Jim Hultman
Jim Hultman
Minnesota, US
31 registered members (Alan_nc), 195 guests, and 464 spiders.
PreunitPeter, Tcycles, Metalguru, hanscarlsson, BSADon
10221 Registered Users
Stuart 109
Lannis 108
NickL 73
582,262 mail-order LSR
Topics66,861
Posts648,584
Members10,221
Page 2 of 17 1 2 3 4 16 17
Re: What did you do to your bike today --join in [Re: chris l] #683840
02/05/17 5:55 pm
02/05/17 5:55 pm
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
New Premiers for the t150
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: What did you do to your bike today --join in [Re: chris l] #683841
02/05/17 6:06 pm
02/05/17 6:06 pm
kevin roberts Offline
fefsa
fefsa
thought i'd have the 1965/66/71/72 tbolt off the lift. it's been up there for ages with dead points while i did other stuff. just had a few minutes, so i glued the primary cover on. tomorrow i'll attach the footpegs and controls and so on.
this bike is a 66, with a bitsa 72 or so motor. it has an old un-sealed stator, with various wires exposed to the interior elements. glued them in place with a great gob of silicone, so we'll see if the electrons stay where i want them.
gasket cement only on the cover side of the gasket, so that i can grease the other side and just drop off the cover now and again for messing about in there.
if i get this thing off the lift tomorrow the LSR goes on so i can pull the motor and refit the new cylinder head.
live every day.
die once.
Re: What did you do to your bike today --join in [Re: chris l] #683856
02/05/17 9:32 pm
02/05/17 9:32 pm
Got in a short ride on Tuesday, barely past the first oil change after the rebuild.
I had planned to check the head torque and set valves today. But I didn't get to bed until 9 this morning, no daylight by the time I got up.
I did have enough time to seal and tighten up the left exhaust though. Can't have leaks there.
Good thread. The Motobrick forum has one too.
Re: What did you do to your bike today --join in [Re: chris l] #685446
02/20/17 4:32 am
02/20/17 4:32 am
Short ride again today. Still pissing oil from the line to the OP gauge. I upgraded to a nice braided line, but the fitting on the line is for a flare, not the straight NPT which all gauges have on the back. Might need to revert to the cheap plastic line. For some reason, two adapters and compression fittings don't leak, but a straight line to the gauge does.
I suppose that a washer with one convex surface and one flat would fix this, but nobody makes one.
Re: What did you do to your bike today --join in [Re: chris l] #686831
03/05/17 2:50 am
03/05/17 2:50 am
OP gauge sussed.
Today I converted the levers to cable on the Mikuni starting jets. I used a British choke lever and made the cables to length. Also installed new petcocks which result in more clearance under the tank to route fuel lines.
Supposed to be in the 60s (19c) tomorrow. laugh laugh
Re: What did you do to your bike today --join in [Re: DavidP] #686842
03/05/17 6:14 am
03/05/17 6:14 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
I was gettin' stuff done and moving stuff around in the garage ...,and
I closed the garage door on the back (ABS) fender of my wife's little scooter ..., again
She is outa town so I have a few days to cover my ass .
If I click the crack back together and tape it in place , I can fiber glass the fender from the under side ... again
The crack when fixed , from the visable side will almost disappear if I do it right .
Re: What did you do to your bike today --join in [Re: chris l] #686948
03/06/17 12:20 am
03/06/17 12:20 am
fefsa
fefsa
got the LSR on the lift and shortened the carb mounts to mock up the tube tanks
looking to lower the height so i can actually lie down on the top tube.
live every day.
die once.
Re: What did you do to your bike today --join in [Re: chris l] #686969
03/06/17 3:12 am
03/06/17 3:12 am
Tridentman Online content
Tridentman  Online Content
Figured out how to convert a T160 with US bars and a Mickey Mouse burnt out front brake switch to UK bars with a hydraulic front brake switch as per a 1979 twin.
Re: What did you do to your bike today --join in [Re: Tridentman] #687043
03/06/17 8:40 pm
03/06/17 8:40 pm
Calling that stupid nylon switch Mickey Mouse is an insult to Disney. laughing
Re: What did you do to your bike today --join in [Re: chris l] #687893
03/12/17 11:56 pm
03/12/17 11:56 pm
Sunny South Carolina, (US)
T140V-Rich Offline
T140V-Rich  Offline
Wonderful thread.
Covered and recovered the Bonnies in the shed while our winter arrived in the Deep South. Snow in the Upstate, rain for us.
Rich
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: What did you do to your bike today --join in [Re: chris l] #687928
03/13/17 4:28 am
03/13/17 4:28 am
Mark Z Offline
Mark Z  Offline
Installing a Tympanium rect/reg on my A65. Mounting plate is built and painted, tank's off, seat's off. Yesterday removed the battery and old generic rectifier and dismantled all the wiring in that area in preparation for re-wiring.
Re: What did you do to your bike today --join in [Re: chris l] #687946
03/13/17 8:31 am
03/13/17 8:31 am
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
Rode the TR6 to work and back in the pissing rain. Cant work out why enjoy riding in the rain so much?
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: What did you do to your bike today --join in [Re: chris l] #687958
03/13/17 10:52 am
03/13/17 10:52 am
You must be a Brit!
Re: What did you do to your bike today --join in [Re: Tridentman] #687959
03/13/17 11:05 am
03/13/17 11:05 am
Boston, Massachusetts, USA
kurt fischer Offline
#irideslow
#irideslow
Moved the bikes around and put the garage back into winter configuration, that is, made space for the car, in advance of tomorrow's winter storm (12"-18" snow predicted, wind gusts past 50 mph).
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: What did you do to your bike today --join in [Re: kurt fischer] #687968
03/13/17 12:24 pm
03/13/17 12:24 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Major rebuild, see my post I'm about to start in projects.
Part way through it looked like this:
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: What did you do to your bike today --join in [Re: chris l] #688054
03/14/17 1:02 am
03/14/17 1:02 am
Mark Z Offline
Mark Z  Offline
Brizzo, what is that chainguard you have on? I tried to run a '67 chainguard on my '70 frame, but it doesn't fit right - the chain hits the top of the guard at the front and keeps splitting it. When I tried to source a used '70 chainguard, my used parts man said that the part numbers are the same '67-'70. But your chainguard looks different from my '67.
Re: What did you do to your bike today --join in [Re: Mark Z] #688073
03/14/17 10:21 am
03/14/17 10:21 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Hi Mark,
That chainguard is from Burton Bike Bits in the UK. A 1969-1970 type. Has the extra stay that came on the 69/70 guard which think probably was added as a response to fatigue cracking. This is my second guard as I find they do crack around the mounting bolts. I ordered the black, but they sent chrome. Bit 'blingy' for me. No issue with the chain, but the bottom does contact on the swing arm. If it was black I would have filed it and repainted.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: What did you do to your bike today --join in [Re: Mark Z] #688074
03/14/17 10:21 am
03/14/17 10:21 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Hi Mark,
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: What did you do to your bike today --join in [Re: chris l] #688134
03/14/17 8:02 pm
03/14/17 8:02 pm
chorley ,lancashire ,uk
chris l Offline OP
chris l  Offline OP
Well over the last few days have ordered and received new swing arm bushes.My goodness that pin takes some getting out.Started with a small hammer and ended up with the lump hammer and ruined a socket and socket extension trying to drift it out.
Once the swing arm was off decided to give it a lick of paint ,and clean all the fasteners whilst it was accessible.
Then a schoolboy error ,scratched the chain guard re building it so had to re paint that .
Its all back together now and hoping for some good weather to go for a spin on the weekend.
Glass half full
Re: What did you do to your bike today --join in [Re: chris l] #688390
03/17/17 7:19 am
03/17/17 7:19 am
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
Well, riding to work on Wednesday I suddenly found myself without first and second gear. I made my way to work with just third and fourth. I say suddenly but I had noticed an occasional problem selecting down to first and had started last week by dropping the oil to see if any lumps of gear fell out. Oil was heavily contaminated with water so I flushed it a few times and re filled it. I think we can blame this one on neglect on my part.
Not unexpectedly I found some very rusty and one broken spring when I pulled the outer cover off. Lots of cleaning later and the new springs arrived on Thursday so I could reassemble and ride the bike home after work. Today on my afternoon tea break I decided it deserved a quick wash.
Rod
Re: What did you do to your bike today --join in [Re: chris l] #688721
03/20/17 6:06 am
03/20/17 6:06 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Last week I removed the speedometer from my '64 TR6R and sent it off for repair. It has worked perfectly and is very accurate, but the reset for the trip meter had started to act up. I like to reset that each time I fill up with gas. It is back on the bike already, with the correct mileage retained on the odometer as per my request.
I cannot possibly say enough good things about Scott Thomas, the craftsman who did this repair and turned it around the same day he received it. The gage is like new. If you have any Smith Gage to be redone, this is the number one place to go.
I blurred the ad a bit when I scanned it. If you can't read the contact info, it says:
ph. 224-595-2037
scott@smithgagerepair.com
PO Box 182, Arlington Heights, IL 60006-0182‚Äč
bigt
Re: What did you do to your bike today --join in [Re: chris l] #688833
03/21/17 3:24 am
03/21/17 3:24 am
Mark Z Offline
Mark Z  Offline
Wiring in my new Tympanium rect./reg. Figured while I was at it, I'd upgrade to a 21st-century fuse holder.
Re: What did you do to your bike today --join in [Re: Mark Z] #689243
03/24/17 8:26 pm
03/24/17 8:26 pm
NJ
jhays79 Offline
jhays79  Offline
NJ
Tried again to get my recently ground crankshaft completely clean before I start re-assembly. Everyday this week I've been letting it soak in a clean white 5g bucket filled with a 50/50 mixture of diesel and gas. The dirt and grit just doesn't seem to stop coming out. Today I gave it another soak and I seem to be gaining a little ground with it. I'm not going to just say, "ah, that's good enough" though. When it's clean it's clean regardless how long it takes.
Re: What did you do to your bike today --join in [Re: chris l] #689273
03/25/17 2:27 am
03/25/17 2:27 am
Removed the float bowls from the Mikunis to drain the results of last week's deluge. Spent an extra hour or more getting the bowls precisely positioned when putting them back on. The overflow tube in the bowl can interfere with float operation, causing either no fuel flow or never ending fuel flow.
Finally started her up near sundown.
No time to ride, had to clean and check the bus for the long trip to New Orleans tomorrow.
Re: What did you do to your bike today --join in [Re: chris l] #689392
03/26/17 1:25 am
03/26/17 1:25 am
fefsa
fefsa
lol
pulled out the 66 A65 bitsa to go for a ride and kicked her over. . . gently . . . and busted the kickstart return spring,
back to the stinking buell, for crying out loud.
i am disgusted that my harley works so well.
i blame hillbilly bike.
live every day.
die once.
