The Bonneville Shop
Shadrach
Shadrach
Maryland
41 registered members (Adam M.), 250 guests, and 463 spiders.
10528 Registered Users
franko 90
NickL 66
785,221 mail-order LSR
Topics69,221
Posts674,282
Members10,528
Rotor Clearance #678236
12/18/16 9:57 pm
12/18/16 9:57 pm
USA
Dave M Offline OP
Dave M  Offline OP
USA
Fellas, what is the correct clearance between rotor and stator please?
69 T100R
If you have done this job I welcome advice on the proper workshop method(s) to adjust that clearance, stator studs into the case would seem a somewhat fragile attachment. Thanks.
66 TR6R Trophy
67 T120R Bonneville
68 BMW R60/US
69 T100R Daytona
91 Honda ST1100
Re: Rotor Clearance [Re: Dave M] #678241
12/18/16 10:45 pm
12/18/16 10:45 pm
Tampa FL USA
Sam Online content
Sam  Online Content
Tampa FL USA
I've always cut up a coke can which is .004 thick, doubled it up so it's is now .008 thick and place 4 pieces at 12, 3, 6,and 9 o'clock around the rotor and tighten the rotor onto the crank. If nothing is bent or out of line the four pieces of aluminum should slide out. I'm sure there are other methods to get this accomplished and someone will share it.
Re: Rotor Clearance [Re: Dave M] #678265
12/19/16 6:55 am
12/19/16 6:55 am
Stuart Offline
Stuart  Offline
Hi Dave,
69 T100R
Assuming original Lucas rotor and stator, 0.008" to 0.012" between rotor and stator coil cores, if they're proud of the potting around the inner circumference of the stator.
To fit, I use a similar method to Sam - I think I read it on this forum years ago. Only information I'd add:-
. If the stator coil cores do stick out a little from the stator potting, obviously(?) the shims need to be between them and the rotor.
. Make the shims big enough that, even when they're between rotor and stator, there's plenty sticking out to get a good purchase with pliers/vise-grips.
. If the stator isn't the same clearance all the way 'round, ime it's impossible to move the stator laterally with the rotor in place; otoh, if you remove the rotor before attempting to move the stator, you risk moving the stator too far ...
. I assemble rotor, stator and shims off the bike and then attempt to slide the whole assembly cleanly on to crank and stator studs at the same time. It must be "clean"; if fitting the stator pushes one or more studs in a particular direction, as soon as you remove the shims, the "pushed" studs will simply spring back into their original position, moving the stator relative to the rotor. cry
. Fitting rotor and stator together gives a better indication of which (if any) studs need 'tweaking' and the tweak direction.
. Yes, the process can be time-consuming and frustrating mad Otoh, if the virgin you sacrificed before starting really was, the process can work first time. :bigt
. Once fitted and shims removed, don't forget to turn the crank/rotor to different positions and recheck the clearances.
Re: Rotor Clearance [Re: Dave M] #678284
12/19/16 10:49 am
12/19/16 10:49 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Dave, Last year I put in a new Wassell stator and rotor. I've had an old brass feeler gage in the toolbox for many years. That made it easy to check clearance without the magnets trying to grab the gage. I had .012" clearance all around, and I turned the crank to check at about every 60° of rotation.
I didn't need to tweak the mounting studs at all, and there was really no wiggle room when installing the parts.
Good luck with it. I assume this is on your TR6?
Re: Rotor Clearance [Re: TR6Ray] #678286
12/19/16 11:41 am
12/19/16 11:41 am
USA
Dave M Offline OP
Dave M  Offline OP
USA
The 500 Daytona ran poorly this past Fall, Ray. The bike is a blast to ride except when lacking the power to climb even modest inclines. Problem found to be the 15 year old Lucas rotor slipping on it's center causing the timing marks to jump wildly when using a strobe.
Has Lucas improved this problem? Hoping so, I have seen rotors labeled as "welded".
I suppose 15 years is good service. facepalm
Sam and Stuart, thanks for your comments and help. A .008 feeler gauge will insert all around and at all crank positions.
Is a bit tight @ 9 o'clock but unless cautioned here, the britbike gods have smiled w/o the sacrifice! grin
66 TR6R Trophy
67 T120R Bonneville
68 BMW R60/US
69 T100R Daytona
91 Honda ST1100
Re: Rotor Clearance [Re: Dave M] #678369
12/19/16 9:48 pm
12/19/16 9:48 pm
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
I know I will get a lot of flack for this but.....If I can get at least .006 all around I'm somewhat happy. Almost all will have a varying amount of clearance all around the rotor. Instead of pushing and prodding the studs this way and that, which always takes oodles of time with middling results, I get out the Dremel tool with a drum sander and CAREFULLY remove JUST ENOUGH. Much quicker and works great. sometimes it is just the potting material I am removing. If it is the metal I am removing only .003. I suppose I might be losing a tiny bit of output but this is not a perfect world. This way I know that the stator will not shift back to its old position and fuse to the rotor.
Re: Rotor Clearance [Re: SEATTLE GS] #678434
12/20/16 1:00 pm
12/20/16 1:00 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
+1 I have done so before.
Re: Rotor Clearance [Re: Dave M] #678639
12/22/16 4:08 pm
12/22/16 4:08 pm
dave jones Offline
dave jones  Offline
I have done this, too. I followed the Roy Bacon way and filed metal off the pole pieces in the stator to get the right clearance which sounds like Seattle GS's technique. You can't take metal off the rotor because you may unbalance it or make it fall apart. Worked fine and is still charging fine.
Re: Rotor Clearance [Re: Dave M] #678670
12/22/16 9:15 pm
12/22/16 9:15 pm
South cone
reverb Offline
reverb  Offline
South cone
...so what s exactly the problem to have an small clearance in one side and more on the other? Still clearance...
The studs are straight and the stator fits perfectly well there.
I understand what Stuart is saying; I remember that I did something similar, but you never finish with a tight stud...so I fastened to the case but I have that variant in the clearance.
Re: Rotor Clearance [Re: Dave M] #678686
12/23/16 1:15 am
12/23/16 1:15 am
Qld, Aust and Otago,NZ
Ginge Offline
Ginge  Offline
I've got variable clearance too. Got it as close as I could, then tightened it up. May have tapped a stud with a hammer to convince it to stay there. I used the coke can trick as well.
Still runs a 55watt headlight globe. It's a Sparx unit not Lucas.
Same bike.
Ginge
Re: Rotor Clearance [Re: Dave M] #678778
12/24/16 5:09 am
12/24/16 5:09 am
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
there is nothing wrong with varying clearances around the rotor. Its the minimum clearance that's important. Too close and it is possible to weld the stator to the rotor. Much damage can occur.
Re: Rotor Clearance [Re: Dave M] #678813
12/24/16 3:06 pm
12/24/16 3:06 pm
John Healy Offline
John Healy  Offline
This cannot be over emphasized!
Over the years the unit construction model primary covers of many Triumphs have been hit in the front. This can bend studs and crankshaft. In this condition you can offer a new stator and rotor with the bent crankshaft facing toward the back (the same way the studs are bent) giving you the impression you have clearance. When you rotate the motor 180 the clearance will to go away. Now you get out your dial indicator and check the rotor to make sure the crankshaft isn't bent. It only takes a little bit to cause problems.
Beside a bent crankshaft there are several other reason the rotor can touch the stator with disastrous results:
Loose rotors - where the zinc casting has come loose from the steel center allowing the magnets to wedge outward. This is not something to play around it. The magnets sit on a portion of the steel center that has been cut in a hexed. Each one of the magnets sit on one of the flats. When the outer part of the rotor comes loose the magnets are forced outward. The looser it gets the closer it gets to the stator. In the worse case the whole unit explodes with magnets going here and there.
Failing drive side main bearing with too much clearance. This can cause the rotor to rub with similar problems.
Non-unit models are especially problematic. On a Triumph there are only three 1/4" screws holding the inner primary cover in place. When the inner cover comes loose the stator is allowed to drop onto the rotor.
Nortons have a similar problem.
Re: Rotor Clearance [Re: John Healy] #678895
12/25/16 4:41 pm
12/25/16 4:41 pm
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
And "bent crankshaft" = "scrap crankshaft"?
Re: Rotor Clearance [Re: Dave M] #678903
12/25/16 7:53 pm
12/25/16 7:53 pm
kevin roberts Offline
used ones aren't expensive
ebay crank
The study of the art of motorcycle maintenance is really a miniature study of the art of rationality itself. Working on a motorcycle, working well, caring, is to become part of a process, to achieve an inner peace of mind. The motorcycle is primarily a mental phenomenon.
/robert_m_pirsig_
Re: Rotor Clearance [Re: Dave M] #678908
12/25/16 8:33 pm
12/25/16 8:33 pm
John Healy Offline
John Healy  Offline
Straightening crankshafts is normal practice.
Re: Rotor Clearance [Re: kevin roberts] #678931
12/26/16 7:49 am
12/26/16 7:49 am
Running from demons in WNY
Hillbilly bike Online content
ebay crank
Yes cheap to buy and then cheap becomes expensive after machining the beat up right side oil feed and turning the crank to .010 as one journal is worn and the other larger than stock grin
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: Rotor Clearance [Re: Hillbilly bike] #678932
12/26/16 8:30 am
12/26/16 8:30 am
you're talking about that one i have by the workbench
/robert_m_pirsig_
Re: Rotor Clearance [Re: kevin roberts] #678935
12/26/16 9:40 am
12/26/16 9:40 am
That would include the cranks in my dual engine currency convertor..
And one of the cranks had to be straightened...It was done on specialized equipment, a sort of controlled peening procedure...
Re: Rotor Clearance [Re: Dave M] #678964
12/26/16 3:54 pm
12/26/16 3:54 pm
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
So I will reword it..."bent crankshaft" = "expensive crankshaft"
Re: Rotor Clearance [Re: SEATTLE GS] #678968
12/26/16 4:37 pm
12/26/16 4:37 pm
Not necessarily...it cost me 40 bucks to have the crank straightened...The shop was doing machine work on the two engines so the price might have been discounted a bit...
Re: Rotor Clearance [Re: Dave M] #678972
12/26/16 5:35 pm
12/26/16 5:35 pm
HawaiianTiger Offline
Should be included in the cost of nitriding the crank.
Re: Rotor Clearance [Re: HawaiianTiger] #678982
12/26/16 8:02 pm
12/26/16 8:02 pm
Nitriding was $116 for both cranks, it's priced by weight..One crank bent, one did not.The straightening is as needed I suppose..I had two other cranks treated in the last few years that didn't warp/bend...The bend was less than .002
The heat treating also caused the crank journals to grow slightly in diameter...About .0003 on the 1.6 inch rod journal. The machinist has to include this on junk like mine where the crank is ground to clearance before treatment based on the bearing torqued in the rod..
The Mahle rod bearings varied in diameter a few 10 thousands of an inch...
