Jim Hultman
Jim Hultman
Minnesota, US
31 registered members (Alan_nc), 195 guests, and 464 spiders.
PreunitPeter, Tcycles, Metalguru, hanscarlsson, BSADon
10221 Registered Users
Stuart 109
Lannis 108
NickL 73
582,262 mail-order LSR
Topics66,861
Posts648,584
Members10,221
T100R carb problems #688651
03/19/17 5:59 pm
03/19/17 5:59 pm
New York
Joey Y Offline OP
Joey Y  Offline OP
New York
So I posted on here a few weeks ago about picking up a T100R. Anyway-I did. I also thought it would be a good idea to fix something that wasn't broken and go ahead and clean out the carbs/fuel system since the bike was running good, but has been sitting.
When I took the carbs apart, I noticed everything internally was scored, the casting of the bowls and body wasn't mating nice, the gaskets were shot. Anyways $40 dollars and 12 hours later after going through the carbs over and over and over, I couldn't get them not to piss gas, deprive the bike from fuel, and leak all over the place. Due to their extremely poor condition to start with, I said [censored] it, and bought brand new AMAL 626's
I'm running the exact same set up on a bone stock bike - 150 main, 106 needle #3 cutaway, here are the carbs I purchased:
https://www.classicbritishspares.co...set-triumph-bsa-500-t100r-a50-l626-r626a
Same style bars same throttle cable. However I can't set the carbs up. The idle screams at all positions. 1 1/2 turns out on the air mix and starting between 1 and 2 on the main idle.
I need a sanity check. Is this a throttle cable issue? Something pinched. Do these new 626s require a different longer cable? Someone tell me how I'm screwing up simple carbs, thanks in advanced
1969 TR6R
1966 BSA A65
Re: T100R carb problems [Re: Joey Y] #688654
03/19/17 6:09 pm
03/19/17 6:09 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
http://www.jba.bc.ca/Bushmans%20Carb%20Tuning.html
Try lubing the cables and greasing the throttle. Let the cables hang off throttle and see if the outer covers move easy.
Re: T100R carb problems [Re: Joey Y] #688662
03/19/17 6:48 pm
03/19/17 6:48 pm
Stuart Offline
Stuart  Offline
Hi Joey,
Have you taken off the air filters and checked with a Mk.1 eyeball that the slides are reaching the bottom of the bodies when the throttle is 'closed'?
I notice the carbs. in CBS's picture has cable adjusters for both throttle and choke cables; did the original carbs. have adjusters in the carb. tops for the throttle cables? If not, and you haven't changed the cables, that could be your problem?
AMAL Premiers have a removable pilot jet; you aren't 'adjusting' the pilot jets thinking they're the air screws?
Premiers have been known to have swarf in them when brand-new; facepalm you might have to strip them and blow through all pilot passages and jets ...
Originally Posted by Joey Y
#3 cutaway,
While it isn't likely to have anything to do with the existing problem, when you start using the bike, you might find these are too rich; they're what was specified nearly half-a-century ago, and we don't have the same fuel ...
Re: T100R carb problems [Re: Joey Y] #688663
03/19/17 6:48 pm
03/19/17 6:48 pm
New York
Joey Y Offline OP
Joey Y  Offline OP
New York
Still the same. Couldn't be from removing the choke right? Never had choke on my old carbs either so I took out the block and put the stopper in the top. I feel like this has to be a cable issue. The bikes screaming when it starts up
1969 TR6R
1966 BSA A65
Re: T100R carb problems [Re: Joey Y] #688679
03/19/17 8:31 pm
03/19/17 8:31 pm
New York
Joey Y Offline OP
Joey Y  Offline OP
New York
Stu
Thought about that too. I put the old carb tops one where the cable just fits in there on the new amals so that eliminates the issue. I also have the slides not reaching the bottom of the bodies, there is a gap...I have them set off the idle screw 1.5 turns in from when the slide starts moving up. Should there be no gap at all?
1969 TR6R
1966 BSA A65
Re: T100R carb problems [Re: Joey Y] #688686
03/19/17 10:56 pm
03/19/17 10:56 pm
Tampa, Florida
GTSRider Offline
GTSRider  Offline
Tampa, Florida
One thing I did on my 71 T100R was to convert the dual cable off of the throttle, to a single cable ,
connected to the plastic cable splitter used on T140's .
The carbs connect to the splitter , and then the one single cable to the throttle.
....low cost modification that seems to work well. I siliconed everything , and the action is very smooth !
GTSRider
Hudson Valley , NY
82 T140ES
76 TR7
71 T100R
PM
Re: T100R carb problems [Re: Joey Y] #688750
03/20/17 12:39 pm
03/20/17 12:39 pm
Stuart Offline
Stuart  Offline
Hi Joey,
Stu
Just to be clear:-
. "1.5 turns" applies to the air screw - horizontal opposite the pilot jet. You unscrew it "1.5 turns" from fully-seated as a starting point for tuning.
. The idle screw is the one that points upwards into the body at about 45 degrees. You set that wherever for your desired idle rpm. If you've set these to "1.5 turns", unscrew 'em completely, screw in any and all cable adjusters and check that the slides are then hitting the bottoms of the bodies when the throttle is closed. Then start the engine and, if the engine isn't "screaming", raise the slides with the throttle 'til the engine is a little above "your desired idle rpm", screw in the idle screws 'til the idle rpm doesn't drop when you let go of the throttle, then lower the rpm to "your desired idle" by unscrewing the idle screws the same small amount each at a time.
Once you've balanced the carbs., you might have to alter the idle screws position "for your desired idle rpm".
Re: T100R carb problems [Re: Stuart] #688754
03/20/17 12:55 pm
03/20/17 12:55 pm
Bishop, Calif.
Bishop, Calif.
Re: T100R carb problems [Re: Joey Y] #688777
03/20/17 6:50 pm
03/20/17 6:50 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Whatley's Second Law of Brit Bikes: A man always buys a Brit bike with one more carburetor than he is capable of tuning.
laughing
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: T100R carb problems [Re: Joey Y] #688831
03/21/17 2:41 am
03/21/17 2:41 am
New York
Joey Y Offline OP
Joey Y  Offline OP
New York
Ok..so thanks for all the responses. Updates:
Got the bike fired up. 1 1/2 turns out on the air screws, then from the lowest possible point the slide goes, right to where it starts engaging with the idle screw 1 1/2 turns in. Main is 150, needle is 106, slide is 3, needle clip is 1, no choke, left AMAL premier float height as I got it. Totally stock 72 T100R. The bikes running idling and accelerating, not running amazing but at least it's a step the right way. It definitely isn't ready to ride yet though. The thing runs in first and idling in the garage, but when I come out of 2nd gear the bike dies. It almost seems like a lack of fuel to the carbs. I noticed premier carbs have a smaller looking fuel hookup on the bowl, so I ran 1/4" line versus 5/16". I also put my stock Concentric carb tops and springs in the new premiers to accommodate to my old throttle cables not having the thread to thred into the Concentric head. Could either of these be the reason for that dying out? I'm thinking that or something with the clutch got out of wack randomly (separate issue?) Also I've been reading about the "new" pilot screw on these new premiers should I touch this?
1969 TR6R
1966 BSA A65
Re: T100R carb problems [Re: Joey Y] #688835
03/21/17 5:02 am
03/21/17 5:02 am
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
Have you balanced the throttle slides?
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: T100R carb problems [Re: Joey Y] #689400
03/26/17 2:15 am
03/26/17 2:15 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Except for a few preliminary settings, tuning of the carbs cannot be done until every other tune-up spec is met.... ignition timing verified, valves set, plugs cleaned or replaced, plug wires checked, plug caps checked, etc, etc.
This is a common mistake people make.
RF Whatley
Cornelia, GA
Re: T100R carb problems [Re: Joey Y] #689404
03/26/17 2:55 am
03/26/17 2:55 am
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
When I install an AMAL I first look at the motor side and put a .040 wire under the slide and adjust the throttle stop screw so it just releases the wire. It is a good starting point. Should give a good idle. It also helps to mark the screw position on the carb body so you can return to it.
