halmc
halmc
Tallahassee, FL
20 registered members (Alan_nc), 167 guests, and 102 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
DavidP 72
btour 66
690,426 mail-order LSR
Topics68,045
Posts662,084
Members10,387
Is this a C12? Happens to be my first BSA :) #6796
12/27/05 11:05 am
12/27/05 11:05 am
India
bsa_c12_india Offline OP
India
Hi! Everyone, I m new to this board, from India, I just brought a 250 CC BSA recently and after looking at some pictures, its seems that the model is a C12. I need your expert advice on the following :
1. Is this indeed a C12 or some other model?
2. Where can I get some pictures for a Single Seat ( Saddle type) So that I can get it fabricated in India. It would be very expensive for me to import it, besides im not sure if I can import such things at all smile
3. Same for the rear mudgard. Need to replace this one.
Waiting to hear from all fellow BSA Riders wink LEt me know if there is sometime I can help u with smile
The picture is here : http://img469.imageshack.us/my.php?image=dscn45711vq.jpg
Re: Is this a C12? Happens to be my first BSA :) #6797
12/27/05 12:28 pm
12/27/05 12:28 pm
Have a look at www.petersclassicbikeparts.nl/html/buddyseat_dualseat.html
He has several photo's and drawings of the seats in his shop.
Also check www.petersclassicbikeparts.nl/html/saddles_seats.html
for sadles.
regards from Holland.
Re: Is this a C12? Happens to be my first BSA :) #6798
12/27/05 1:22 pm
12/27/05 1:22 pm
Royal Berkshire.
Kev. Offline
Kev.  Offline
Royal Berkshire.
I would think you could get a Royal Enfield single sprung seat in India, that you could modify to fit, you may even be able to fit a RE rear guard.
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
1981 Harley FLH
2006 BMW R1200GS
Re: Is this a C12? Happens to be my first BSA :) #6799
12/27/05 1:36 pm
12/27/05 1:36 pm
gavin eisler Offline
It may be a C12 motor, but its a C11 frame, C12s were swingarm, the one in the pic is a plunger frame, and the motor could be a side valve C10 its hard to say.
Check the crank cases for numbers.
Pod
Re: Is this a C12? Happens to be my first BSA :) #6800
12/27/05 4:13 pm
12/27/05 4:13 pm
North East England
beezageezauk Offline
North East England
Hi there,
I agree with Pod, the bike in the picture looks like a sidevalve C10L to me. If you can locate the frame & engine numbers and put them on the board for us we should be able to determine the exact year and model. You will then have a basis to work from. I believe that there are quite a lot of BSA second hand parts available in India if you know where to look for them. What part of India are you from?
Beezageezauk.
Re: Is this a C12? Happens to be my first BSA :) #6801
12/27/05 4:14 pm
12/27/05 4:14 pm
British Columbia
hh Offline
hh  Offline
British Columbia
That's definitely a C10L which is a sidevalve (flat head) motor. It has an alternator in the primary case instead of a generator which puts it in the early fifties, probably about 1953. pod's advice is best. The engine numbers are on the left below the cylinder, and the frame numbers are on the left of the head stock, just in front of the tank. The solo seat you want was fitted to several models and is not a BSA specific seat, a Lycette I think. Here's a picture of the seat on a 1951 C11:
Note the different bottom end on this bike with a generator drive chain case, and the different top end which is the C11/C12 type overhead valve.
Re: Is this a C12? Happens to be my first BSA :) #6802
12/27/05 4:27 pm
12/27/05 4:27 pm
I found a C10 picture on
www.vintagebike.co.uk/Bike%20Directories/BSA%20Bikes/pages/BSA%20C10.htm
It's without plungers, but the engine seems to be side valve.
In the galleries part of that site is a C12.
Re: Is this a C12? Happens to be my first BSA :) #6803
12/27/05 6:03 pm
12/27/05 6:03 pm
India
India
hi ger, thanks for the links, I did check them out, and as kev mentioned, I can find local made sprung seats, but i m not very happy with the way the look. But if i dont find a old one lying here some where , I would probably buy those local made ones.
its the same with rear guard too, there are some local RE ones, but then may require some mods before i can use them.
thanks anyways smile
I am a bit confused now frown , the motor is indeed a side value. The frame number is dc 1051683 and enginer number is bc 1048941. the owner and the registration book says its a 56 model.
beezgeezauk, yes geting parts in india is relatively cheap and easy, but i m from a small town in west, so i have to go to north or bigger cities in west like mumbai to get them.
hh & ger, thanks for the pic, i did find it from my pervious searchs on google.
thanks for all ur help
Re: Is this a C12? Happens to be my first BSA :) #6804
12/27/05 9:34 pm
12/27/05 9:34 pm
North East England
North East England
I would say that your registration book is correct and your bike is a 1956 C10L. The frame numbers for this year were from DC10S-101 to DC10S- 2573 and the engine numbers were BC10L-7001 to BC10L-9611. So allowing for a slight mis-interpretation of certain letters and numbers it appears to be a genuine bike and probably still has its original engine.
The "5" in your frame number should be a "S" and the "4" in your engine number should be a "L". This happens quite often and is nothing to worry about. My "B31" is registered as a "S31" and BSA never produced a S31.
Good luck with the project and keep us informed of your progress.
Beezageezauk
Re: Is this a C12? Happens to be my first BSA :) #6805
12/28/05 11:00 am
12/28/05 11:00 am
India
India
thanks beezageezauk, i have something to work on with now. do u know any other members with similar bikes? and how much should it be valued at appoximately.
I have started the restoration, not on my own, but m geting it done thru a mechanic. Currently working on the rims and tyres and then will work on the engine smile
Re: Is this a C12? Happens to be my first BSA :) #6806
12/28/05 3:40 pm
12/28/05 3:40 pm
North East England
North East England
It is always difficult to value any machine because there are so many variations to be taken into consideration. These variations will depend on the condition of the bike, or the quality of the rebuild or even where the machine is located. All I can say is the humble C10L will not command a particularly high figure so don't let it run away with your money.
BTW, I believe that the rear mudguard on this model is the same as the Plunger 125cc Bantam so at least your search for that item should not be too difficult. Also the dual seat is correct for the 1956 C10L.
I know of a couple more guys in India who run BSA's, but not in your area. If I can find their personal information I will pass it on to you privately. They may be able to suggest suppliers of second hand parts. Beezageezauk.
Re: Is this a C12? Happens to be my first BSA :) #6807
12/28/05 3:45 pm
12/28/05 3:45 pm
India
India
thanks beezageezuk, I anyways dont intend to sell its, so doesnt matter much smile
Re: Is this a C12? Happens to be my first BSA :) #6808
12/28/05 4:10 pm
12/28/05 4:10 pm
Indy
Vox Teardrop Offline
Indy
Looks like a time consuming restoration. Good luck.
95' Triumph Speed Triple
72' Triumph T120
64' BSA Lightning Rocket
Re: Is this a C12? Happens to be my first BSA :) #6809
03/23/06 7:29 pm
03/23/06 7:29 pm
East Sussex
Bob Wilkinson Offline
East Sussex
Try this for a C10 with single saddle
Pics of my bike on BSAOC East Sussex Website which I run. http://www.geocities.com/eastsussexbsa@btinternet.com/c10
pics shown are of a C11 or C12 as these pic show rocker covers for an OHV arrangement, a C10 or C10L sidevalve, almost looks like a 2 stroke engine and head definatly looks like a two strokes head.
Easiest way to check is , if you can remove the head by simply removing the 4 head bolts without any rockers, valve etc, then it is a sidevalve.
Hope this helps
Bob Wilkinson
