jim schmidt
jim schmidt
Sanger, CA
30 registered members (Alan_nc), 220 guests, and 448 spiders.
10257 Registered Users
Stuart 75
Lannis 55
TBolt72 47
610,901 mail-order LSR
Topics67,152
Posts651,660
Members10,257
BB34 piston #673057
11/01/16 8:05 am
11/01/16 8:05 am
Lancashire. England.
resingled Offline OP
Hi there everyone. I have a BB34(not GS) with a standard piston BSA part number 65-1265. To try to cure a smoky engine I was going to have the barrel rebored but was advised that it only needed honing. I had this done and the bore does now look good. I don't want to put the old piston back in the nice smooth bore but a replacement appears to be unobtainable. Chris at Autocycle Engineering has done a search for me but drawn a blank. Any suggestions or help will be most welcome. Regards. Dave.
Re: BB34 piston [Re: resingled] #673065
11/01/16 9:56 am
11/01/16 9:56 am
gastonia .. NC
limeyrider Offline
limeyrider  Offline
gastonia .. NC
What is wrong with the " old " piston ?.... new rings and a newly honed cylinder should go well together, am I missing something ??.
Good luck
James.
Re: BB34 piston [Re: resingled] #673082
11/01/16 12:05 pm
11/01/16 12:05 pm
Boomer Online content
Boomer  Online Content
Were the barrel and piston measured for clearance? Were the ring lands on the piston checked against new rings for clearance? If you are within tolerances it would probably be fine to use the old piston with new rings.
Re: BB34 piston [Re: resingled] #673151
11/01/16 11:52 pm
11/01/16 11:52 pm
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
If the piston is not in a poor state and not cracked, but is just a touch undersize, make it 'bigger' with a coating by HPC.
Here's a link to a USA provider (where the parent company lives, I'm sure, though I have used it outside the USA):
http://hpcutah.com/coatings/the-top-5-benefits-of-a-piston-coating/
The coating is slippery and anti-seizure. HPC promote it for other reasons the required here (increase the size of the piston) and they also do a ceramic top coating (also able to be used on combustion chambers and valve heads) for minimising heat transfer). We've used it many times (usually just the side coating) on racing 2 strokes where controlling bore clearance to very tight tolerance is essential. The ceramic top's benefits are arguable both ways in a two stroke - I have used it but no longer bother.
On a 64mm 2 stroke piston we get somewhere between 1 and 2 thou increase in size. As the above website suggests, there can be up to 0.003" increase in diameter (or reduction in bore clearance).
It's cheap (by comparison with new pistons) and is available (unlike some pistons). We have used it on used pistons - the ring lands are masked off and the skirt blasted (not sure what with) to clean it and then the coating sprayed on and baked. The coating has a very fine
'stopped' effect that slowly flattens off a little (more visual and dimensional).
Oliver Wendell Holmes
Re: BB34 piston [Re: resingled] #673170
11/02/16 7:09 am
11/02/16 7:09 am
Thanks for your replies. The "old" piston has a few scratches and in the past has appeared to have "caught" on the barrel. the barrel was also marked but the honing has resolved this so the damage was slight. I have some new original Hepolite rings for the piston but don't feel comfortable putting a lightly scratched piston in a nice smooth bore.
Regards. Dave.
Re: BB34 piston [Re: resingled] #673189
11/02/16 10:51 am
11/02/16 10:51 am
Kent, England
John Alexander Online content
John Alexander  Online Content
Kent, England
Should not make much difference, it's the rings which have the main contact with the bore, so a slightly scratched piston should be ok to use again.
Goldie John.
Re: BB34 piston [Re: resingled] #673195
11/02/16 11:04 am
11/02/16 11:04 am
Magnetoman Offline
Magnetoman  Offline
The iron/steel of the cylinder liner is many times harder than the cast Al of the piston so there's no chance the piston will deface the bore. Also, scratches typically are into a material leaving little or no raised area at the edges. Even if the piston were made of a much harder material than Al it only would be the areas raised above the surface of the piston, not the "grooves" of the scratches, that would be of concern.
This is the essential point. A new, perfectly smooth piston that has the wrong clearance would be very much worse than an old scratched piston that was the correct size for your current cylinder. It is because of small variations in size that machine shops bore and hone cylinders to the diameter of pistons supplied to them with the cylinders. They don't bore to whatever nominal size the pistons are listed as having.
Re: BB34 piston [Re: resingled] #673212
11/02/16 3:34 pm
11/02/16 3:34 pm
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
Of greater importance on the piston is the ring side clearance. That is the clearance between the ring and the land face.
To much and the rings can "flutter", which can cause ring breakage, which then scores the bore and destroys the piston at the least, and maybe gets pieces down into the internal workings, which can cause worse damage.
The BMS book cites 1 to 1.5 thousandths max clearance as acceptable, any more requires a new piston. A feeler gauge should go all the way in between the ring and land, with no appreciable widening of the gap out at the outer edge of the land. Taper in the groove is as bad as to much clearance. (worse, in my experience).
JR
Re: BB34 piston [Re: resingled] #673225
11/02/16 5:01 pm
11/02/16 5:01 pm
Thank you all for your replies. I feel better about putting back the old piston with new rings.I'll certainly check the ring clearance though. thanks for the information Jerry.
