Arlo
Arlo
Indianapolis, IN
35 registered members (AngloBike), 280 guests, and 413 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,170 mail-order LSR
Topics67,366
Posts654,078
Members10,288
BSA A10 Spitfire High Pipe Exhaust Mount #690788
04/07/17 12:26 pm
04/07/17 12:26 pm
Houston Texas USA
thackero Offline OP
thackero  Offline OP
Houston Texas USA
I have the high pipe exhausts both exiting on the left for my 1961 A10 Spitfire and whilst I know where the mounting point is on the frame above the rear of the primary can anyone help out with some pictures of the mounting clip and maybe how to secure both the pipes and the heat shield. It would appear that the hardware for the high pipe mounting is not available so I will probably fabricate my own. Pictures sketches are very informative so whatever anyone has would be welcomed. Thanks
1961 BSA A10 Spitfire
1964 Triumph TR6R Trophy
1975 Norton Commando Mark III E/S
2007 Triumph Speed Triple
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690882
04/07/17 10:19 pm
04/07/17 10:19 pm
Georgia Mountains
goodtry Offline
goodtry  Offline
Georgia Mountains
I can take a few pictures this weekend and post on Monday if someone doesn't add some pics prior.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690911
04/08/17 1:54 am
04/08/17 1:54 am
Kansas City
RGSDave Offline
RGSDave  Offline
Kansas City
Hope this helps....Dave
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690947
04/08/17 1:48 pm
04/08/17 1:48 pm
minnesota
chuckmn Offline
chuckmn  Offline
minnesota
A few years ago when I was looking for Spitfire parts I found a company in Australia that made reproductions. At the moment i can't seem to find their information.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690964
04/08/17 3:32 pm
04/08/17 3:32 pm
Here's a close up of the bracket, not quite as nice as the one shown above. They are hard to find. I imagine they would fall off or were tossed as something not recognizable.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690966
04/08/17 3:41 pm
04/08/17 3:41 pm
The shield was mounted off of one pipe. It used the tee clamp like what was used on A10 muffler brackets. There was a stand off shouldered hex nut off of the end of the tee bolt that the shield was mounted to using a slotted screw. The Spitfire Hornet used a shield that was very similar only a bit narrower.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #690998
04/08/17 8:56 pm
04/08/17 8:56 pm
That the set from San Jose Bill?
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: D.Bachtel] #691064
04/09/17 3:53 pm
04/09/17 3:53 pm
Pipes yes, mounting bracket no.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #691075
04/09/17 6:11 pm
04/09/17 6:11 pm
Irish Swede Offline
Irish Swede  Offline
So. the pipes were mounted to each other, but were they mounted to the frame? If so, how?
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: Irish Swede] #691103
04/09/17 9:55 pm
04/09/17 9:55 pm
In Dave's pictures of the exhaust system you can see in the first one that the pipes were bolted together by interlocking tabs bolted together. You can just see it after the first swept bends at the front of the cylinder with the horn behind. The bracket I posted a picture of that wraps over the two pipes has a hole in the middle for a bolt that threads into one of the toolbox bosses cinching the pipes to the frame. Again in Dave's first picture you can see the bolt head in the middle of the bracket.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #691150
04/10/17 12:14 pm
04/10/17 12:14 pm
Irish Swede Offline
Irish Swede  Offline
Thanks, Boomer. I see it now.
A simple solution without making the frame 'special' to the Spitfires.
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: Irish Swede] #691220
04/11/17 2:08 am
04/11/17 2:08 am
Houston Texas USA
thackero Offline OP
thackero  Offline OP
Houston Texas USA
My understanding is that the Spitfire frames only had one boss on the frame for the exhaust pipe clamp bolt and no passenger peg loops so the spitfire frame was a modified standard frame made for that model. Kind of special as its not standard
Re: BSA A10 Spitfire High Pipe Exhaust Mount [Re: thackero] #717225
11/30/17 3:47 pm
11/30/17 3:47 pm
Uk
X
XLS Offline
New poster
XLS  Offline
New poster
X
Uk
Did anyone send the photos of the exhaust mount? i have the same problem but have the clip bolt and spacer but would like to see where it attaches to the frame
