Konstantinos
Konstantinos
Athens Greece
37 registered members (bill50cal), 186 guests, and 482 spiders.
10416 Registered Users
btour 84
Triless 76
Rohan 76
reverb 75
Stuart 70
707,972 mail-order LSR
Topics68,286
Posts664,818
Members10,416
thackery washer how to #689549
03/27/17 3:59 am
03/27/17 3:59 am
South cone
reverb Offline OP
reverb  Offline OP
South cone
...I am trying to change these washers in the pillion footrests. I am trying different procedures but the space is minimal and also I am chipping all the paint.
So next possibility, but I am here asking before to do it, is to red heat the spring washer to softened and to massage it inside that cavity...
could be a wrong idea?
Re: thackery washer how to [Re: reverb] #689552
03/27/17 5:07 am
03/27/17 5:07 am
Great Southern Land
tridentt150v Online content
tridentt150v  Online Content
Great Southern Land
That would be a dumb idea....you would loose al the coil tension in the washer and then your pillion peg would flop down all the time.
Try spreading your pillion peg fork out a bit.
Use a longer bolt or threaded rod that is small enough to go through the footrest thread without using it and then two thin nuts then turn the nuts out. If you can, use plain washers to protect your paint while you do this. If you don't understand what I am saying get back to me and I will go into more detail.
BTW I have never ever had any problem with this task....so your fork must be bent or the washer is the wrong one or something.
Re: thackery washer how to [Re: tridentt150v] #689607
03/27/17 4:07 pm
03/27/17 4:07 pm
South cone
reverb Offline OP
reverb  Offline OP
South cone
I imagined the possible lose of the tension hence I asked before to do anything...
I think that I understand what you are trying to explain but the peg forks (the hangers) are dead hard impossible to move it to gain space.
The springs are new and look thick, I do not have right now the an old one to compare; I only remember that the old one was loose there so there s no right action.
Re: thackery washer how to [Re: reverb] #689668
03/28/17 1:15 am
03/28/17 1:15 am
South cone
reverb Offline OP
reverb  Offline OP
South cone
...the space in the hanger peg is 7/16 the other part is 5/16 and the washer is 3/16 without compression; with compression is 5/32
I cannot imagine how the factory did to put these ones without chipping the paint.
Re: thackery washer how to [Re: reverb] #689694
03/28/17 10:38 am
03/28/17 10:38 am
Peter R Offline
Peter R  Offline
Fernando, are you sure that these spring washers are original ? The ones in the footrests of my Triumh look thinner than the one in your picture.
I had the same problem as you, that the footrests moved down by itself, and I cured this by fitting a thin steel washer behind the spring washer.
Re: thackery washer how to [Re: reverb] #689705
03/28/17 12:05 pm
03/28/17 12:05 pm
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
What bike are we talking about?
Post a picture of what's in the way?
Re: thackery washer how to [Re: AngloBike] #689717
03/28/17 1:09 pm
03/28/17 1:09 pm
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
That sure looks like the wrong spring to me. Supposed to be flat wire not round.
Re: thackery washer how to [Re: reverb] #689718
03/28/17 1:58 pm
03/28/17 1:58 pm
Tridentman Offline
Tridentman  Offline
That looks like a standard hardware store spring washer to me--made from fairly thick flat stock.
The "proper" spring washer is made from much thinner flat stock and consequently fits quite easily into the pillion footrest.
In fact as previously mentioned if the footrest itself has worn away/corroded away between the "jaws" of the footrest then you sometimes need to add a plain washer to the spring washer in order to get the right amount of force to stop the pillion footrest flopping down instead of staying in an upright position.
So--reverb--get the correct washers----or if that is difficult because of where you live then grind off some of the existing washer---a bit at a time---trying it in the footrest at each stage.
Re: thackery washer how to [Re: reverb] #689727
03/28/17 2:55 pm
03/28/17 2:55 pm
South cone
reverb Offline OP
reverb  Offline OP
South cone
...thank you.
Is a 67 frame that when I bought it only had one pillion peg and one spring.
I bought these others from a British parts seller...
I will try and see if I can grinding down
Re: thackery washer how to [Re: reverb] #689756
03/28/17 7:51 pm
03/28/17 7:51 pm
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
I know you are at the last outpost of civilization but if you have to modify something to make it work it's not the correct part. The part # for that on a 68 is F2277 and it looks kind of like the thackery in the rocker box.
By the time you grind down what you have there will nothing left. I'd find a new parts guy.
Re: thackery washer how to [Re: reverb] #689759
03/28/17 8:07 pm
03/28/17 8:07 pm
Jordan, NY
Al Eckstadt Offline
Al Eckstadt  Offline
Jordan, NY
Maybe you can find and use a different type of spring washer. Belleville washers should work well in a footrest. Or wave washers. You may need some thin washers to shim to the correct tension. Pics from McMaster-Carr. Belleville and Wave.
[img]https://images1.mcmaster.com/mvA/contents/gfx/large/96445kc1l.png?ver=1323073912[/img]
[img]https://images1.mcmaster.com/mvA/contents/gfx/large/99842al1-b01l.png?ver=1414505822[/img]
If you can't find another spring washer try using a stack of very thin washers and tension them with the footrest thru-bolt/nut.
Al Eckstadt
Re: thackery washer how to [Re: Al Eckstadt] #689780
03/28/17 11:03 pm
03/28/17 11:03 pm
Ontario Canada
Bob Buchanan Online content
Bob Buchanan  Online Content
Ontario Canada
With the correct thackery washer, ( thinner than shown ) because the late 50s bike used the same part numbers , the way to tighten tension on footpeg it to turn slotted screw in and lock in place with lock nut. Unless thread has been drilled out !
Re: thackery washer how to [Re: reverb] #689785
03/29/17 12:58 am
03/29/17 12:58 am
South cone
reverb Offline OP
reverb  Offline OP
South cone
Seems that there are two types. Mine look like these ones
http://www.eBay.ca/itm/60-2438-TRIUMPH-500-650-750-REAR-FOLDING-FOOTPEG-THACKERY-SPRING-WASHER-5-16-/121824152884?hash=item1c5d490d34:g:yU4AAOSwEK9T9O~2&vxp=mtr
Triumph 60-2438 Rear Folding Footpeg Spring Washer 500 650 750 NOS NP3313
http://www.eBay.ca/itm/Triumph-60-2438-Rear-Folding-Footpeg-Spring-Washer-500-650-750-NOS-NP3313-/331618563463?hash=item4d3601b587:g:Ac0AAOSwu4BVvPdb&vxp=mtr
Re: thackery washer how to [Re: reverb] #689789
03/29/17 1:27 am
03/29/17 1:27 am
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
The one from TSS looks right. I can't get the 2nd site to open.
Re: thackery washer how to [Re: reverb] #689794
03/29/17 2:42 am
03/29/17 2:42 am
South cone
reverb Offline OP
reverb  Offline OP
South cone
...alright guys just grind down the washers as Tridentman suggested and finally they fitted! a bit of chipping in the paint but I am glad that worked.
Desco, there are many things here but nothing of these "obscure" stuff; also now seems all made in China and the importers normally bought what they think that sell fast.
Thank you very much for your time and tips.
