umjwh
umjwh
Lowell, Ind
36 registered members (Andy Higham), 237 guests, and 391 spiders.
blayde54, Davenz13, Sean65, Rerock, pkuzyk
10477 Registered Users
NickL 83
franko 75
Triless 61
748,064 mail-order LSR
Topics68,836
Posts670,477
Members10,477
JP pistons Australia ....any good? #688443
03/17/17 8:49 pm
03/17/17 8:49 pm
Auckland NZ
Ignoramus Offline OP
Auckland NZ
i am going to have to replace pistons in A10 std . Ive heard mixed reviews about JP pistons some say they are great, some say they are junk
any comments from those who have used them successfully or other wise ?
I will likely go for the semi dished (medium compression option) or stick with whats there fully dished lowest compression.
Thanks Guys
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688446
03/17/17 9:45 pm
03/17/17 9:45 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
The JP Pistons I have handled are massive and heavy compared to any other similar pistons. I have said they are good for driving in tent stakes if short a hammer. Looks like they were milled out a big block and a bit too much material was left behind. They will definitely change the balance. And folks have absolutely nothing good to say about JP rings. The lumps I have seen are over 10 years old so I don't know if JP has improved since then.
Re: JP pistons Australia ....any good? [Re: Peter Quick] #688486
03/18/17 6:46 am
03/18/17 6:46 am
Sydney, Oz
Shane in Oz Offline
Shane in Oz  Offline
Sydney, Oz
JP appear to cast pistons to the maximum oversize and then machine them down for the lesser oversizes and standard, so the weight depends on the oversize.
On the plus side, they will make weird and wonderful pistons if somebody can provide an old example for a pattern, which was great for my Sloper.
I think A10 Std pistons are still available from other manufacturers, so worth looking for alternatives.
As far as JP rings go, they may not be a problem on 2-ring pistons such as the Sloper.
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688499
03/18/17 10:40 am
03/18/17 10:40 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Ig,
In the feedback I've seen and the conversation with only one owner who used them (500 Dominator) best steered clear of if possible it seems
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: JP pistons Australia ....any good? [Re: Shane in Oz] #688500
03/18/17 10:47 am
03/18/17 10:47 am
BSA_WM20 Offline
BSA_WM20  Offline
Yes I have used JP pistons on several cars & bikes without problems.
Weights do seem to vary a bit, some can be lighter than originals while others are heavier.
AS for the rings, totally unsuitable for use in a British Iron bore, they will take a long while to bed in if at all.
A friend runs JP's in his Douglass, C10 & G14 ( one only in the twin ) without any problems after he fitted proper rings.
I have on in the M20 right now and I had one in a WDB40, both worked fine .
They are cast so not as good for hard use as JE's but for every day riding absolutely fine remembering that the crank will most likely need to be rebalanced.
We had this out on another forum and it ended up the JP was the closest to Std weight, but that was more good luck than anything else.
I would have though that you could get Std A 10's in the shaky isles without much hassle .
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688544
03/18/17 7:49 pm
03/18/17 7:49 pm
Auckland NZ
Auckland NZ
Interesting comment about the rings being no good ...........thats what ive been told . Trevor : you cant get much here these days , our biggest and best supplier has gone down hill recently.
I hadn't even thought about the weight issue , but considering how much more work it is to balance the crank than just do the pistons I will probably just cross my figures and put whatever pistons i get straight in and see how it runs ,,, if no good i will then do the balance act.
Looks like no one is that keen on JPs so far ........
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688710
03/20/17 3:19 am
03/20/17 3:19 am
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
I heard JP pistons are usually heavy?
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688733
03/20/17 9:15 am
03/20/17 9:15 am
BSA_WM20 Offline
BSA_WM20  Offline
British Spares were never much chop with BSA stuff & I stopped ordering from them in the 80's after 3 wrong shipments in a row.
Even worse was the excuse, "some on put the new parts in the wrong bin".
If you don't know what the parts look like you should not be selling them.
I think I still have some credit slips from them somewhere.
BJ's bike bits in Qld are good and Mike Reily is even better and he for sure will have std A 10's in stock with good rings.
Re: JP pistons Australia ....any good? [Re: Ignoramus] #688792
03/20/17 8:34 pm
03/20/17 8:34 pm
Auckland NZ
Auckland NZ
Trevor ive had (untill the last few years) good success with british spares but their stock is way diminished these days ............will try the place you quoted in QLD cheers
