Back2Brits
Back2Brits
Philadelphia, PA USA
38 registered members (Alan_nc), 194 guests, and 453 spiders.
Tcycles, Metalguru, hanscarlsson, BSADon, VH5150
10220 Registered Users
Lannis 109
Stuart 109
NickL 68
reverb 61
581,550 mail-order LSR
Topics66,854
Posts648,474
Members10,220
tire tube has 2 nuts #669702
10/01/16 4:33 pm
10/01/16 4:33 pm
Douglass Harroun Offline OP
The tube stem has two nuts supplied, and a dished washer. Should I use both nuts, one on each side of rim? The washer against the rubber?
Re: tire tube has 2 nuts [Re: Douglass Harroun] #669703
10/01/16 4:59 pm
10/01/16 4:59 pm
Both nuts, locked together outside the rim, halfway up the visible part of the valve..
Re: tire tube has 2 nuts [Re: Douglass Harroun] #669717
10/01/16 7:49 pm
10/01/16 7:49 pm
I throw one nut in the pile, use other outside rim.
Re: tire tube has 2 nuts [Re: Douglass Harroun] #669961
10/04/16 6:32 am
10/04/16 6:32 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
One nut against the sealing washer on the inside of the rim.
One nut on the outside of the rim.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: tire tube has 2 nuts [Re: RF Whatley] #669963
10/04/16 6:44 am
10/04/16 6:44 am
kevin roberts Offline
fefsa
fefsa
one on the outside valve stem, the other on your keychain for when the first falls off.
live every day.
die once.
Re: tire tube has 2 nuts [Re: Douglass Harroun] #669974
10/04/16 9:20 am
10/04/16 9:20 am
South cone
reverb Offline
reverb  Offline
South cone
...if you put a nut inside the rim you ll have kind of a space when inflate the tire, making more prone to puncture or failure and that s not good in my book
Re: tire tube has 2 nuts [Re: Douglass Harroun] #669994
10/04/16 12:46 pm
10/04/16 12:46 pm
This is attributed to an email from Michelin, on an Ariel forum:
The conical washer sits over the inner tube valve stem and should follow the contour of the valve so that the convex side sits against the wheel rim when fitting.
Once fitted to the wheel the two lock nuts sit on the valve cap side of the wheel rim. After fitment and inflation to the correct pressure, the two nuts should be backed up towards the valve cap, and locked against each other.
This is not usually an issue on correctly inflated road going tyres, but should there be any slippage of tyre on the rim, during heavy braking or acceleration for example, the inner tube could be pulled around slightly with the tyre and if the inner tube is bolted to the rim the valve can be ripped out. If the lock nuts are raised towards the valve cap then inner tube has some leeway to move before this happens. Any movement is thus obvious as the valve stem will no longer be straight and pointing at the centre of the hub, but will be pulled round at an angle.
http://forum.arielownersmcc.co.uk/viewtopic.php?t=3880&start=10#p25405[/quote]
Re: tire tube has 2 nuts [Re: RF Whatley] #669997
10/04/16 12:58 pm
10/04/16 12:58 pm
I recognize you as the expert, but are you really sure about that?
What could possibly be the function of a nut inside the rim?
Why is the dished washer on the tube a really good fit for the rim, but is awkward and grossly out of place against a hex nut?
Why isn't the inside nut a "stress point" for the tube?
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670002
10/04/16 1:50 pm
10/04/16 1:50 pm
Tridentman Offline
Tridentman  Offline
Many thanks, TT, that is extremely helpful and also makes a lot of sense.
Sometimes acerbic wit and sometimes very helpful info --this guy is quite a Scotsman!
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670007
10/04/16 2:05 pm
10/04/16 2:05 pm
An engineer guy at work bought an oil in frame 650 Tiger. He's such a perfectionist he emailed Michelin about the two nuts and that's what they replied with.
At least, so he says. I don't think I've actually seen the reply.....
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670022
10/04/16 4:04 pm
10/04/16 4:04 pm
Irish Swede Online content
Irish Swede  Online Content
I thought the entire purpose of the second nut is to lock the first one in place, and the purpose of the first nut is to lock the valve stem in place onto the rim.
Also, if the tube has been properly lubricated with talc or chalk when it's installed, how can any slippage of the tire on the rim grip the tube enough to rip out the valve stem?
Re: tire tube has 2 nuts [Re: Irish Swede] #670024
10/04/16 4:35 pm
10/04/16 4:35 pm
Yes, while you're fitting a new tyre and tube.
Ok, the tyre goes round and round, leaving the tube in one place. You should do some controlled experiments.
Or argue it out with the makers.
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670034
10/04/16 6:45 pm
10/04/16 6:45 pm
Out There!
Nick Offline
Nick  Offline
Out There!
Does anyone really believe that that little nut on the valve stem is going to 'hold the tube in place' if the tire slips on the rim? Some folks just have to learn the hard way.
The only thing a nut is needed for is for preventing the stem from slipping inside the tire when mounting the tire on the rim and when pushing the stem inwards to allow the tire to properly seat on the rim.
Speedway bikes have an elegant solution: the stem protrudes not from the rim, but from the tire sidewall and has a 90 bend in it (at least they did the last time I went to a speedway race).
Re: tire tube has 2 nuts [Re: RF Whatley] #670036
10/04/16 7:18 pm
10/04/16 7:18 pm
OZ
Triless Online content
Triless  Online Content
OZ
I've always done what RF says, except I use the outside nut, finger tight, to lock the steel valve caps I use.
Its amazing the amount of people who "help " by screwing the nut back down to the rim !
Re: tire tube has 2 nuts [Re: ] #670069
10/05/16 3:26 am
10/05/16 3:26 am
OZ
OZ
Good grief ! That explains it all. Needles has thrown his nuts away !!
Seriously, in this day and age would tyre manufacturers cling to hangovers from pushbike days ! Those nuts are obviously still supplied for a reason !
I agree with RF as to the placement of those nuts.
Re: tire tube has 2 nuts [Re: Triless] #670116
10/05/16 12:45 pm
10/05/16 12:45 pm
And you'll probably get off with it.
Be wary of putting a nut inside the rim for a customer though, now that you know better.
Re: tire tube has 2 nuts [Re: triton thrasher] #670147
10/05/16 5:59 pm
10/05/16 5:59 pm
OZ
OZ
Well, TT, I've been fitting tubes to my bikes the way I was shown all those years ago.And, thus far, haven't had any problem. When I was operating, I only did service work and some engine rebuilds on motorcycles.
Although I change my own tyres I stayed away from that aspect re customers.Actually,the bulk of my work was with stationary engines. No call for tyre changing there !
But, one things for sure, I'll be having a bit of a think now !
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670162
10/05/16 6:49 pm
10/05/16 6:49 pm
I haven't seen tube damage obviously caused by any placement of nuts.
Tubes are fairly tough and most owners don't keep them too long (I hope).
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670226
10/06/16 8:11 am
10/06/16 8:11 am
I fit mine as shown on the Ariel note above, I used to lock both against the rim until my off roading pal told me that the valve could rip out before I even know the tube had shifted, and that if i lock the nuts by the cap I could quickly inspect the valve and see if the tube has moved or not.
Re: tire tube has 2 nuts [Re: Lannis] #670232
10/06/16 8:49 am
10/06/16 8:49 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
I always considered the stem as a separate piece from the tube, and that the washer and first nut were a mechanical backup system in case the bonding between the 2 parts was faulty.
The described stack-up was what I was shown during my professional training in 1966. Every customer and personal tire I've changed since then (which must by now number in the thousands) has been fitted that way with no known failures.
I will point out that the outside nut is left loose (just spun on), because if the tire does slip on the rim, the angle of the valve stem will be the first indicator of trouble, well before the stem is ripped away from the tube. This is important because punctures can be repaired on the road side, but once the stem is ripped free of the tube, replacement is mandatory.
However, being an old dog that's still able to learn new tricks, I'm rethinking the stack-up based on the Michelin memo. You're never too old to learn !
bigt
RF Whatley
Cornelia, GA
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670234
10/06/16 9:07 am
10/06/16 9:07 am
Irene, South Africa
robcurrie Offline
robcurrie  Offline
Irene, South Africa
It's difficult to push on the air nozzle if the valve is not held steady in the rim with a nut, especially if the tyre is flat.
Rob C
Re: tire tube has 2 nuts [Re: Douglass Harroun] #670262
10/06/16 12:41 pm
10/06/16 12:41 pm
Wonder if we'd get a different answer from Dunlop, or Pneumant.
Re: tire tube has 2 nuts [Re: triton thrasher] #670273
10/06/16 2:50 pm
10/06/16 2:50 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
Ok ,
It looks like we're all on the same page ... no one is putting 2 nuts under the rim
