Jim Hultman
Jim Hultman
Minnesota, US
30 registered members (Alan_nc), 197 guests, and 472 spiders.
PreunitPeter, Tcycles, Metalguru, hanscarlsson, BSADon
10221 Registered Users
Stuart 109
Lannis 108
NickL 73
582,262 mail-order LSR
Topics66,861
Posts648,584
Members10,221
Alternator Conversion #662111
07/28/16 3:52 pm
07/28/16 3:52 pm
al jam Offline OP
al jam  Offline OP
I'm not sure this is going to work but I'm attempting to fit a Kubota alternator in place of the dynamo on my Viper. I know it's been done before but I've never seen a photo or explanation of the best way to do it.
After raiding the scrap bin at work for some scrap alloy and spending a couple hours at the lathe here's progress so far.
Still a little work to do but with any luck it'll fit though I suspect the pulley/belt cover will require a little modification.
1958 Triton
1958 Triumph 650 Speed Twin
1958 Velocette Viper
1959 Norton 650SS bitsa
1961 BSA Bantam D1
Support your #1 Velocette Forum
Velocette Motorcycles on e-Bay UK, Velocette motorcycles on e-Bay North America
Re: Alternator Conversion [Re: al jam] #662114
07/28/16 4:40 pm
07/28/16 4:40 pm
Les P Offline
Les P  Offline
If you have the room OD wise you could make a carrier and drive it off the non pulley end. (Maybe that was the plan anyway)
The shaft is only a light press fit.
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: Alternator Conversion [Re: al jam] #662118
07/28/16 4:56 pm
07/28/16 4:56 pm
al jam Offline OP
al jam  Offline OP
Aye that's a good idea Les, I'll be able to see what kind of room I've got when I get home tomorrow night and get it offered up on the bike.
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #662143
07/29/16 5:25 am
07/29/16 5:25 am
Just as an aside, if you want more than 14A output at some future point I have found a 20A alternative.
http://chinagas.en.alibaba.com/product/2...usan_Denki.html
Model 100 = Universal one wire self turn on unit for conversion or OEM applications.
Model 200 is replacement for Kokusandinki units as found on tractors & refrigeration units.
Model 200 = Kokusandenki OEM unit repl. for GP9905 / GP9906 / GP9907 Lester # 10930
Model 300 = unit without integral regulator. Has long lead wire for external regulator.
I would prefer the Model 300 without the internal regulator but yet to find that version retail, the Model 200 version is available retail.
This is one example
http://www.urqualitysolutions.com/New-Alternator-8970489700-GP9905-Kokusan-Denki-10930-10930.htm
Re: Alternator Conversion [Re: al jam] #662221
07/30/16 1:38 am
07/30/16 1:38 am
al jam Offline OP
al jam  Offline OP
It fits!
I'll need to make up a new rear bracket/plate for the belt/pulley cover as the magnet takes up the space where the old one used to attach.
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #662223
07/30/16 1:42 am
07/30/16 1:42 am
al jam Offline OP
al jam  Offline OP
Thanks kommando, I'll keep those links for the future. Since I'm not out in the dark that often I was hoping 14A would be enough, we'll see if it is once it's all wired up..
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #662231
07/30/16 4:33 am
07/30/16 4:33 am
As long as you don't plan to add electric start 14A will be fine, I was looking for a conversion to add electric start to my Commandos and need a new alternator as the Lucas one is not thin enough.
Re: Alternator Conversion [Re: al jam] #662772
08/03/16 4:04 pm
08/03/16 4:04 pm
al jam Offline OP
al jam  Offline OP
Wiring still to tidy up abit but it all works.
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #663330
08/08/16 5:45 pm
08/08/16 5:45 pm
bon Offline
bon  Offline
Would this alternator be enough to power electronic ignition, head and tail lights and indicators ?
Re: Alternator Conversion [Re: al jam] #663380
08/09/16 5:07 am
08/09/16 5:07 am
14A version would give at 12V 170W, so plenty of juice in comparison to the std Lucas alternators and very close to the high output single phase Lucas versions. The 20A would be 240W and 3 phase so beats the Lucas 3 phase. Only issue is they do not give a rev number for the output, but as they are fitted to diesel generators this should be at a lowish rev number as these are limited to 3 to 4k rpm.
Re: Alternator Conversion [Re: al jam] #663402
08/09/16 10:23 am
08/09/16 10:23 am
al jam Offline OP
al jam  Offline OP
Here's the spec/information I have found
Voltage 12V
Normal Output 150W
Max current 14A
Rotation Clockwise
Output rpm 4250rpm
Charge starting 1800rpm
Drive pulley 100mm
Alt pulley 58.5mm
Ratio 1:1.7
I'm assuming that 1800rpm will put the charge light out and anything over 4250rpm is unnecessary but we'll just have to see how it goes in service.
At the moment I think I'm running about an equal ratio but I was planning on making up a toothed belt set-up running the alternator a little faster.
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #665315
08/26/16 2:28 pm
08/26/16 2:28 pm
al jam Offline OP
al jam  Offline OP
Ordered toothed belt pinion blanks and a beltfrom belting online and machined them up this afternoon. Just waiting on the correct belt, ordered the wrong width 1st time round!
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #665932
08/31/16 1:46 pm
08/31/16 1:46 pm
al jam Offline OP
al jam  Offline OP
Belt arrived today, fits great and there's a healthy charge showing on the a ammeter. A little fabrication is required to get the covers fitted but I'm pretty happy it all works. �17 Inc postage and a bit of time on the lathe is pretty good for a belt drive conversion in my eyes, bit of a shame to cover it up.
Now I just need to rebuild the mag. Fitted a brightspark easycap which has helped with cold starting but the last 2 evenings the bike has cut out and refused to restart once hot. Runs great as long as I don't go further than about 15 miles!!
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #679138
12/28/16 8:24 pm
12/28/16 8:24 pm
Smackinthemiddle, NJ
rocketscientist Offline
Nice Job Al Jam!
Questions:
1) What regulator / rectifier is that?
2) Obviously, you went 12v, but did you stay pos (+) earth?
3) No provision for a belt tensioner.....so the tooth belt needs to be spot on..
What is the front and rear pulley full description and belt size?
I'm thinking of doing the exact same thing. eBay in us has plenty of Kubota alternators for $67 US. Just need to figure the rest of the parts.
Thanks!
Re: Alternator Conversion [Re: al jam] #679976
01/04/17 12:36 pm
01/04/17 12:36 pm
Hinckley Leicestershire Englan...
bthtony Offline
bthtony  Offline
As there is a lit of inertia on the alternator I would use a V belt. Guess how I know
Re: Alternator Conversion [Re: rocketscientist] #680096
01/05/17 12:17 pm
01/05/17 12:17 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Could the housing be machined so that the alternator doesn't sit in it concentrically? That would mean the pulley would be off center and belt tension could be adjusted the same way as the stock set up.
Ed from NJ
Re: Alternator Conversion [Re: edunham] #685687
02/22/17 8:20 pm
02/22/17 8:20 pm
al jam Offline OP
al jam  Offline OP
That's what I did, there's not a huge amount of adjustment but there's enough to keep the belt tight
Just after I bought it in 2013 before mechanical re-commisioning
And today after 40 miles in the uncharacteristically sunny Scottish winter...
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #686157
02/27/17 2:22 am
02/27/17 2:22 am
Thanks for the additional picts you sent and posted. It clears quite a bit up. Mike
Re: Alternator Conversion [Re: al jam] #692230
04/18/17 7:55 pm
04/18/17 7:55 pm
al jam Offline OP
al jam  Offline OP
Finished off the last couple jobs today.
Felt a little bad about butchering the inner belt cover but it wasn't in great condition to start with. I turned an extended crankcase stud nut to use as an upper mount having removed the old upper mount that no longer fitted due to the increased diameter alternator compared to the dynamo.
Also had to make a new outer battery strap, the original was a casualty of an early test ride. Unfortunately the flat bar I had was a little thicker than the original but it'll do for now.
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #692253
04/18/17 11:26 pm
04/18/17 11:26 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Hang on I'm confused Al, earlier you had fitted a tooth belt, -did you later go back to the vee belt?
Re: Alternator Conversion [Re: Joolstacho] #692924
04/24/17 6:04 pm
04/24/17 6:04 pm
al jam Offline OP
al jam  Offline OP
Aye, I decided to go back to the v-belt, I misread the chart when selecting the belt size and the T5 belt is a little on the light side so I've reverted to the V-belt for now until I get time to build up a stronger set up. I'm also curious to see how the alternator performs at the current speed ratio. I'm thinking of speeding it up to increase the current at lower engine rpm but since it was designed for a small diesel engine I'm wary of having it run too fast for fear of overheating it. Don't know if anyone else has an opinion or experience of this?
1958 Triton
1961 BSA Bantam D1
Re: Alternator Conversion [Re: al jam] #692974
04/25/17 10:59 pm
04/25/17 10:59 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Have you measured the output at various revs Al?
Re: Alternator Conversion [Re: Joolstacho] #712437
10/23/17 8:13 pm
10/23/17 8:13 pm
al jam Offline OP
al jam  Offline OP
I haven't a rev-counter fitted at the moment but it's on my list of things to have a look at over the winter. I also need to fit a new regulator as the one currently fitted has given up, I think it happened when the live feed to the battery fretted through on a longer ride into the borders. The fuse at the battery blew but I didn't have one at the regulator so I'm guessing that the prolonged short is the cause of the failure. I've bought a cheap Chinese scooter rectifier which seems to work but we'll see how it lasts after a few miles.
1958 Triton
1961 BSA Bantam D1
