Spitfire Ken
Spitfire Ken
Illinois
29 registered members (BikeVice), 198 guests, and 411 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 62
633,845 mail-order LSR
Topics67,352
Posts653,894
Members10,285
Loose Exhaust Stub 67 650 #597242
04/30/15 7:51 am
04/30/15 7:51 am
dave jones Offline OP
I have one stub that is so tight it cannot be removed but the other has good threads and still loosens.
I looked back over some old threads where John says to remove the first two threads (head end) and then make sure thst there are threads still showing at the other when it bottoms. Is this still the best cure or is there a new one?
If the threads disappear when it is tight I thought I could relieve the plain stub metal next to the last thread (pipe end) to make sure it does bottom.
I also see various oversize stubs for sale but not sure about these.
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #597269
04/30/15 12:24 pm
04/30/15 12:24 pm
kommando Offline
kommando  Offline
The oversize stubs work well, Seeger Engineering do them and if you ring them they will tell you what to measure to determine the best oversize for your head, they come without the first 2 threads as standard so work as Triumph and JH intended.
Re: Loose Exhaust Stub 67 650 [Re: kommando] #597363
05/01/15 5:44 am
05/01/15 5:44 am
Thanks for that. I have now done what I said I would do in my original post- filed off the first two threads and relieved the area just beyond the threads at the other end. Tightened it by putting a bar through and knocking it tight. Hope this fixes but if not I will try an oversized type.
dave
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #597597
05/02/15 1:38 pm
05/02/15 1:38 pm
Surrey UK
Mattsta Offline
Mattsta  Offline
Surrey UK
Yup
Agree with Kommando
The oversize stubs supplied by Seager engineering are excellent
I have oversize stubs fitted on both my exhaust ports and they work very well
1952 Triumph T100 in a BSA A7 Frame
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #623314
10/27/15 5:14 pm
10/27/15 5:14 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
dave
Dave,
How did this work out for you? I had to remove my DS header to open up the primary on my '64 TR6. I found the stub has a bit of wiggle, where once it was tight. I have read John Healy's recommendation and it makes sense to me. I can look inside and see that the end of the exhaust stub is not bottoming out into the head. There are no threads showing on the stub outside the head. The method described here sounds plausible.
If I try to remove the stub to work on it, am I likely to destroy the threads in the head, or should the stub turn out? Are there any special steps to take first, other than soaking it with some penetrant like PB Blaster?
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #623350
10/27/15 9:38 pm
10/27/15 9:38 pm
USA, WA state
russrudolph Online content
russrudolph  Online Content
USA, WA state
I had a loose stub filed 2 threads off and now it is tight, very simple to do.
Re: Loose Exhaust Stub 67 650 [Re: russrudolph] #623376
10/28/15 7:30 am
10/28/15 7:30 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Thanks, russ.
The part I was worried about was taking the exhaust stub out to do the repair. It only rotates in either direction a couple degrees before it gets very tight. I'm thinking I may do more damage to the threads in the head if I force the stub to unscrew. I could just leave it and make sure the header pipe is clamped tightly to the stub. If I do that, is the stub likely to fret in the head until the threads are destroyed anyway? I'm not sure about letting this sleeping dog lie?
Re: Loose Exhaust Stub 67 650 [Re: TR6Ray] #623377
10/28/15 7:36 am
10/28/15 7:36 am
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
Winter is almost here. Might as well fix it before it becomes a major problem. Looks like my head is going to visit England.
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=623097#Post623097
Re: Loose Exhaust Stub 67 650 [Re: desco] #623382
10/28/15 9:00 am
10/28/15 9:00 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Hi desco. I've been reading your thread about a similar (but worse) exhaust stub problem. Before you send your head to England, have you read this 7 year old post by JH?
Re: Loose Exhaust Stub 67 650 [Re: TR6Ray] #623387
10/28/15 10:07 am
10/28/15 10:07 am
Bishop, Calif.
Bishop, Calif.
The only place I found in the USA that fixes this get $250 a hole. And requires welding.
http://www.seager-engineering.com/index....t-thread-repair
These people do both sides for $275 and that includes new spigots and no welding.
I'm thinking about letting them do a valve job while they have it apart.
Re: Loose Exhaust Stub 67 650 [Re: desco] #623395
10/28/15 11:28 am
10/28/15 11:28 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
desco, that looks like it would be fixed for life, especially if they do a valve job at the same time.
With my exh stub able to rotate a degree or two, I'm wondering if it is just the first step to where yours is at right now. Like you said, winter is coming on. Maybe I need to break out the dremel and start cutting a slot thru the inside of my exh stub.
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #623399
10/28/15 11:45 am
10/28/15 11:45 am
JubeePrince Offline
JubeePrince  Offline
Ray -
If the stub is slightly loose, perhaps it's judst carbon build-up that is buggering up the threads and making it difficult to remove?
Desco - If you get the guides replaced, make sure the shop (or even better, you) removes the carbon with soda blasting before removing the old guides....
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #623400
10/28/15 12:06 pm
10/28/15 12:06 pm
kommando Offline
kommando  Offline
Before you ship anything to the UK make sure you have the import documentation setup correctly or the recipient will be charged import duties and VAT. It has to come in a free issue material for work within UK and return to its owner.
Re: Loose Exhaust Stub 67 650 [Re: desco] #623428
10/28/15 4:12 pm
10/28/15 4:12 pm
Running from demons in WNY
Hillbilly bike Offline
In California you tried Franz & Grubb and Raber's?
I ride junk
Re: Loose Exhaust Stub 67 650 [Re: Hillbilly bike] #623430
10/28/15 4:38 pm
10/28/15 4:38 pm
Bishop, Calif.
Bishop, Calif.
Just called F and G. He did the cylinder on the 72. Great work.
Would not touch the threads in the head with a ten foot pole. PITA.
His words not mine. He recommended Seager after looking at their website.
Don't know why but I just don't care for Raber's.
Re: Loose Exhaust Stub 67 650 [Re: desco] #674832
11/18/16 11:57 am
11/18/16 11:57 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
On a BMW airhead, each exhaust header is held in place with a finned alloy nut screwed onto an externally threaded spigot on the alloy head. Conventional wisdom says to remove those nuts yearly to apply a fresh coat of anti-seize. If the nut seizes during an attempt to remove it, the best advice is to stop, cut partially through the nut in a couple places, and fracture it with a cold chisel. To do otherwise, like continuing to try to unscrew the galled threads, will give you the opportunity to remove the head and send it out to get the destroyed threads welded up and re-cut.
All this was running through my mind as I was unsuccessfully using various implements of destruction, into the wee hours this morning, to try to remove the DS spigot from the head on my TR6. The head is still on the engine and in the bike.
When I started, the spigot would wiggle back and forth only a couple degrees of rotation. I can now turn it one full rev before it goes tight in either direction. I have been soaking it in penetrant and working it back and forth.
This '64 spigot doesn't have the tommy bar holes, just the little notches on the outer end. My next trick will be to let it soak while I make up a better tool to attack it. I'm thinking of a cheap 1 1/2" socket, run through with a grade 8 bolt to grab those evil little notches.
Searching for a tip on how to proceed, I found my own, unanswered posts from a year ago (see earlier posts above). Steve suggested that built-up carbon may be causing the problem. I have reached inside the spigot with a hooked pick and cleaned the inner edge of the spigot as much as I could.
So . . . lots of people have replaced these spigots. Am I the only one who has had this much trouble just removing the old one? I started to do this job a year ago, but put it off by just resealing the header joint with silicon. The stub was evidently wiggling and fretting. Toward the end of summer, the engine was popping back on the overrun, signalling a leak at the header joint.
Anybody fought this fight and succeeded? I'd prefer not to have to remove the head and send it off like desco did last year with his.
Re: Loose Exhaust Stub 67 650 [Re: TR6Ray] #674835
11/18/16 12:36 pm
11/18/16 12:36 pm
Bishop, Calif.
Bishop, Calif.
I sent my head to these guys;
http://www.shopevengineering.com/index.htm
a pleasure to work with, quality work and fair price. And MUCH cheaper shipping.
Get it apart anyway you can, you can't use it the way it is.
Never mind. just saw where you are.
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #674842
11/18/16 1:46 pm
11/18/16 1:46 pm
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
Ray, they bind up in the head as the thread gall's. It makes a god awful mess and is a pain in the arse. I had the very the slight advantage of the tommy bar holes. I seem to remember running the motor with the headers off to introduce some heat and continuing in the manner you are going back and forth. Somewhat anti social i'm afraid. I like your socket idea, perhaps with a big 3/4 drive ratchet, turning a bar with the motor in the frame is awkward as hell.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: Loose Exhaust Stub 67 650 [Re: R Moulding] #674867
11/18/16 4:54 pm
11/18/16 4:54 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
desco, thanks for the reference. I've heard nothing but good about E&V and I am happy that you are once again happy with your ride. I'm a lot closer to Michigan than you are, so, if push comes to shove . . .
Rod, Thanks for sharing your experience. That is sort of what I expected.
After some measuring I found that I needed a 1 9/16" socket to slip over the O.D. of the spigot. It's a cheap 12-point socket and that size allows for the internal ribs to fit onto the spigot. The local big box store had 3/4" drive sockets in 1/16" increments, except they skipped 1 9/16"! Oh well, 1 5/8" will work, if a little wobbly. When did somebody teach those Chinese about heat treatment? I had to regrind the tip of my drill a half dozen times to get two holes through the walls of that socket.
Those blasted little slots in the end of the spigot need a 3/16" bolt, but I couldn't find a grade 8 bolt smaller than 1/4" diameter. I had some of those in grade 8, so I drilled the socket again to enlarge the holes to 1/4". Then I ground some flats on the sides of the bolt so it would fit the slots in the spigot.
I just had a go with it. I can turn the spigot back and forth about two turns now, but the slots in the spigot taper outwards. The tool I made wants to ride out of the slots. mad
I'm going to try to Dremel the slots out a little with a round bit to see if I can bring them to 1/4" and semi-round. That should let me use a regular 1/4" bolt. Nothing's easy!
But, just as I was about to tear out the remaining four or five hairs left on my head, the powder coat guy called. I'm off to pick up my BMW swingarm and chill on the TR6 for an hour or two.
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #674868
11/18/16 5:11 pm
11/18/16 5:11 pm
JubeePrince Offline
JubeePrince  Offline
Ray -
I know the engine is in the frame, but fab up some sort of 2' - 3' cheater handle/pipe on your home made tool and let physics take over.....
Afterthought: Might need two people. One to hold the tool on the stub and one to work the cheater end.
Re: Loose Exhaust Stub 67 650 [Re: JubeePrince] #674876
11/18/16 7:59 pm
11/18/16 7:59 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Originally Posted by JubeePrince
Ray -
Thanks, Steve, but no need now:
I used a little burr tool in the Dremel to enlarge the slots in the exhaust spigot, also rounding each side of both slots. Then I put a new 1/4" bolt in my makeshift removal tool. The rounded sides of the slots made a seat for the sides of the bolt and kept the tool from jumping out of the slots. The spigot material is not super hard. I had to reshape the slots several times, because the corners of the slots kept going away.
As I was working the spigot back and forth, it was still squawking and groaning. I put away the penetrating oil and got my little pump can of plain engine lube oil. I brought the spigot out as far as it would go, and put a splash of oil on the exposed threads. I also reached inside the port and put oil at the inside end of the spigot. Then I just worked it back and forth as far as it would go each way, adding oil at both ends every so often. Eventually, it quit squawking, which was encouraging. The spigot began turning more easily within its range of motion. Then, all of a sudden, it started turning freely and just came on out. I think that happened when oil had permeated the full length of the threads.
The threads need a good cleaning in the head, but they look to be intact and in good condition. There's nothing wrong at all with the spigot . . . that a new replacement spigot won't cure.
The mess on the face of the cylinder head is leftover silicone that needs to be cleaned off.
All this was done with the bike's hind end up in the air with no rear wheel, and the centerstand sitting on a piece of 2"x12" for more lift. I had to be extra careful not to tip it over. The back wheel is ready to go back on, but I got caught up in the process of this exhaust spigot.
Cheers! (and I really, really mean that)
p.s. The powder coat job was just splendid on the BMW swingarm!
Re: Loose Exhaust Stub 67 650 [Re: dave jones] #674879
11/18/16 8:18 pm
11/18/16 8:18 pm
Christchurch NZ
R Moulding Offline
R Moulding  Offline
Christchurch NZ
Nice job Ray. well done. You know very well I am a lazy sod and would likely have welded the socket to the spigot!
Rod
Re: Loose Exhaust Stub 67 650 [Re: TR6Ray] #674881
11/18/16 8:41 pm
11/18/16 8:41 pm
Farmington,Connecticut,USA
JBMorris Offline
JBMorris  Offline
nice job with the 'cheater'- how did you drill thru the socket?
1978 Bonneville T140V PX
Re: Loose Exhaust Stub 67 650 [Re: R Moulding] #674886
11/18/16 8:57 pm
11/18/16 8:57 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Rod, you are anything but lazy. Welding the socket to the spigot would maybe be a good idea, but I never learned to weld; the fuel tank is right above where I was working; I have close to $20 invested in making that tool, and I don't want to buy another one for the other spigot grin
{Edit} JB, we must have been typing at the same time. I laid out the holes in the socket to allow the tool to fit full depth into the spigot slots, while the end of the socket came as close as possible to the face of the head without hitting it when the spigot was fully seated. I also located the holes to pass through valleys inside the socket, rather than through the thicker ridges. Then I just hit the mark with a center punch, put the socket into the vise on my drill press, and ran it through. I had to use cutting oil and take it slow. All I had were regular high speed steel bits, but they made it by re-grinding the tip as needed.
An afterthought -- it may have worked better to drill the holes through the socket a bit closer to the end of the socket. Then, holding the socket in place over the spigot, use the holes in the socket as guides to drill holes through the spigot. Then pass a bolt all the way through. That would get closer to Rod's idea of welding the socket to the spigot, but yet leave it removable. I may do this for the other side.
Re: Loose Exhaust Stub 67 650 [Re: TR6Ray] #675029
11/20/16 11:44 am
11/20/16 11:44 am
wisconsin
jurbanec Offline
jurbanec  Offline
wisconsin
Any reason not to drill two holes through the spigot?
