? John Healy mentioned doing bench tests on seals to see the pressure it too to invert them....
My dual engine Triumph had the front engine lose all oil pressure after a piston partially seized...I wrote off the pressure loss to piston debris in the oil pump...I totally disassembled the engine and very carefully searched for clues but found debris in rod bearings and the screen sump filter.... the oil pump appeared clean. These pre unit engine side covers are converted to seals and they appeared like new... ......I repaired the engine and it been run for about 1/2 an hour with no problems....As I mentioned elsewhere the oil pressure was 95-100 psi when the engines are reved up with moderately warm oil...(LSR is short duration and the oil never fully warms up). I now have the oil pressure reduced to 75-80 PSI after trying a lot of pressure relief springs and use of shims as required...
Kommando identified the seal I used in one of the engine as an SDA Taiwan made part.. John Healy tested these seals 10 or more years ago and said they invert at about 160 psi, and less PSI when hot.....PW seals invert at around 200 psi or more.....
At any rate I have two genuine PW seals coming ............So, any proof you have of an actual seal inversion ? Perhaps the engines having seal inversion had 100 psi oil pressure...I do know from reading that most guys do not have oil pressure gauges installed...
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692616
04/21/17 6:15 pm
04/21/17 6:15 pm
I think the garter spring will be off the seal, after inversion.
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692618
04/21/17 6:30 pm
04/21/17 6:30 pm
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
When mine did this you could clearly see that the lip part of the seal was distorted.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: The inverted cranksahft seal.... [Re: R Moulding] #692620
04/21/17 6:34 pm
04/21/17 6:34 pm
Thanks guys....I'll pull the side cover an have a look.....
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692632
04/21/17 7:41 pm
04/21/17 7:41 pm
This seal was responsible for the motor burning up.
Kinda fuzzy, but I think you can see where the seal lip is deformed.
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692643
04/21/17 9:10 pm
04/21/17 9:10 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Your post is long, but I believe your main question was about crank seal inversion.
The only way to measure is by using an oil pressure gauge. Otherwise it's remove the timing cover to inspect.
In general, oil seal inversion (in my experience) is a rare and a non-fatal occurrence. On my 1966 6T, I found the seal and circlip popped entirely out of the cover and simply floating on the end of the crank. This engine (showing 12K miles) had never been opened and there is no telling how long it had run like that. Still, when the crank was removed, the crankshaft journals showed absolutely no signs of distress or damage. This for the simple reason that oil is being sucked into the crank, and so any oil presented to the oil input nipple is readily taken in. This is the common result on regular road bikes.
Further, IMHO in your specific application, the conversion to oil seal over the original brass bush, may not be an asset. This for the simple reason that when your engines are cranked, the run times are extremely short which allows no time for oil warming. So, whereas "bushing by-pass" once the oil is hot, as might be a concern on a typical road bike, is totally out of the picture in your application.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692648
04/21/17 10:15 pm
04/21/17 10:15 pm
Pleasant Hill, California USA
TR7RVMan Online content
TR7RVMan  Online Content
Hi Hawaiian Tiger, What brand seal is that?
Looking at the '69 bonnie cover on my work bench that has original seal from 70s that has the tin shield. Comparing snap ring edge were pliers go to the edge of your seal & to the edge of old version seal, the tin of the old seal might have prevented that from happening?? The old tin version appears to cover more of the lip.
By the way, the old tin version has black rubber around the outside edge, so rubber seals outside. The rubber ends just around corner so it slightly is on tin face.
The tin covers much of the seal lip such it supports lip from rolling out. Measuring an old seal on the crank snout the gap between snout & tin is .032" meaning seal lip would have to squeeze through .032" to invert.
Certainly rubber could do that with enough pressure. I wonder how the old original version would compare to modern Pioneer Weston?
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692649
04/21/17 10:30 pm
04/21/17 10:30 pm
Death row next in line norfolk
Tribsauk Offline
Tribsauk  Offline
I have a oil seal conversion on my pre unit 750 Tribsa but only machined the timing cover just enough so the seal sits flush and left the old part remaining bush in situ so I have the best of both .. if the seal gives out I still have the bush to feed crank.With this conversion there is no place for a circlip to hold seal in situ I used superglue with no problems after approx 6000 miles.Dave
1941 BSA WM20
1958 TRI-BSA 750 PRE UNIT
1957 THUNDERBIRD
1932 R E MODEL GS SPECIAL
1947 BSA YM21
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692656
04/22/17 12:21 am
04/22/17 12:21 am
Bill, the photo is helpful, thanks....Nick, I spend time trying to get heat into the engine before each race...it's not easy because the machine is stationary and with no air flow the head gets too hot before the oil gets slightly warm...So the engine has to run, then shut down to allow the head to cool and started again.as it advances slowly towards the starting line.. About the bushing being an advantage over the seal, most of the Triumphs in LSR including my other bike are unit engines...
..Both engines cases are 1956, one a TR6 generator , the other a 6T alternator engine..,
The bike goes on the dyno May 4th to be thrashed unmercifully and don't need an oil pressure failure at full power causing the smoking crankshafts to bounce off the floor..
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692667
04/22/17 1:54 am
04/22/17 1:54 am
South cone
reverb Offline
reverb  Offline
South cone
...hi Tony, I cannot add more info to help on this but I am very interested in that dyno test. May be you can shot a few clips to see what s going on..
Re: The inverted cranksahft seal.... [Re: reverb] #692705
04/22/17 11:37 am
04/22/17 11:37 am
I will take a video of the bike on the dyno..... An airplane pilot once said
two engines doubles the risk of an engine failure
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692709
04/22/17 12:00 pm
04/22/17 12:00 pm
Jordan, NY
Al Eckstadt Offline
Al Eckstadt  Offline
Jordan, NY
Tony, what about a magnetic block heater to warm the oil? The heater would go on the oil tank, right?. If you have an alloy oil tank you could strap it in place somehow. Of course it would require access to 110 volts (maybe a small hand carry generator).
Al Eckstadt
Re: The inverted cranksahft seal.... [Re: Al Eckstadt] #692715
04/22/17 1:08 pm
04/22/17 1:08 pm
That's a thought, auto drag racers use oil pan heating pads, the location of the oil tank lends itself to a small heating device....This bike is tightly packaged despite the 68 inch wheel base..I do use 20/50 synthetic racing oil in both bikes that supposedly lubes better when only slightly warmed up....In the long run these engines are stressed beyond design limits like all mass produced street engines that are modified for racing...So it's a short hard life no matter what...
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692743
04/22/17 8:39 pm
04/22/17 8:39 pm
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
Running less oil in a smaller oil tank would also allow faster warming and put you closer to where you want for temperature. Insulation might also help, perhaps make it removable. On Excalibur dragbike I (originally) ran a length of polycarbonate tube for the oil tank. It held about 300ml (1/2 pint) with sufficient headspace. Basically I reasoned that returning oil could be fed back almost immediately with only enough time to remove aeration was required. The idea worked a treat, saved a lot of weight. Eventually I discovered the methanol blow-by past the piston rings was crazy cracking the polycarbonate. One thing I really liked was I could see oil level at a glance. I'm sure you'd cringe at running so little oil...! It did 4+ seasons like that.
Just a few thoughts that might help you come up with solutions.
Re: The inverted cranksahft seal.... [Re: Hillbilly bike] #692748
04/22/17 9:17 pm
04/22/17 9:17 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
Hello, I have always had a pressure gauge, old mini type smiths ones.
I had the timing cover machined for an oil seal on my pre-unit T120 engine about 1980. It involved welding around the bushing boss and was only milled for the seal to recess flush (no circlip).
It improved the hot pressure enormously, from zero at tickover to ~20 psi, and 40-60 at speed.(cold oil ~85+psi).
The seal popped out quite soon, so I made a thin retaining plate with 2 screws, required slimming the crank pinion retaining nut slightly.
No further issues until 30 or so years later I noticed a drop in oil pressure from the usual ~50 to ~15 running, gentle ride home - open and find one side of the seal lip pushed the wrong way. Unfortunately I did not notice the maker of the seal, but it would have been supplied by TMS, who I have confidence in.
So it has happened once to me in 30 years, I do not think that is worrying, except for the fact that if it happens, you may not know unless you have a gauge.
Re: The inverted cranksahft seal.... [Re: koan58] #692751
04/22/17 9:59 pm
04/22/17 9:59 pm
The oil seal inversion shown in the above photo did not happen to a Pioneer seal, but some unknown brand without reinforcing metal. The crank and rod failure didn't happen immediately but over about 100 miles.
It significantly lowers oil pressure when this happens but leaves just enough to impart a false sense of safety. This is why having an oil pressure test or onboard pressure gauge or indicator(pre unit) can save your motor.
I suspect that when the motor got hot, the oil pressure was basically zero, but the owner/rider didn't notice since he had open pipes on the bike. Rod journals burned to the point where they started to knock instead of just spinning a bearing and then throwing a rod like what usually happens to these motors when oil pressure is lost.
Re: The inverted cranksahft seal.... [Re: Excalibur] #692755
04/22/17 10:43 pm
04/22/17 10:43 pm
The bike has a common tank , the total oil system,tank, filter, hoses is about 3-1/2 quarts....I might cringe a bit running and engine wide open for 30-45 seconds on 16 oz's of oil...
I pulled the side cover on the front engine that I had to rebuld because of lost oil pressure....It has been run 1/2 hour or so since....I turned the quill about .020 because scoring that happened before I got the crank...So it's the 70-6387 .020 seal...It's an SDA,, looks fine up close in real life.This seal did not invert causing the pressure loss.....I have two new standard seals, a 2072 PW and a SDA branded seal. I find them to be identical in appearance ,...That's not to say they are identical in quality...
