Jack Adams
Jack Adams
Noblesville, IN
25 registered members (Alan_nc), 185 guests, and 374 spiders.
Nomdegom, Andy Mac, kwbikr, RandomTask, George Henstorf
10379 Registered Users
Mori55 94
NickL 84
Stuart 83
DavidP 79
reverb 73
Triless 68
687,952 mail-order LSR
Topics67,995
Posts661,427
Members10,379
1971 T120R Head Bolt Kit #681765
01/18/17 11:25 am
01/18/17 11:25 am
New York
gioleo123 Offline OP
New York
I am planning on getting my Bonneville back on the road. I would like to swap out the inner head bolt washers with the larger 82-2184 washers as used on the outer head bolts. I understand this is pretty much a must do item.
I figured while I have the rockers off, it would also be an ideal time to update the head bolts to the later T140 style for ease of torqueing the head in the future. John Healy, I believe mentioned he supplies a kit for this. I have done a search but can not find it anywhere. Does anyone know if such a kit still exists and who sells them?
If not I am figuring updating to the 72 head bolts should do the same thing. I understand I would also have to swap out the rocker bolts to the shouldered version. Thanks in Advance!
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681819
01/18/17 6:37 pm
01/18/17 6:37 pm
JubeePrince Offline
JubeePrince  Offline
I'm not aware of a kit, but it should be easy enough to do. Did they already convert the threads from CEI to UNF in '71?
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681821
01/18/17 6:53 pm
01/18/17 6:53 pm
San Rafael, Ca.
BikeVice Offline
BikeVice  Offline
San Rafael, Ca.
His business is a wholesale distributor called Coventry Spares. You could call him and see if he still produces the kit. I'm sure he could recommend a dealer in your area and send them one if so.
Yes, both the 1972 bolts and the T140 style studs will require shouldered rocker box bolts and they're different. 5/16" for the 1972 and later 650's and 3/8" for the T140.
Eric
1971 T120RV (R.I.P.)
1973 T140V/TR7
1993 Ducati 900 SS
Re: 1971 T120R Head Bolt Kit [Re: JubeePrince] #681822
01/18/17 6:58 pm
01/18/17 6:58 pm
San Rafael, Ca.
BikeVice Offline
BikeVice  Offline
San Rafael, Ca.
The 650's were CEI through the end of production. The kit studs are CEI on one end and UNF on the other. I remember reading the thread about these studs when they first started producing them. The prototypes were early 650 inner head bolts with the heads cut off and the blank ends then threaded UNF.
Eric
1973 T140V/TR7
1993 Ducati 900 SS
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681903
01/19/17 1:46 pm
01/19/17 1:46 pm
New York
New York
Thanks, Bike Vice and JubeePrince for the replies.
I will reach out to John Healy to see if the stud kit is still being manufactured.
From John's previous reply on an earlier thread:
'The kit consists of 4 new heat treated head studs - one end threaded CEI and the other UNF; four T140 head nuts and four thicker hardened full size head bolt washers which have provisions for "O" rings. The "O" rings help keep oil from flowing down the head studs. Used with CovSeal rocker box gaskets it solves a lot of issues with the 1971-72 stock set-up'
It seems like a great solution to the problems associated with the original head bolt design.
My bike is very large mileage (>1400)so I am hopeful for a minimal depression, caused by the small washers, but you never know...
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681914
01/19/17 3:05 pm
01/19/17 3:05 pm
JubeePrince Offline
JubeePrince  Offline
Excellent info, Eric, thanks! beerchug
Somehow missed that one, b/c I usually pay close attention when John speaks. When it comes to these old bikes, I trust him explicitly and implicitly.
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681930
01/19/17 4:35 pm
01/19/17 4:35 pm
Tridentman Offline
Tridentman  Offline
Those studs sound very much like the original fittings for 1974 T120RVs.
When I restored mine there was nothing like it in the parts books.
Had to use the 72 T120 and 74 T140 and guesstimate the rest.
But certainly all CEI at the bottom and Unified at the top.
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681943
01/19/17 7:57 pm
01/19/17 7:57 pm
John Healy Offline
John Healy  Offline
I refrain from pushing my parts on this site. We have been supplying this kit (71-2362AK), and individual parts, to dealers for some ten years.
The kit includes the UK made hardened CEI-UNF stud (71-2362A), a thicker hardened washer (82-2184A) which includes a quad viton seal to replace the undersize washers that dent the head, and the factory nuts and rocker box bolt to replace the 1971-1972 ones.
Yes they are still available as kits or as individual parts.
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681952
01/19/17 9:18 pm
01/19/17 9:18 pm
New York
New York
Thanks John H,
As of yet I have only been able to find the washers with seal, 82-2184a. I will try searching for the studs/ kit using the parts number.
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #681954
01/19/17 10:00 pm
01/19/17 10:00 pm
Queensland, Australia
Tiger100 Offline
Tiger100  Offline
Moore's shows a listing for the kit (2nd from top on link below)
https://www.moorescyclecenter.com/response1.asp?partID=inner
Grant
Re: 1971 T120R Head Bolt Kit [Re: Tiger100] #682008
01/20/17 12:06 pm
01/20/17 12:06 pm
New York
New York
I checked in on Moore but it looks like he is out of stock.
I also checked in on some of the other site sponsoring venders but none seem to recognize the part numbers. I have a line on some 72 head bolts which should work well, not as slick as the kit, but along with the larger washers will accomplish my goals.
Thanks all
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #682012
01/20/17 12:49 pm
01/20/17 12:49 pm
JubeePrince Offline
JubeePrince  Offline
Check with Mitch Klempf?
http://www.klempfsbritishparts.com/
I'd call directly instead of perusing the online site....
Re: 1971 T120R Head Bolt Kit [Re: gioleo123] #682051
01/20/17 6:41 pm
01/20/17 6:41 pm
San Rafael, Ca.
BikeVice Offline
BikeVice  Offline
San Rafael, Ca.
Thanks all
Hopefully your source has the rocker box bolts as well. I recently had to buy 1. $10.00! I wouldn't want to have to buy 4.
Eric
1973 T140V/TR7
1993 Ducati 900 SS
