Jim Hultman
Jim Hultman
Minnesota, US
30 registered members (Alan_nc), 197 guests, and 472 spiders.
PreunitPeter, Tcycles, Metalguru, hanscarlsson, BSADon
10221 Registered Users
Stuart 109
Lannis 108
NickL 73
582,262 mail-order LSR
Topics66,861
Posts648,584
Members10,221
Bushing for 66-2008 #691749
04/15/17 1:14 am
04/15/17 1:14 am
Denver CO
Jerry Roy Offline OP
Denver CO
Is the bush in part # 66-2008 ( timing side out rigger plate) a standard bearing bronze, and can it be replaced without the benefit of line boring?
Is there a min and max clearance associated with it?
Mine seems to have excessive clearance, due to some wear on one side of the shaft.
Any insight is appreciated.
JR
Re: Bushing for 66-2008 [Re: Jerry Roy] #691764
04/15/17 5:32 am
04/15/17 5:32 am
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
Cant really answer the question with any authority, though it's not uncommon to see the bush removed, as the lack of correct alignment or misalignment of the shaft can cause the shaft to break...
There is a noice needle roller conversion out there..I bought one once, and had Phil Pearson build it into my engine, though I suspect he had produced the kit in the first place! (the kit amounted to a new outrigger plate and the bearing fitted to it.)
Oliver Wendell Holmes
Re: Bushing for 66-2008 [Re: Kerry W] #691799
04/15/17 2:53 pm
04/15/17 2:53 pm
Denver CO
Denver CO
Thanks for the reply, Kerry,
The part of my shaft that rides in the bushing has one part of the bearing surface noticeably worn, and when the main bearings indicate .0015 in runout, the end of the shaft that rides in the bushing indicates .0035 to .004 inch. So obviously, it has been running like that for a long time.
Now you have me wondering if I should leave it alone, or make a new bushing and try to hold the shaft Concentric with the bushing. I suppose I should put it together and see what the clearance between the gears is at apogee.
One thing or another, huh?
JR
Re: Bushing for 66-2008 [Re: Jerry Roy] #691825
04/15/17 7:21 pm
04/15/17 7:21 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi JR,
From your description it would seem that the crank and / or mainshaft is not running true
The part that runs in the bushing is part of the mainshaft pinion
I have machined a worn pinion true to its bore and made a new bush from PB1,
This was on a B31 rebuild, new mains and rebuilt crank
Attempting to "straighten" the spindle with a tighter fitting bush would not be a good idea
Re: Bushing for 66-2008 [Re: Jerry Roy] #691854
04/15/17 10:58 pm
04/15/17 10:58 pm
IMHO, with the run out on the timing side crankshaft it has gotten loose in the tapered bore or the rivets have given way. Either means that you need to look at the root of the problem and mend a fix and bring the runout back within tolerance. A new bushing will be oblong in no time otherwise. The runout is circular, 360 degrees. The wear on the shaft is from no clearance, in fact interference from the bushing.
Re: Bushing for 66-2008 [Re: Jerry Roy] #692184
04/18/17 2:40 pm
04/18/17 2:40 pm
Denver CO
Denver CO
Thanks for the input guys.
From my perspective it looks like the answer to the problem, since the main bearing seats run true, the drive side shaft runs true, the flywheels run true, and the outer end of the timing side is the only part that doesn't, is to shim between the flywheels so that they are in effect one piece. Clamp them down to a solid table, make a pipe with holes bore to the diameter of the main shaft, the splined portion, and the oil spigot , and apply bending force to the shaft until the end spigot is centered.
Has any one done that, or is there another method that is more appropriate?
JR
Re: Bushing for 66-2008 [Re: Jerry Roy] #692235
04/18/17 8:46 pm
04/18/17 8:46 pm
Norfolk England
DBDBrian Offline
DBDBrian  Offline
Norfolk England
Jerry, I personally would not go down that route. If there is any doubt, the timing side shaft needs to be checked for truth as an individual item, with the crank apart.If found to be bent, it should ideally be replaced. I'm not saying it can't be straightened, but is it worth the risk and trouble.
Are you sure the the problem is not being caused by run out on the crank , a 0,0015 run out at the bearing would obviously be amplified along the length of the shaft.
Are you checking the crank between centres, or on the bearings ?
Another point too watch, is when the timing side outer nut is pulled up tight, it can on occasions pull the shaft off centre, Even with a crank which is running true, the quill need to be clocked after the nut is pulled up.
The best method is to manufacture a nut , which will pass through the outrigger bearing, it can then be all pulled up and clocked before fitting the outrigger plate.
Brian
Made In England
Re: Bushing for 66-2008 [Re: Jerry Roy] #692278
04/19/17 5:10 am
04/19/17 5:10 am
He says he has .0015 at the main bearing and .0035 to .004 at the end or at least near the end of the shaft at the bushing! I don't think the shaft is bent, it is out of true and the only way to straighten is to pull the crank out and true/replace the timing side shaft. I would suspect a loose rivet or more. In the past, Alpha used to sell replacement timing side shafts. The factory ones had an issue with the step between the main bearing and the pinion gear. A relief of the sharp angle by machining in a radius at this point would help alleviate this issue.
At a race at Westwood Canada one year, about 1987, a Gold Star racer had his bike just quit on him. When he pulled the timing cover he noticed that nothing rotated inside the timing chest when he turn the engine over. The timing side mainshaft had sheared at this step.
Re: Bushing for 66-2008 [Re: Boomer] #699077
06/19/17 11:07 pm
06/19/17 11:07 pm
British Columbia, Canada
Tricatcent Offline
Tricatcent  Offline
The same thing happened to my engine. The timing side shaft broke and everything stopped turning. The crankshaft nut on the timing side was loose, so the shaft was not lined up.
Re: Bushing for 66-2008 [Re: Jerry Roy] #699100
06/20/17 2:58 am
06/20/17 2:58 am
Denver CO
Denver CO
Huuummm, quandaries
I'm using bearings that ride on the inner bearing shoulder on the shafts when I measure things.
And there is a definite portion of the timing side shaft, where it rides in the brass bushing in the out rigger plate, that has a polished appearance about half way around the circumference, so it has definitely been that running way for a long time.
Something else to lose sleep over. facepalm
Thanks for the input guys. Every bit of knowledge helps.
JR
