Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,879 guests, and 585 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,307 mail-order LSR
Topics65,693
Posts634,977
Members10,027
Page 4 of 5 1 2 3 4 5
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #671521
10/19/16 3:54 am
10/19/16 3:54 am
Could someone explain please why la -y does not relate to 67 as indicated by bsa docs within uk?
The BSA owners club is UK focused and does not worry about what happened in the US despite the majority of BSA's output going to the US.
There is a really long thread on this board which explains more but can't find it. In short if it has a -Y but a 67 number but has 70 parts its a 70. There may have been a 1000 67 A65's that were made and had to be re-exported but there is more to the story than the BSAOC has on their website.
Just to confuse matters more there are 70 bikes stamped with a Y not -Y but that is a reference to extended warranty.
Re: 1970 Lightning "Y" Bike Project... [Re: Ian T] #671523
10/19/16 6:05 am
10/19/16 6:05 am
Stuart Online content
Stuart  Online Content
Hi Ian,
Firstly, welcome to the Forum. smile
Originally Posted By Ian T
bought an unregistered lightning USA which is virtually identical to Kev's. It has matching numbers a65la10997 y. I'd like to know what year it is. The us title says 1970
Contributors to this thread suggest la65 -y relate to 1970
Note there is a significant difference between "-Y" (Dash Y) and just "Y". The thread "kommando" couldn't find is http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=403236#Post403236, be prepared to be there a lo-on-ng time ... and note there will be short test afterwards. grin
various clues on the bike indicate its later than 67 : 2 screws on metal tank badge; twin leading front brake; bsa 'watermark' on engine numbers tag.
Are the engine numbers and "bsa 'watermark'" stamped into a 'pad' raised above the surrounding crankcase metal? Are the nuts holding down the barrel base to the crankcase 12-point rather than normal 6-point, does a 1/2"AF 12-point ring spanner fit (ignoring that the barrel material might be a bit close for just any spanner to fit completely), are the studs into the crankcase 3/8" o.d. and threaded UNF? If so, more clues it's more-likely '70 rather than '67.
the vintage mcc dating gurus say It left the factory 5 Jan 1967 which concurs with bsa oc info posted online which says A65 LA relates to 1967.
Bantam John (bsa parts specialist in uk) tells me the bike probably had a replacement bsa engine at some point with bsa dealer restamped engine number to match the frame.
As the saying goes, "Denial ain't only a river in Africa" ...
Re: 1970 Lightning "Y" Bike Project... [Re: Stuart] #671535
10/19/16 9:28 am
10/19/16 9:28 am
U.K. Midlands
Ian T Offline
Ian T  Offline
U.K. Midlands
Thanks for your replies guys.
OMG! I didn't realise all the discussion about LA Y bikes! How complicated. The answer to all your Q's, Stuart, are 'yes' therefore it looks as if my bike is a 1970 bike after all which concurs with the US title. I have actually applied to BSAOC dating officer for a dating letter so I will wait with interest. Hopefully thereafter I can start the uk registration process.
Thanks for your help guys. This looks like a great forum! I'm going to post a separate message about gearbox cluster removal...
Sunbeam S7 Deluxe 1949
Honda CB750 K3 1972
Suzuki GT500 1977
BSA A65 Lightning LA Y 1970
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #671550
10/19/16 1:15 pm
10/19/16 1:15 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
We need pictures, just so you know.
and welcome
So another Y bike, we will soon have enough for our own sub section bigt
1950 Vincent Comet
1952 Norton Special
1963 BSA Super Rocket
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado x2
2009 Triumph Bonneville (now sold)
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #671564
10/19/16 4:51 pm
10/19/16 4:51 pm
Allan Gill Online happy
Allan Gill  Online Happy
Ian, if you take the seat off and look at the bolt mounting brackets, this will tell us a lot, 69/70 frames had different seat brackets to 67/68 and pre 67 had them different again.
Some 69/70 frames had fairing tubes welded to the headstock, this wasn't on earlier frames and all 69/70 frames were fitted with a swing arm which had bronze bushings and not rubber silent block bushes, the swing arm bolt was also solid where as the earlier ones were hollow.
As already mentioned, all 70 engines had a bsa embossed number block, as did most 69's but the very early 69's were on a raised block, but not machined flush or bsa stamped.
Re: 1970 Lightning "Y" Bike Project... [Re: Allan Gill] #671746
10/21/16 6:29 am
10/21/16 6:29 am
U.K. Midlands
Ian T Offline
Ian T  Offline
U.K. Midlands
Here are a couple of shots of the frame. The front of the seat doesn't latch onto a part of the frame - I wonder if this has broken off?
Do these photos help identify the year?
Thanks guys
Honda CB750 K3 1972
Suzuki GT500 1977
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #671747
10/21/16 6:32 am
10/21/16 6:32 am
gavin eisler Online content
gavin eisler  Online Content
3/8ths bihex barrel studs/nuts make it 1970.it will have a vertical clutch cable entry as well. The seat should have a pair of forks/ bracket at the front to engage with the horizontal bar at the rear end of the frame top tube.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #672322
10/25/16 1:56 pm
10/25/16 1:56 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
Top end should all be back together this weekend if I don't go to a Guzzi camp in Gloucester....
1950 Vincent Comet
1952 Norton Special
Re: 1970 Lightning "Y" Bike Project... [Re: Ian T] #672328
10/25/16 3:31 pm
10/25/16 3:31 pm
Texas Gulf Coast
Curmudgeon Offline
Curmudgeon  Offline
Texas Gulf Coast
I can see the remnants of the front seat bracket in the picture. It either broke off or someone cut it off.
I've had several A65 with the Y and from all my research they are '69, '70 specification even though the serial number suggests it's a '67.
reliccycles.com
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #672330
10/25/16 3:42 pm
10/25/16 3:42 pm
Mississauga, Ontario.
Adam M. Online content
Adam M.  Online Content
If you plan to put it together this coming weekend Kev, don't forget to anneal the gasket even when new, and cover it with copper cote both sides.
I hope the bottom of your head will be machined by SRM.
After you start riding, proper retorque is essential to keep your cylinders sealed.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673086
11/01/16 12:36 pm
11/01/16 12:36 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
My head having returned from SRM, was now ready to be fitted, and after a question asked in the competition section, I equipped myself with some copper sealant, and a pair of small o-rings, so I was ready to go.
Barrel and gasket prepared and ready for the head to be fitted..
Head looking good too..
bigt
1950 Vincent Comet
1952 Norton Special
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673087
11/01/16 12:40 pm
11/01/16 12:40 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
How do you guys torque the outer four head nuts, I can't fit a socket/torque wrench on these four, so have done them by "feel" using a spanner.
1950 Vincent Comet
1952 Norton Special
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673088
11/01/16 12:45 pm
11/01/16 12:45 pm
You can buy a "crowfoot" open-end wrench that has a 3/8" or 1/2" drive hole on it, mount it at 90 degrees to the shaft of the torque wrench so that the overall length is correct, and torque it that way.
I don't bother, though ... "feel" has always worked well for me. Have never had a head leak.
We're approaching the tipping point ... where those who vote for a living will outnumber those who work for a living .....
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673089
11/01/16 12:48 pm
11/01/16 12:48 pm
Get a 1/2" af ring spanner, weld a 1/2" drive adaptor to it use the wrench on this with the spanner at 90 degrees to the torque wrench.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673117
11/01/16 4:40 pm
11/01/16 4:40 pm
Looking good!
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673996
11/10/16 2:12 pm
11/10/16 2:12 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
Now where was I?
With the head all bolted down, and the rockers installed, it was time for some new SRM adjusters to be fitted...
Next on the list was refitting the exhaust system...
Now I have a couple of questions....
1. can someone tell me the thread size of the rocker cover head studs, the end that goes into the head. As I need to run a tap down the threads in the head.
2. I am after the part number for the oil tank drain/filter gasket.
Thanks.
1950 Vincent Comet
1952 Norton Special
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #673997
11/10/16 2:21 pm
11/10/16 2:21 pm
Centre studs are 1/4 BSF tapped in the ally.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #674020
11/10/16 4:36 pm
11/10/16 4:36 pm
Santa Barbara, Cal.
Bodger Offline
Bodger  Offline
Santa Barbara, Cal.
The pictures are well lit and in focus too, yay!
And the pipes are stock/original?
What is the latest opinions about the mushroom tappet adjusters?
Looking good kev!
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #674142
11/11/16 7:05 pm
11/11/16 7:05 pm
I'd use phenolic distance pieces between head and the carbs.
In town and in the traffic jam they can save your carbs from overheating.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #683578
02/03/17 5:50 pm
02/03/17 5:50 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
My little BSA has had to take a back seat for a while, I just can't find the correct forks for the bike, so it is just sitting on the bench until something turns up.
1950 Vincent Comet
1952 Norton Special
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #683690
02/04/17 3:52 pm
02/04/17 3:52 pm
Hi Kev,
Risking asking a silly question, you do know that '70 BSA forks are essentially the same as contemporary Triumph forks? The only really BSA-peculiar bits are the sliders; fit Triumph sliders - and ride the bike bigt - 'til the Beeza bits come along?
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #683712
02/04/17 7:40 pm
02/04/17 7:40 pm
Or leave the triumph sliders on and don't change them because they don't looks any different laughing
Re: 1970 Lightning "Y" Bike Project... [Re: Allan Gill] #683719
02/04/17 8:30 pm
02/04/17 8:30 pm
Hi Allan,
I did wonder ... I couldn't see any difference but, as most other '69/'70 forks part numbers are the same as Triumphs, I thought Small Heath must've given the sliders different part numbers for a reason I couldn't see ...?
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #683754
02/05/17 3:50 am
02/05/17 3:50 am
They could have their differences but as the wheel fits the same they look close enough for me not to be too worried if it was mine.
Re: 1970 Lightning "Y" Bike Project... [Re: Kev.] #683827
02/05/17 4:41 pm
02/05/17 4:41 pm
Royal Berkshire.
Kev. Online sick OP
Kev.  Online Sick OP
Royal Berkshire.
I can't find Triumph ones either, I ave been looking. I have the correct wheel now with 8" twin leading brake. One will turn up.
1950 Vincent Comet
1952 Norton Special
