Thomas4
Thomas4
Thun, Berne, Switzerland
192 registered members (68 royalstar tony), 1,675 guests, and 518 spiders.
analyse, Drifter, john harrison, David Stothard, iansouthoz
10039 Registered Users
Lannis 149
kommando 113
478,877 mail-order LSR
Topics65,746
Posts635,570
Members10,039
Page 2 of 2 1 2
Re: 1969 Triumph Bonneville Tail Light Ground [Re: Stuart] #671197
10/16/16 5:21 pm
10/16/16 5:21 pm
Pacific northwest
quinten Online content
quinten  Online Content
Pacific northwest
The ET igniton has 2 distinct and separate power supplies ,
Originating from seperate stator coils ,
feeding
the 2 separate filaments in the taillight bulb .
They then share a single common earth path .
If the taillight lights
And the brake light does not ,
It is not the original common fender/frame earth path ... or the wire you added
... that is/was at fault .
Look for the problem in
1. The power supply (stator coils )
2. The wiring
3. Bulb holder
Or
4. The brake switch
To test the stator ,Jumper a wire from the stator wire
directly to the brake filiment .
If that works , the problem lies somewhere in between .
Re: 1969 Triumph Bonneville Tail Light Ground [Re: quinten] #671216
10/16/16 8:13 pm
10/16/16 8:13 pm
Stuart Online content
Stuart  Online Content
Hi Quinten,
Up to now, I have deliberately avoided mentioning "earth" (or 'ground'), because a) Rick is a relative newbie and b) ET electrics are AC so there isn't any "earth" (no DC distinct 'supply' and 'return').
Moreover, if there really were "2 distinct and separate power supplies", the ignition would only work when the brake pedal was depressed, so the lamp was on ...
So well done for clarifying that ... facepalm
path
Mmmm ... especially when the brake filament draws three times as much power as the tail filament and we have no idea of the condition of the bike and the components that make up the "fender/frame path" ...
Page 2 of 2 1 2
