Lliam Harrison
Lliam Harrison
Windham ME
47 registered members (Al Eckstadt), 286 guests, and 399 spiders.
10256 Registered Users
Lannis 62
608,687 mail-order LSR
Topics67,112
Posts651,274
Members10,256
Hydraulic Clutch conversion? #678405
12/20/16 6:31 am
12/20/16 6:31 am
Norfolk UK
Tricky-Dicky Offline OP
Norfolk UK
Noticed that there are some clutch slave/actuators available on eBay that on measuring look like they could be used in the T160, just wondering has anyone done this and did it improve the feel/effort, as the std clutch is quite heavy.
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678411
12/20/16 9:10 am
12/20/16 9:10 am
Stuart Offline
Stuart  Offline
It shouldn't be - all my triples, I can pull the clutch lever with one finger at least a few times for demonstration purposes; two fingers and I can pull the levers all day (I used to live in pre-M25 London and cross north-west to south-east and return regularly). I also have a T100 and none of my triples' clutches are noticeably "heavier" than the twin's clutch.
Usual culprits for a "heavy" triple clutch are the cable (I work on - off the bike - after cleaning and lubing, the inner should slide through the outer under its own weight, or I replace it) and/or worn handlebar lever pivot. Or a p.o. might've installed a 'heavier' spring to 'cure' clutch slip.
There has been much recent discussion on the TOL forum about "plate thickness", "basket heights", yadda, yadda; if you'd like some light Christmas reading while Strictly Mincing or whatever is on, try typing "clutch" into the TOL Advanced Search and wading through the returned links ...
The triple clutch can be a problem item, but ime much can be done before hydraulics are the 'solution'.
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678420
12/20/16 11:27 am
12/20/16 11:27 am
Norfolk UK
Norfolk UK
One result with "Hydraulic Clutch" in the content, by yourself, the cable is reasonable but not perfect, basic adjustment seems fine, will have a look in the manual for anything i have missed,
However the question still stands, i would like to hear from anyone who may have used the eBay type slave in a conversion?
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678424
12/20/16 11:47 am
12/20/16 11:47 am
Not heard of one being used on a Trident but there is a report on the NOC about one being used on a Norton Commando.
http://www.nortonownersclub.org/noc-chat/general/499829127?b_start=0#868663213
Not as easy as it looks but I have seen one on a Triumph Cub which works very well but there is not a lot left on the cub you would recognise as being cub like wink
Back to the hydraulic clutch. Spent some time shortening the slave cylinder thread to ensure it's not up against the rear isolastic tube. Shortened the rod and re-threaded it (2mm x 0.4mm) slimmed down the screw on nipple to fit the fork in the gearbox. Struggled to bleed the system as I had to undo the banjo screw to align the pipe. Finally I just couldn't get enough travel on the rod to properly release the clutch, so gave up. I may re-visit this with a larger master cylinder from a Honda to match the brake lever, or try and get more movement out of the existing setup by more meticulous bleeding.
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678426
12/20/16 12:15 pm
12/20/16 12:15 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I have not tried that particular type. I make these:
The hydraulics eliminates the cable friction. Mine also automatically adjusts for clutch disc wear.
I had someone ask for a master using the T160/T140 master brake mount and lever which requires a different cylinder bore. I am testing this one:
The hydraulics are not going to fix other problems such as the pressure plate binding.
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678435
12/20/16 1:05 pm
12/20/16 1:05 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #678437
12/20/16 1:46 pm
12/20/16 1:46 pm
Norfolk UK
Norfolk UK
Thanks fellas, but 165 vs 7 for a slave is going to be a no contest for an experiment....anyway where is he challenge in fitting an existing kit. wink
Had a look at the Commando conversion and think that the travel may be the only bug to fitting, but you don't know until you try as they say.
Re: Hydraulic Clutch conversion? [Re: Tricky-Dicky] #689623
03/27/17 6:10 pm
03/27/17 6:10 pm
Norfolk UK
Norfolk UK
Update for this one too, i have fitted one of these Chinese cheapys, and it appears to work fine, there is enough movement to disengage the clutch OK, as per the original cable/leaver combination, did need to find a 19mm master cylinder in order to shift enough fluid, and its still a bit heavy, but then i do still have a clutch problem, i am suspecting the plate maybe warped.
