Blapper
Blapper
Kent UK
20 registered members (Allan Gill), 229 guests, and 449 spiders.
10419 Registered Users
btour 85
Rohan 77
Triless 70
reverb 68
713,648 mail-order LSR
Topics68,327
Posts665,185
Members10,419
Copper Head Gaskets? #672576
10/27/16 3:03 pm
10/27/16 3:03 pm
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
This is not specifically a competition question, but I guess you guys would have more of a clue, considering the pressures you put your motors under.
I am rebuilding the top end of my A65 lightning, and have/ will use a copper head gasket, I have it all annealed and ready to go, although I am being advised to use some copper coat sealant before assembly? Now I can't find copper coat here in the UK, but while searching the WWW, I found this snippet on "Access Norton" I use a copper head gasket on my 750 racer. I'd always had trouble with it leaking until someone told me to try ....silver paint! Yep, ordinary spray can silver. Spray a thin coat on the gasket, let it dry and bolt it all together. It never leaks now.
Will this work? there is also a suggestion of using one of the four bond sealants, Yamma bond, Kawa bond, etc.
So tell me your thoughts?
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
1981 Harley FLH
2006 BMW R1200GS
Re: Copper Head Gaskets? [Re: Kev.] #672595
10/27/16 4:56 pm
10/27/16 4:56 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
Yes silver paint works, assemble before it dries.
The other sealant you mention is THREE Bond, it is brilliant on metal to metal joints eg crankcase halves, it can be used very sparingly so a tube will seal hundreds of joints
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: Copper Head Gaskets? [Re: Kev.] #672603
10/27/16 5:37 pm
10/27/16 5:37 pm
kevin roberts Offline
i use this stuff, which is apparently available in britain?
http://www.eBay.co.uk/itm/Permatex-...alant-Gaskets-Seals-Makers-/231471126173
i haven't had any head gasket leakage with triumph copper head gaskets, but i don't push things, really, only 11.75 to 1.
pushrod tom would be the man to ask-- he's running an A65 with significant top end pressures.
Re: Copper Head Gaskets? [Re: Kev.] #672657
10/28/16 7:24 am
10/28/16 7:24 am
Edgewater, Md
Blown Income Offline
Edgewater, Md
I use the same stuff Kevin linked on all of my bikes, even the A65 racer with almost 14:1 compression. I am not sure I would use the threebond style products used for sealing cases on the HG.
1955 BSA Bantam D1 Plunger
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1970 Triumph TR6C
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: Copper Head Gaskets? [Re: Blown Income] #672662
10/28/16 8:36 am
10/28/16 8:36 am
Running from demons in WNY
Hillbilly bike Offline
On liquid cooled engines with copper gaskets a sealer is used around the water and oil passage openings...Some builders coat the entire gasket with Hylomoar or Three Bond, it seems to be and individual choice.
I use the Copperhead spray but in the past I used about any type of spray paint...Dry gasket is probably fine if the mating surfaces are perfect.
For a reference,what did the manufacturer use, if anything, when these engine were new?
I ride dinosaurs that eat money
Re: Copper Head Gaskets? [Re: Kev.] #672663
10/28/16 8:41 am
10/28/16 8:41 am
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
I've been using Gaskacinch. I think it's made by Edelbrock. Available thru major mc parts suppliers. The spray on copper coat is good too. PRT
Re: Copper Head Gaskets? [Re: Kev.] #672722
10/28/16 7:18 pm
10/28/16 7:18 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
I use the Permatex shown above. Follow the instructions. Need to spray freshly before fitting.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Copper Head Gaskets? [Re: BrizzoBrit] #672728
10/28/16 8:22 pm
10/28/16 8:22 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
As youre in the UK, just pop down to your local Halfords branch and get some Loctite Ultra Copper Gasket Seal 5990, see This Link .
I've used this on my A65 and B44 head gaskets and also on the exhaust joints. Its good stuff, only a small smear is needed on the head gasket especially around the oil drain holes and pushrod tunnels.
Re: Copper Head Gaskets? [Re: Kev.] #672754
10/29/16 6:50 am
10/29/16 6:50 am
gavin eisler Online content
gavin eisler  Online Content
Thanks for the link gunner, didnt know about that stuff. O rings help to seal the front oil drains.
las t seal was good with Blue "Comma" sealer , lightly applied, now using "Coppercoat" , the paint idea is a good one, must try that next.
Re: Copper Head Gaskets? [Re: gunner] #672903
10/30/16 5:06 pm
10/30/16 5:06 pm
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
Thanks. :bigt
1952 Norton Special
1981 Harley FLH
2006 BMW R1200GS
Re: Copper Head Gaskets? [Re: Kev.] #672960
10/31/16 8:32 am
10/31/16 8:32 am
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
I picked some lactate up today and some o-rings, so all set now, thanks again.
1952 Norton Special
1981 Harley FLH
2006 BMW R1200GS
Re: Copper Head Gaskets? [Re: Kev.] #672964
10/31/16 9:36 am
10/31/16 9:36 am
mmm Creamy lactate. Sounds tasty.
Re: Copper Head Gaskets? [Re: gavin eisler] #672976
10/31/16 10:57 am
10/31/16 10:57 am
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
auto spell rubbish, it should say Loctite laughing
1952 Norton Special
1981 Harley FLH
2006 BMW R1200GS
Re: Copper Head Gaskets? [Re: Kev.] #672996
10/31/16 2:46 pm
10/31/16 2:46 pm
Allan Gill Online happy
Allan Gill  Online Happy
I have used paint, o rings, well seal, copper coat, and various head gasket sealants and the only thing which has worked first time is using a quality NOS head gasket, mines fitted with nothing as a sealant. Just the annealed gasket on two clean flat surfaces. Notibly on the A65's the oil drain holes are much smaller on the original gasket than on the pattern ones.
But unless your barrel is flat and the head is flat, your pissing in the wind.
Re: Copper Head Gaskets? [Re: Allan Gill] #673344
11/03/16 10:47 pm
11/03/16 10:47 pm
Riverside, CA.
noisy norton Offline
Riverside, CA.
Bingo!!
Re: Copper Head Gaskets? [Re: Kev.] #673362
11/04/16 6:41 am
11/04/16 6:41 am
i once lived in a coastal valley in california tbat was so windy tbat if you did piss outside the wind would whip it away into the sky without it ever hitting the ground.
was this too much information?
it would roll a 7000 pound truck across the gravel if you left both doors open.
Re: Copper Head Gaskets? [Re: kevin roberts] #673377
11/04/16 8:39 am
11/04/16 8:39 am
Or shoveling feces against the tide....Ducati air cooled engine don't have head gaskets.. Dan from Franz&Grubb has built a Triumph with no head gasket...
Re: Copper Head Gaskets? [Re: Kev.] #673392
11/04/16 11:02 am
11/04/16 11:02 am
Bolton Lancs UK
Bolton Lancs UK
On my Greeves I tried both copper and aluminium head gaskets, with and without sealant. It spat them out in disgust! I then re machined the head and used just sealant, it nearly sealed, but I was getting a dribble of oil from the head joint. After looking inside an Aprilia RS125 I copied the head sealing arrangement, no sealant, no gasket just a groove in the head with an "O" ring in it. No leaks no dribbles of oil and I can remove and replace the head without changing the ring
'35 OK Supreme
'36 OK Supreme
Moderated by  Allan Gill
